16th Jun 2021, 9:02 am | #21 |
Re: Uher 24 Hi-Fi Special Check Out
Do not remember the Channel Link switch on my CR 240, probably because never got it working sound wise (need to get back to this and progress) so never checked the switch out. Been trying to find my CR 240 (which is in bits some where) to compare the tape control operation.
David |
16th Jun 2021, 11:51 am | #22 |
The CR 240's isn't an electrical switch, just a sliding ramp that engages or disengages a cog behind the right level control to make the knobs move together or separately, though you can lock them together at any point of the teeth - meaning one is constantly higher than the other, for example.
It just rang a bell from your description, if it's not anything to do with multitracking. Perhaps Uher found the option to change levels equally a constant they catered for across different models in different ways. |
16th Jun 2021, 2:42 pm | #23 |
Yes now know exactly what you mean.
David |
16th Jun 2021, 3:29 pm | #24 |
I might be wrong but the pot ganging lines (dotted lines) in the schematic don't look right to me?
Lawrence. |
16th Jun 2021, 4:36 pm | #25 |
I certainly struggled to try and work out how it all worked, maybe there could be a drawing error ?
David |
