20th Jun 2021, 11:53 am | #1 |
1970's Sony TC-204 SD Tape Deck No rewind or Pause
Hi all.
I've inherited the above, seems to be OK in many respects but there are 2 issues: (1) The pause button does not budge. (2) When facing the unit pressing ffwd or rewind the right hand spindle turns anticlockwise for both, the left hand spindle does not rotate at all so I only have ffwd. I can't quite see but the l/h spindle looks like it has a groove for a small square section belt but from the service manual it is not so clear to me.. Video here:- ******************************7YXqLV9ns2NwE2Nv6 Photo here of where it looks like there is maybe a belt missing but if there is I'm not sure where the opposing pulley might be that it links to. ******************************d88PLcXUKmz3mjaw7 I've highlighted the belt slot - this might be a red herring, I'm not sure as the r/h spindle has a belt that drives the counter so maybe they just made the one part irrespective of if it had a belt or not (and if not maybe it should be driven / geared from behind - I've not taken it apart to have a look yet) Any help would be appreciated. Thanks.. |
20th Jun 2021, 4:47 pm | #2 |
Re: 1970's Sony TC-204 SD Tape Deck No rewind or Pause
Just to add, I read on tapeheads that somebody else had the same issue and the rewind lever was seized (and/or the leaf spring was bent over the years). If the former i'm not sure how to unseize, I mean it rocks slightly but don't want to force it in case it's actually already rotating full range...
Here's the exploded view and actual image in case it jogs somebodies memory... ******************************BNuQNmUTNyxSDY239 ******************************VXGbUw2LB8goWnPi9 Thanks again.. |
22nd Jun 2021, 11:10 am | #3 |
Yes agreed very difficult from the Service manual to see how the supply reel table is driven in fast rewind.
David Last edited by DMcMahon; 22nd Jun 2021 at 11:23 am. Reason: Typo correction |
22nd Jun 2021, 11:28 am | #4 |
Cheers for the reply David, I made some progress and rewind now working - had a post here on tapeheads which explains. Any idea how to progress further?
http://www.tapeheads.net/showthread.php?t=91285 |
22nd Jun 2021, 1:11 pm | #5 |
Two things...
Firstly, are you a fan of the Fall? Second, and this is just a guess, does the Pause button work when pressed with the Play or record buttons? I may be completely wrong, but its the sort of thing I'd come up against and find the explanation isn't what I'd expected.
Is it live, or is it... no, it's live actually... |
22nd Jun 2021, 1:33 pm | #6 |
First - I was, I am 65+ live outings but I lost count along the line. Miss him and them so... I am also in (west) Oxfordshire btw having left my NW roots some time ago!
Second - The pause button just does not move down under any circumstances. |
