7th Dec 2022, 6:28 pm | #1 |
BBC Tape machine maintenance / alignment specs
This documant is available on the bbceng.info website, but I've attached a copy here for ease of access.
For recorders with VU meters, align 0VU to correspond to 320nWb/m for most tapes. Mods; I don't know if this is worth making sticky? John |
7th Dec 2022, 11:35 pm | #2 |
Re: BBC Tape machine maintenance / alignmet specs
That document makes interesting reading but it also makes a few assumptions which may not necessarily be true outside the BBC. There is no mention of the different equalisation standards commonly encountered - probably because the BBC only used one standard. The reference levels are also higher than normally encountered with domestic machines.
It probably should be read in conjunction with a more step by step guide and also the service manual for the machine that you are working on. |
8th Dec 2022, 10:58 am | #3 |
8th Dec 2022, 8:51 pm | #4 | |
8th Dec 2022, 9:11 pm | #5 |
Re: BBC Tape machine maintenance / alignment specs
The "original" IEC standard (= DIN/CCIR) is now known as IEC 1, and that's the one which the BBC used, and corresponds to the "IEC" position found on Revox A77's etc.
As I understand it, the old "NAB" standard was absorbed into IEC and became IEC 2. So, if an A77 was re-issued today, the replay switch would be labelled "IEC 1" and "IEC 2" John |
24th Dec 2022, 12:51 am | #6 |
Most 'domestic' machines were Nab and normally the consumer line up of 250nWb/m, except for the Revoxes and some European models. That document is for professional machines, as used by the BBC. It is always best to get the service manual for your particular machine and follow those specific guidelines.
