Old 9th Nov 2022, 9:54 am   #1
Vincent1
Default Beocord 5000 (49xx series) mechanism
Hello,
Beocord 5000 (the 49xx series, sliding drawer type
Question regarding the cassete mechanism.
Does anyone know how to correctly remove the cover / cap (part 22033 as per exploded parts diag)
from the supply or take-up reel shaft ?
I wish to remove the reel assys to thoroughly clean..
in particular the small sprung 'trident' assy
The exploded parts I have is a scan..it appears there is an indent at top of shaft
and that somehow the cover fixes into that..and holds the reel assemblies on to shaft
Any knowledge appreciated
best wishes
Vincent
Vincent1 is offline
Old 9th Nov 2022, 10:28 am   #2
DMcMahon
DMcMahon's Avatar
Default Re: Beocord 5000 (49xx series) mechanism
I can see the cover on the drawing but do not know how to remove it.
Some of the forum members who own B & O decks may well know.
If not try posting on -
https://www.beoworld.org/
DMcMahon is offline
Old 9th Nov 2022, 1:17 pm   #3
Vincent1
I found the answer.
It simply pulls off.
Fingernails under just the little conical cover and a vertical pull..
It is a plastic moulding and just clicks into a machined groove at top of shaft..
Presume there is a bead of some sort inside it to engage with groove
The trident which should slide up and down freely
on the table assy was binding at the upper part of its travel..
This meant it would not engage properly with the cassette tape lugs (to drive the tape 'spool'
Unable to rewind sometimes and rattling noise.
The reason was that the inner, hexagonal part of the real assy moulding,
(the part that the trident slide up and down upon), had a hairline crack in one side of the hexagonal moulding.
Thus when the end stopper was puhed back in (nice, relatively tight, push fit)
it opened the crack slightly, giving the upper hexagonal part a slight flare..
causing the trident part to bind..
all best
V
Vincent1 is offline
Old 9th Nov 2022, 3:01 pm   #4
DMcMahon
DMcMahon's Avatar
That is all good news, Vincent.
Like many things fairly simple once you know how.
DMcMahon is offline
Old 9th Nov 2022, 8:20 pm   #5
Vincent1
Drew a diagram to show what was happening in my particular case..
Hopefully it might be of use to someone else..
all best
v
Vincent1 is offline
Old 10th Nov 2022, 10:43 am   #6
DMcMahon
DMcMahon's Avatar
A good diagram and well explained, certainly could be very useful for someone else.
DMcMahon is offline
Old 19th Nov 2022, 4:48 pm   #7
Dillen_de
Gluing the trident to the hexagonal stem in its uppermost position works suprprisingly well.
The tape reels will easily adapt when a tape is loaded.
Martin
Dillen_de is offline
