Old 29th Nov 2022, 12:47 am   #1
Michael Maurice
Michael Maurice's Avatar
Default Glue for speaker cloth
I'm restoring a Philips radiogram and need to replace the speaker cloth.
i have some suitable material, but am wondering which type of glue to use.
In the past, I've used Evo-Stik, impact adhesive after stapling the cloth to the wood.
I'm wondering though if there is a better glue and a better method.
Forum Moderator
Michael Maurice is offline
Old 29th Nov 2022, 1:26 am   #2
joebog1
Default Re: Glue for speaker cloth
If its "proper " speaker cloth, it should shrink with applied heat from a hairdryer or heatgun.
Otherwise my method has been to stretch it evenly over the baffle and staple it generously all around.
A paper stapler wont do. I have several different industrial staplers, including an air driven apholstery "tacker " .
Staples are available in a thousand formats these days, and dont be afraid of the Chinese stainless steel staples. So far my experience with them has been excellent.
Joe
If I had to glue it on, I would be using water based acrylic contact glue.
joebog1 is offline
Old 29th Nov 2022, 2:14 am   #3
Jan Zodiac
I always used staples and wood glue. And that goes for all the different types of cloth I have been using.
Regards,
Jan
ID:	268954   Click image for larger version
ID:	268955   Click image for larger version
ID:	268956   Click image for larger version
ID:	268957   Click image for larger version
Jan Zodiac is offline
Old 29th Nov 2022, 10:07 am   #4
agardiner
agardiner's Avatar
I have tried various glues in the past, but my go-to one now is 'Mod Podge'. This is a multi-purpose craft glue and I find it easier to use, and it doesn't tend to leak through the cloth. Available online of course but also from places like Hobbycraft and The Works.
agardiner is offline
Old 29th Nov 2022, 10:28 am   #5
McMurdo
McMurdo's Avatar
if it's a simple grille/board behind then I spray it with carpet aerosol glue, adding the cloth from the top and gently stretching it over and then on so the weave is level. If the grille is a sort of fret then in the past I have taken evostick (from a can) and thinned it down with a xylene or toluene-type solvent, then brushed it on sparingly with an old paint brush, then added the cloth that way once it's gone tacky.
I haven't used PVA wood glue but I know people who swear by it.
Kevin
McMurdo is offline
Old 29th Nov 2022, 2:13 pm   #6
60136 Alcazar
60136 Alcazar's Avatar
Pre-WW2 they used the same glue as the wood - hot hide glue.
I use Titebond hide glue around, but well clear of, the speaker grille aperture; the glue allows you to re-tension after application as it allows slip, taking a day or so to set properly. It may however bleed through, particularly on light coloured materials (hence applied well away from visible areas). It is a reversible adhesive and can be released with heat or hot water.
Of course, sub-baffle boards are easiest as you can pre-tension the fabric on an external frame and 'drop' the baffle in, or drop the frame onto the baffle, thus ensuring the patterning is correctly orientated.
John
Progress consists of doing what you've always done - just more expensively.
60136 Alcazar is offline
Old 10th Dec 2022, 11:25 am   #7
Iangebbie
One other tip (I have used) is before fitting the cloth apply some Ironing spray (Available at most big stores) then iron before fitting, this helps flatten the cloth and make it a lot easier to fit, it also stops you having to stretch the material, Cheers Ian G
Iangebbie is offline
