Old 3rd Jun 2021, 8:15 pm   #1
themylogin
Default cassette deck mechanism with large diameter flywheel
Attached are the photos of a tape drive mechanism that was widely used in the middle-class Soviet tape decks. It seems quite unusual, using a heavy large-diameter flywheel (implying a 220V motor taken from a reel-to-reel machine). The only idler is used for playback mode; in forward/rewind mode, corresponding pulleys are pulled a little bit back and come into direct contact with the flywheel, resulting in a very noisy (and sometimes tape-tearing) but rapid rewind. My sources claim that this is not an own development and that it was hugely inspired by one of the SONY decks; however, I was not able to find anything like it. Has anyone seen a similar mechanism? I would be very grateful to see an original implementation of this idea.
ID:	235391   Click image for larger version
themylogin is offline
Old 3rd Jun 2021, 9:33 pm   #2
TIMTAPE
Default Re: cassette deck mechanism with large diameter flywheel
I think various companies used AC motors for their earlier mains only powered decks: Sony, Akai and Pioneer to name three.
An interesting feature in this one is that what looks like a metal take up spool idler seems to gain its traction by riding directly on the rubber flywheel belt. I've not seen that before.
TIMTAPE is offline
Old 3rd Jun 2021, 10:53 pm   #3
TIMTAPE
Clarification: the idler seems to connect with the belt as the belt is wrapped around the flywheel. Not necessarily the best way as there would be only a small surface area of contact between idler and belt. More common for the belt to "wrap" around the idler for better grip.
TIMTAPE is offline
Old 5th Jun 2021, 2:18 pm   #4
Jez1234
The Wollensak mechanism had a large flywheel, AC motor and rewind by idler pressing against flywheel. Used in Wollensak, Advent and NEAL decks amongst others. Actually works very well, if rather "agricultural".
Jez1234 is offline
Old 5th Jun 2021, 4:30 pm   #5
TIMTAPE
Probably a similar heavy duty setup was used in their high speed cassette AV 2770 duplicators. Unfortunately a good overall design marred by the reel tables with their integral felt and plastic clutches which tended to increase in torque over time, leading to damaged tapes.
TIMTAPE is offline
Old 5th Jun 2021, 4:48 pm   #6
paulsherwin
paulsherwin's Avatar
As Tim says, synchronous AC motors were used in most early Japanese HiFi decks. DC motors only became common in about 1977.
paulsherwin is offline
