8th Oct 2022, 4:54 pm | #1 |
BT Ring Generator 2A
I have one of these with some water damage. looks like it could be repairable. Wondering if anyone has a schematic drawing.
18th Oct 2022, 7:55 pm | #2 |
Re: BT Ring Generator 2A
Hi, These are a useful bit of kit & it would be a shame if you are unable to repair.
Never seen inside one so cannot advise but is it possible to see what components / wiring have been water damaged then repair or replace if needs be. A piccy of the internals would be useful. Rog |
24th Oct 2022, 11:40 pm | #3 |
I don't know how extensive your damage is, the only information I have is a photo I took a while back of the PCB in one. I have a higher res photo available if you need.
The installation manual is here if you don't already have it. |
3rd Nov 2022, 1:33 pm | #4 |
I can't remember the number of those I have ( from memory therte seemed to be a few versions as cases were not identical) or even at moment find one. From memory these were used on various PABX to provide a feed for extension bells where the PABX used predominantly system phones. If so ,thanks for the info.
