2nd Aug 2023, 5:19 pm | #61 |
Re: Listening to hifi in the perfect position?
Many years ago I had a customer bring in an Audionote single ended triode zero feedback amplifier. A truly awful thing as are all of the breed and easily beaten by a decent music centre amp. I measured around 8W max output and THD around 16%! At 3W it was still something like 3% THD.
When he came to collect it we got chatting hi fi and he asked about my system so I gave him a demo. It was pretty high end gear of the day (about 1990). I put on a good recording and turned up the wick a bit. After a while he turned to me and said "that's got amazing clarity, dynamics, nice tight bass, it very much reminds me of when I worked for a while in a recording studio and heard the playback on the monitors... No I don't like that at all!" |
2nd Aug 2023, 6:10 pm | #62 |
No accounting for taste. I recall back in the seventies there was a very clever guy who I worked in the test department with. He designed and developed speakers in the BBC vein and I don't mean just buying paper cone speakers and using a capacitor to a crossover. He developed Zobels and so on. Anyway, on the subject of valves he said, "They're fine if you don't mind listening to distortion." And of course he was right, most half decent trannie amps have many times less distortion than valved amps. Of course that isn't the full story as we know, but it's a fact.
2nd Aug 2023, 8:24 pm | #63 |
Ah the old valves Vs transistors in audio is a subject with long legs!
I think being single ended, with no negative feedback whatsoever and with all that DC magnetising the tranny core, which needs to be so much bigger to take this (and prob air gapped) so more leakage inductance etc, have more to do with it than the valves per se in this instance For my ha'porth on the wider subject well it's dead easy with line level and lower signals to get 0.5% THD or less with ye olde generic circuits dating back to the 20's. This was thought more than good enough until around the late 60's into the 70's I guess, so maybe there was little effort to reduce it to super low levels (KISS, bean counters and not re-inventing the wheel no doubt all played a part with the status quo here). Many more modern units have simply copied these designs, either because they couldn't design their own, or it was still considered good enough, or to try and get some "vintage valve classic magic" into the sound. If we leave output transformers out of the mix for now then it is perfectly possible to make valve amps using more modern techniques (often one's nicked from Tek and HP valve instrumentation schematics and modified for audio use) that can give very low distortion. Older Audio Research pre amps with phono stage managed about 0.003% and I've designed and built valve stages with similar or slightly better specs myself. Valved power amps from Radford, Audio Research and Esoteric Audio Research (EAR) amongst others have managed THD around the 0.05% level in spite of output transformers. Obviously if it wasn't for the distortion of the transformers themselves and their phase shift, which limits the amount of NFB that can be used, then they could go much lower. I seem to recall a rare Technics output-transformer-less power amp managed about 0.01% THD and a damping factor of something like 80! An all valve apart from the mosfet source follower OPS 100WPC power amp I built many years ago managed 0.005% THD and some excellent 20KHz full power square waves. If you "cheat" and help the valves out by resorting to using solid state devices as current sources and mirrors then THD can be just as low as with all solid state designs I'm still waiting for the "PNP" valve to be invented |
2nd Aug 2023, 8:40 pm | #64 |
Asimov, 'Positronics' If we ever get it, we may not be so keen on the plague of troublesome robots associated with it.
2nd Aug 2023, 8:59 pm | #65 | |
However the shock came when I went for an audiogram and discovered that I also have the well-known "4kHz notch" in both ears, a pronounced dip in the response around that frequency. This makes speech particularly hard to decipher in the presence of background noise. The odd thing is that 4kHz notch hearing loss is usually associated with noise-induced hearing damage. Now while I've been to the odd rock concert (Runrig's was the most painfully loud; it lasted two hours but my ears rang for two days), ran a mobile disco back in my youth and so on, my day job was largely office-based and I never considered that I'd suffered from much noise exposure. The thing is, it's cumulative. It can also have a family link - my father was profoundly hard of hearing, and my sister is more affected than I am - so who knows? Look after your ears, you only have one pair, and hearing aids, as good as they are nowadays, are no substitute. Audiologists don't correct any hearing loss above 8kHz, so most of the top octave of hi-fi recorded music is sadly lost to me forever
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 2nd Aug 2023 at 9:00 pm. Reason: Clarity |
2nd Aug 2023, 9:13 pm | #66 |
Phil,
you are not the only one who is hard of hearing! Many years of my work life I did "special orders" blasting in the mining business. When you are a young guy you enjoy every big booom but the older you get the more you regret and eventually you become aware what it has done to your ears! My audiograms have shown more and more decay, so I do not need any "High-End" gear any more. A strong 1960s valve amp is all I need! Joe |
2nd Aug 2023, 10:05 pm | #67 |
No Longer a Member
Another problem with hearing particularly when you're middle age is wax in your ears, it can also affect your balance. Here in the UK you can get it removed free on the NHS if your GP believes it is necessary. If you've had a build up and got it cleared, it still may need doing again in a few years time. A couple of drops of olive a week in each ear, is supposed to help keep them clear, but there are proprietary solutions which are better.
I remember reading many years ago, I think it was Stan Kenton, told his horn section that they weren't blowing loud enough. "We're blowing as loud as we can boss!" So he got his ears syringed and it cleared the problem. |
3rd Aug 2023, 7:32 am | #68 | ||
3rd Aug 2023, 7:39 am | #69 | |
3rd Aug 2023, 8:57 am | #70 |
Very valid points, Steve. My wife suffers from very waxy ears and despite using olive oil and other proprietary products regularly, she has narrow ear canals and still needs them syringing now and again. This service has all but disappeared. GP surgeries no longer offer it, and the private sector (if you can find a provider) charges exhorbitantly.
Other areas may differ. Good to see this topic being discussed as hearing loss seems to afflict many of us!
3rd Aug 2023, 9:07 am | #71 | |
No Longer a Member
Some chemists will do it for you for around £50. But I'd rather have an experienced nurse with all the specialised equipment. |
3rd Aug 2023, 9:58 am | #72 |
Yes - just had mine done with a sort of specialised vacuum cleaner for £55 from a well-known high street opticians who also offer this service. The syringe method or the water blaster is now frowned upon (though not as much as the cotton bud or worse!).
Once done you will find you need to re-adjust the balance control on your amplifier... |
3rd Aug 2023, 10:26 am | #73 |
I have been fortunate to experience broadcast studio equipment, as well as some very nice kit at a hi-fi exhibition. Back when my hearing was up to the task! Even so, I still preferred a pair of Beyerdynamic (pale grey, oblong) or AKG Professional heaphones. It's not so much about precise positioning in the sound field, or acoustics; more so a sense of immersion in the music.
Not expecting anything near hi-fi is liberating. Simply 'relaxing into' the rich, mellow tone from a valve woodie set brings its own rewards. |
3rd Aug 2023, 12:45 pm | #74 |
Yes good point. I realised this many years ago when I'd got into various albums by enjoying them at a friends place on their ghetto blaster or music centre etc and had then bought my own copy only to find when played on my hi fi system that they were atrociously badly recorded to the point of never being played again!
