22nd Nov 2021, 10:05 am | #1 |
Kikusui PSU mains cable stowage mod
A rather modest 'success' but one I'm sharing in case it appeals to others.
I have two Kikusui PAB PSUs I acquired from an ex-BBC engineer. He shared my dislike of captive trailing mains cables, or perhaps I acquired that from him too... With test gear in particular, I also don't see the use of yards of trailing cable when I'm working on the bench. Given that these units have insufficient space to add a Cannon or IEC socket, he devised a very neat way of stowing the cables, atop the unit, by the addition of two cable tidy 'brackets' plus opening the square holes in the lids. I've just acquired a further s/h unit - which in any event had a damaged mains cable, and made the same mod myself. It makes for neat stowage. Best explained in pictures. |
22nd Nov 2021, 8:15 pm | #2 |
Re: Kikusui PSU mains cable stowage mod
Neat! I particularly like the nibbled-out ventilation hole bit. The cable brackets will also help with the tendency of some to put a folder/newspaper/whatever over the ventilation holes on hard-worked PSUs- probably more likely in a work rather than home setting.
I'm not a fan of captive leads either- sometimes there's simply no space for an IEC inlet but a stub of cable with an IEC line plug on it is one option. |
