Old 19th Nov 2022, 11:12 pm   #1
EnyaFox
Default SPT Video RF Modulator
Hello,
I have obtained a rack mount RF modulator today. I can't seem to find any information about SPT or this modulator. I have included a few photos. If you know anything about it, please let me know!
ID:	268380   Click image for larger version
ID:	268381   Click image for larger version
EnyaFox is offline
Old 22nd Nov 2022, 3:55 pm   #2
coil1234
Default Re: SPT Video RF Modulator
Hello,
can't help with specifics I'm afraid, however SPT stands for Sound Powered Telephones who I believe were taken over by Redifon.
SPT originally made sound powered telephones which are used on ships as a backup means of communications, but I believe they diversified into onboard radio and TV systems.
So this may have been part of a onboard TV distrubution system, or indeed a land based system?
Mike A.
coil1234 is offline
Old 22nd Nov 2022, 5:00 pm   #3
x72
x72's Avatar
Yes, SPT used to do distribution gear for marine use in the 1980s. They were based in Maldon, Essex. From this it looks like they were taken over by Thales after Redifon then that division was closed:
https://find-and-update.company-info...0MEL%20LIMITED
x72 is offline
Old 22nd Nov 2022, 5:08 pm   #4
winston_1
SPT were in Malden in Essex and have been gone for around 20 years now.
I have a number of these modulators and a manual somewhere. They are high output vestigial sideband modulators to almost broadcast spec. The output is around 105dBµv. In your picture the left board is the power supply, the centre board is the actual modulator to BBC spec which gives an output at IF 38.9MHz vision. The module on the right is an upconverter to a (fixed) output channel. The digital display on the front panel is normally hard wired to display the output channel. Broadcast 2 to 12 and 21 to 69. Yours appears to show 88 which I think is cable channel S09. Be aware they may be setup with either a BG (5.5MHz) or I (6.0MHz) sound carrier.
Best way to test it is to connect it to an aerial input on a TV via around 30dB attenuator connect a video source and try to tune it in. Most modern TVs (except Panasonic) will tune cable frequencies, older ones may not.
Any more info required (including converting from BG to I) let me know.
winston_1 is offline
Old 23rd Nov 2022, 6:20 pm   #5
EnyaFox
Could it be a possibility that one or more of the resistors on the display have gone?
I think there is also something wrong with the power supply. I am trying to figure that one out but after a while of being powered, it would trip the RCD .
EnyaFox is offline
Old 23rd Nov 2022, 6:25 pm   #6
EnyaFox
Is it possible to provide more information on the power supply? Like the output voltages or resistor value?
EnyaFox is offline
Old 24th Nov 2022, 5:32 pm   #7
winston_1
The power supply is very simple. A toroidal mains transformer completely isolated with two output windings. One winding supplies a bridge rectifier, capacitor, and 18v regulator to the modulator. The other winding supplies another bridge, capacitor and -24v regulator to the upconverter. This winding also supplies an unregulated -35v supply to the display PCB.
Faulty resistors would cause display segments to go out not stay on.
Can't see how this is causing RCD trips unless the transformer is low insulation to its fixing bolt (unlikely) or possibly the mains input socket or switch.
Old 25th Nov 2022, 6:48 pm   #8
G6ONEDave
G6ONEDave's Avatar
Perhaps the main input filter socket has leakage to earth causing an imbalance of live and nuetral, hence the rcd tripping.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline
Old 28th Nov 2022, 3:09 pm   #9
EnyaFox
Theres a couple resistors on my power supply. I should have specified that. I will take the power supply out and see what I can find
EnyaFox is offline
Old 5th Dec 2022, 9:15 am   #10
inaxeon
Broadcast kit with Belling Lee connectors. My my.
Out of interest how does it do VSB? It does not have very many components. SAW filter?
inaxeon is offline
Old 5th Dec 2022, 4:17 pm   #11
winston_1
No SAW filter. There are a set of filter cans on the modulator board. Do not tweak them.
Old 5th Dec 2022, 9:59 pm   #12
inaxeon
I'm also interested to know - what's inside that up-converter, and how come it's fixed channel?
Would I be correct to assume it's because it contains a high pass filter which is impractical to re-tune?
inaxeon is offline
Old 6th Dec 2022, 3:54 pm   #13
winston_1
The SPT Manuel provides no information on the upconverter. Only that it should be returned if faulty. I believe it was made in Germany. I never had any problems with it.
Old 6th Dec 2022, 6:59 pm   #14
inaxeon
Interesting. Whole thing looks like a maplin kitset from the 1970s but sold as a commercial product!
Definitely would like to see inside that upconverter if any owner of one has a chance to open it!
inaxeon is offline
Old 27th Dec 2022, 1:00 pm   #15
Cathovisor
SPT used to modify Ferguson TX9s and similar to have isolated chassis and line-level inputs - I used to see a lot of them in my past.
Cathovisor is offline
Old 28th Dec 2022, 1:54 am   #16
EnyaFox
When I have a chance to get around to it, I will take some photos and post it here.
EnyaFox is offline
Old 28th Dec 2022, 12:27 pm   #17
winston_1
Circuit diagrams of the modulator and power supply below.
/Users/************/Desktop/Modulator.png
/Users/************/Desktop/Power supply.jpeg
Last edited by Station X; 28th Dec 2022 at 1:04 pm. Reason: Member's personal details redacted
Old 28th Dec 2022, 1:02 pm   #18
Station X
Station X's Avatar
Sorry, but all you've done is told us where the pictures are located on your own PC. You'll need to upload them as described here:-
https://www.vintage-radio.net/forum/...ad.php?t=77650
Graham. Forum Moderator
Station X is online now
Old 29th Dec 2022, 6:38 pm   #19
winston_1
Diagrams here I hope.
Name:	Power supply.jpg
ID:	270512Click image for larger version
