14th Dec 2022, 6:24 pm | #1 |
Philips N4308/55 Very Faint Playback Sound
Good evening all,
I have just finished replacing all belts and clutches etc but on playback the sound is very feint; can just about hear the tape paying (the tape is a good quality recording. Where should I start tracing the fault. Thank you. Brian |
14th Dec 2022, 7:38 pm | #2 |
Re: Philips N4308/55 Very Feint Playback Sound
Check rec- pb slide switch. Undo output transistors and driver from heat sink testing after each. Common problem.
Regards, Ben. |
14th Dec 2022, 7:41 pm | #3 |
Re: Philips N4308/55 Very Faint Playback Sound
Thanks Ben, will do.
Brian |
