Old 16th Nov 2022, 9:40 am   #1
SpyguyUK
SpyguyUK's Avatar
Smile Yamaha CDR-D651 CD Recorder
I have a Yamaha CDR-D651 CD Recorder. I had not used it for 4 or 5 years but was working ok when last used.
I got it out the other day and both CD doors open and close on their own. CD1 makes a whirring noise too. I sometimes have to close CD1 door manually. CD2 opens by itself. CD2 opens when button is pressed also but CD1 seems to either not shut properly or at all. It won't read discs either.
Could this be a software problem as I assume it's not the belts as both doors do open.
I was going to use it to record cassettes to CD.
Anyone got any ideas what is wrong with it? Video attached of fault.
Using remote control. First part of video with no CD's, second part with CD's.
https://drive.google.com/file/d/1QRG...usp=share_link
Thanks.
SpyguyUK is offline
Old 16th Nov 2022, 10:42 am   #2
paulsherwin
paulsherwin's Avatar
Default Re: Yamaha CDR-D651 CD Recorder
Could be the microswitches getting dirty. Alternatively tired loading belts can produce this symptom despite appearing to 'work' - the slack belt doesn't push the microswitches hard enough. The cheap Chinese belt assortments are OK for this job, at least for a while.
paulsherwin is offline
Old 30th Nov 2022, 11:00 pm   #3
SpyguyUK
SpyguyUK's Avatar
Thumbs up Re: Yamaha CDR-D651 CD Recorder
UPDATE
Thanks. You were totally correct it was the belts! Got the service manual online although only needed to view a couple of pages.
Glad to have repaired this as it's an expensive piece of equipment.
Thanks again.
SpyguyUK is offline
