3rd Dec 2022, 6:55 pm | #1 |
AVO instructions for creating a standardised valve.
Hi all,
I am in the process of building a dedicated unit for standardising a valve the way AVO describes it in the VCM manuals. AVO doesn't specify the value / type of potentiometer used for adjusting the grid voltage, has anyone built one, lf so, can you please tell me what you've used, what works well? Kind regards, Waran. |
3rd Dec 2022, 10:20 pm | #2 |
Re: AVO instructions for creating a standardised valve.
I've owned an Avo 163 for a long time, but I've never heard of Avo giving a procedure for creating standardised valves. Indeed, Avo would happily sell you a standardised valve for use with the 163, and very odd valve it was!
I've spent more time engaged in this task than I want to admit to, but did learn quite a lot on long the way. The very first valve I used for the 163 was an ECL80; two valves in one and nobody else wanted them! Then I think I used EF91's for a while before settling on ECC81's, which are just right (Goldilocks) for the 163 (not sure about other machines). With a Gm of 5-6ma/V, the ECC81 aspires to be an oscillator, and discovering this, I had to add a generous number of ferrite beads to my "hand-driven" tracer to keep it stable. I think there are threads by David Simpson on the forum discussing Standard valves, but are a few years old. Could you post a copy of the Avo procedure? B
Saturn V had 6 million pounds of fuel. It would take thirty thousand strong men to lift it an inch. Last edited by Bazz4CQJ; 3rd Dec 2022 at 10:27 pm. |
3rd Dec 2022, 10:53 pm | #3 |
ISTR with the instructions on my AVO VCM it suggests using ( I think) a new ECC82 and EL34 as “ standard valves”. I have a couple of valves marked up as such and packed away carefully in a very safe place!
3rd Dec 2022, 11:08 pm | #4 |
Hi Bazz,
Sorry, guidance on how to standardise a valve is what I should have said, I'm just following the guidance contained within the Mk3 VCM service manual, but no value is given for the potentiometer used in the circuit as a voltage divider. As Tim has mentioned, the valve I want to standardise is an ECC82. I am in the processing of making a dedicated unit for this, the 200V supply will be from my varic, rectified and smoothed, the 6.3 heater supply will come from my DC bench power supply, the grid volts will be from a battery contained in the box. The box contains a 15V meter to monitor the grid volts and a 20 mA meter for the anode current measurement. The switches are there so I can easily connect to external meters to double check readings etc. I think the potentiometer for adjusting the negative grid may be a case of trial and error. Thanks all. |
3rd Dec 2022, 11:09 pm | #5 |
The instructions for the 163 call up (on page 1) the use of an E55L, supplied by Avo. Seems like you must be referring to an earlier model.
New E55L's seem to be priced at ~£250 each on eBay, so I'll give those a miss. Very high Gm if I recall. Avo haven't specified the pot because they haven't specified the PSU for the grid voltage; just needs to be the right pairing to give fine enough control in the right Vg region for the two valves. If you have a decent psu, you may not need a pot but a fixed resistor would do. Be sure to burn-in a brand new valve for at least 24 hours before standardising; some change l a lot. B
Saturn V had 6 million pounds of fuel. It would take thirty thousand strong men to lift it an inch. Last edited by Bazz4CQJ; 3rd Dec 2022 at 11:18 pm. Reason: over-lapping posts |
3rd Dec 2022, 11:47 pm | #6 |
Hi Bazz,
Great advice, thank you. It is not a new valve, I believe it has done some hours but I will be sure to leave it on the rig as suggested to be sure. I only mentioned the pot as I thought it would be some standard valve Avo used, no power supply is recommended, Avo just suggest using a 9V battery for the grid voltage. I will have a play with it tomorrow when I power it up and change the pot if I need too. Fingers crossed it will all go to plan and maybe I can standardise a few more ECC82s if anyone needs them. £250 for a valve, OMG......... Cheers. Waran. |
4th Dec 2022, 12:58 am | #7 | |
B
4th Dec 2022, 10:21 am | #8 |
My test setup (i have a ct160 also) is a Solartron variable ht bench psu and a Farnell E30-2 for bias. I use a 10k 10 turn pot for bias, with the supply to it around 25% more than the highest grid voltage required. Voltages are monitored with 2 Fluke 77 and a Wavetek dvm for Ia. Tests are done at the Avo CT160 book test voltages, with Vg swung 0.5V either side. This is pretty accurate.
However, you still find that there are people out there who will reckon their Acme mickeymouse tester results are correct and my digital readings must be wrong! Rob
4th Dec 2022, 12:06 pm | #9 |
Hello Waran,
Right enough, I've supplied heaps of standardised valves to Forum folk over the years. Waran is quite right, folks, AVO do - in their VCM MK3 & 4 & CT160 Manuals - give circuit diagrams for DC standardising ECC81's & 83's or their CV equivalents. They are wee double triodes & AVO require them to be strapped as a single valve. Easy enough done if you have a bench DC HT PSU, fully metered for voltage & Ia current in mA, and a 2 channel LV DC PSU to provide both 6.3V for heaters & a -ve range of voltage for the grid. It's very important to commence obtaining a range of Ia readings by starting with a high -ve voltage on the grid which is slowly reduced in steps to produce a tabulation for drawing up a wee Ia/Vg graph. However, ECC's are prone to lighting up & going "phut" should one inadvertently chose the wrong Vg, or the Vg PSU lead becomes loose. Me, of late have been using 6AQ5's or 6AU5's - sturdy wee pentodes. A much better Ia/Vg graph is obtained. Plus, later on in the Manual, AVO require you to use a power pentode for a final Ia test. My hand drawing of graphs is jolly outdated, I admit. There are now several Forum valve testing folk who are experts in using modern Curve Tracing software. There are masses of info available by using "Search", not only my ramblings/banging-on, about AVO VCM's & their calibration. Have a lewk. Regards, David |
4th Dec 2022, 8:12 pm | #10 |
Hi David, I've got some 6AQ5's (EL90) but never thought of them for standard valves. They are quite useful output valves and were used in old 2m rigs as modulators, so I guess they sell for appreciable money?
B
4th Dec 2022, 9:05 pm | #11 |
Tesla 6AQ5s are £8.00 each + VAT from Watford Valves:
https://www.watfordvalves.com/produc...hoCtBQQAvD_BwE Likewise, General Electric 6AU5s are also £8.00 + VAT: https://www.watfordvalves.com/produc...il.asp?id=2581
4th Dec 2022, 9:11 pm | #12 |
Not quite David;
From Watford 6AQ5A/6L31-TESLA x 1 = £8.00 Total Goods £8.00 Total Items = 1Postage = £5.00 VAT = £2.60 Total Cost = £15.60 And David Simpson was supplying standard valves last time from his own stash (with no charge). B
5th Dec 2022, 11:31 am | #13 |
Years ago, I used to supply standardised CV455's & 491's or their ECC eq. for a fiver I think. But then I acquired a heap of decent backsheesh 6AQ5's & 6AU5's. Those I supplied to a heap of Forum folk for just postage, plus Martin Forsberg sent me a few more for free when I started to run out.
They are not prone to PO at their full 40 - 50mA Ia, give a decent Gm slope, and give decent readable Ia readings as long as a steady Va & Vs & Vh are maintained. Regards, David |
9th Feb 2023, 1:38 pm | #14 |
Can someone explain the point of strapping the two halves of the ECC82 in parallel, please? As far as I know, it isn't possible to test the two halves of an ECC82 at the same time, so where does the 'standardised' part come?
I always assumed a 'standard' valve was one that could be tested with known characteristics, to check that the tester was working correctly. Surely a single half of an ECC82 would have different characteristics to those of two halves in parallel. Or am I going doolally? |
9th Feb 2023, 2:34 pm | #15 |
Nope, don't think you're going doolally. Avo seemed to suggest different ways of doing things on each of the different testers. I don't have the Mk3, which calls up the twined ECC82, and cannot see what the intention was. There may well have been some benefit for some users with that method, but as long as you are confident about whatever standard valve you use, it should fulfil it's role . With the VCM 163, Avo offered to sell you a quite un-common valve to use as a standard, which had an unusually high Gm and I've never understood that.
B
9th Feb 2023, 8:28 pm | #16 |
Standardising - producing a jolly decent gm Curve similar to or nigh-on identical to a valve manufacturer's "DC" Curve. Mullard & STC produced excellent reference books for their range of valves containing hundreds of DC Gm Curves. Even back in the 20's & 30's , Mazda, Osram, Telefunken, etc., all had pictures of their factory curves either pasted onto their lovely old(now very collectable) coloured valve boxes. Or printed on an accompanying leaflet.
Note - I keep saying "DC Curve", however all of AVO's range of VCM's/Valve Testers all test valves with 50Hz derived P - P or HW rectified pulses. As do Hickok, Mullard & Taylor & many other valve testers. So the Servicing Manuals need to instruct the user to calibrate the Gm determining (AC)circuitry to be as close as possible to the spot-on factory spec. Regards, David |
10th Feb 2023, 11:00 am | #17 |
This is my understanding of a standardised valve. Have spent quite some time reading up about them from the forum and other books.
As DS has pointed out, all the testers we use have the half wave method of measuring the parameters. What the standardised valve does is make sure that the DC curves obtained from a valve will match the curves obtained from the AC tester, nothing more. So when you obtain a gm of 6.6mA/V on the CT160, etc, then by using the most exhaustive DC tests you will also obtain a gm of 6.6mA/V, but only at the stated Ia, Va etc conditions. That seems to be the crucial condition, and the tester has to be calibrated so that when it shows 6.6mA/V then it really is the AC equivalent of that DC value. When making the standardised valve then the DC supplies are varied over a wide range of values, readings taken and graphs plotted to get the resultant curve. This curve can then by put on top of the similar tester curve to get a best fit. This fit needs to be exactly the same for DC and equivalent AC values, and this is where the enourmous care put in by many people on this forum, apologies - brain fade, can't remember their names, with the correct values of resistances, meter current vs deflection etc. What valve is used as the standard is pretty irrelevant, but don't expect to use a standard 6080 against an ECC83, they are working along way apart on the Ia curve, so there will be heating, contact resistance and other errors creeping in. As I said, this is my understanding. I need to make some but first need to get the tester 100%. |
10th Feb 2023, 1:20 pm | #18 |
I have used a variety of valves over a long period of time for my 163. While you can certainly use any valve as a standard, some may prove to be more suitable than others, and that may depend on the machine you are using and your interests.
As explained in my post #2, I very much like the ECC81 as a standard for the 163, as that gives me near FSD readings on the lowest range of Ia and Gm and easily observable readings on the higher ranges. It's also a double valve, so comparing the two sides gives a little extra confidence in consistency. B
12th Feb 2023, 5:10 pm | #19 |
Hi Bazz,
Great idea, I have an ECC 81 knocking about, I will have a go at standardising that to go with my ECC 82. |
12th Feb 2023, 5:39 pm | #20 |
81's can be quite variable, especially ones that have already been used. You can also find 81's which are a bit above the spec and so give Ia or Gm slightly above the low range FSD's, which are no good for this role. Also, the two different sides can vary by quite a bit.
I've tended to operate my standard valves with Vg set at the Avo data value, but actually, there's nothing to stop anyone using a slightly lower (or higher) Vg in order to get test values closer to FSD, but you'd have to be sure you always used the same test conditions thereafter. Be sure to mark the valve is someway which makes it distinctive. I've said before; owning a 163 is a hobby in itself . B
