22nd Jan 2023, 6:13 pm | #1 |
Tape Choice for Mastering
I have been looking around at new 1/4” tape choices for mastering my own music on my new (to me!) B77mk2 HS here in UK, but I thought I would ask you all what you would choose?
RTM SM900, Capture 914 seem to be highly regarded… I’m going to get the machine looked over and then biased to work optimally with a tape, of which I’ll probably buy a few of reels. Any thoughts / recommendations / experiences gratefully received! |
22nd Jan 2023, 6:43 pm | #2 |
Re: Tape Choice for Mastering
Out of interest, what are the choices these days? Are there many choices?
22nd Jan 2023, 6:50 pm | #3 | |
I’m keen to get a high dynamic range tape, the SM900 seeming to offer a very low noise floor. |
22nd Jan 2023, 7:12 pm | #4 |
All my old Scotch 206 tapes have totally fallen apart, the oxide falls off in strips- so avoid that stuff. It is really dark in colour from memory.
"Behind every crowd, there's a silver Moonshine" |
23rd Jan 2023, 12:39 am | #5 |
Be careful of the tape you buy. With later "+9" tapes your B77 may run out of puff. I think the B77 was designed for no higher than +6 formulations.
23rd Jan 2023, 11:27 am | #6 |
You only need to bias the tape properly - peak record level is up to you.
23rd Jan 2023, 11:40 am | #7 |
RTM is made in France. There is also ATR tape made in the USA, but it's not as easy to find in the UK.
If you can't get good results on RTM, then your machine needs servicing. Nowt wrong with it! |
23rd Jan 2023, 11:44 am | #8 |
Thanks Ted, I was thinking about the B77 record amps possibly clipping before saturating a +9 tape.
23rd Jan 2023, 12:44 pm | #9 |
I have used RTM900 tape with very good results also I have found that second hand Maxell UD, LX and XLI all perform well and don't show signs of age. TDK GX and Memorex tapes also produce good results and don't appear to shed their oxide even when 40 years plus old.
I mentioned in an earlier post about my Ferrograph SP7, the bias on this machine can be adjusted from the front panel with a small screwdriver which the Revox's can't which is helpful when using whatever tape you can get hold of but both of my Revox's are biased for Maxell UD.
Graham |
23rd Jan 2023, 10:12 pm | #10 |
I have used RTM SM911 successfully with a B77.
24th Jan 2023, 8:12 pm | #11 |
RTM SM911 is advertised as +6.
24th Jan 2023, 8:32 pm | #12 |
Another recommendation for the Japanese formulations if you're buying secondhand/NOS. Although not considered professional stock, they have aged very well and can be tremendous performers with correctly calibrated kit.
24th Jan 2023, 10:01 pm | #13 | |
https://datastores.co.uk/product-cat...dio/open-reel/ |
24th Jan 2023, 11:42 pm | #14 | |
Maxell hasn't had any issues with sticky shed. |
25th Jan 2023, 1:38 am | #15 | |
http://richardhess.com/notes/formats...grading-tapes/ Apparently Sony tapes are a bit mixed although I don't see many of those here. UK made 3M tapes are often good but I wouldn't use US made 3M tapes - in fact I wouldn't use any US made tapes at all because just about all of them seem to give problems unless baked. |
25th Jan 2023, 11:04 am | #16 |
Scotch doesn't often go sticky, but I've had matt backed stuff strip its oxide off.
25th Jan 2023, 1:26 pm | #17 |
It depends on the formulation Ted. Some Scotch tape used the same DuPont binder which was responsible for the Ampex problems. The domestic tapes seem to be OK though.
