18th Sep 2022, 6:14 pm | #1 |
Stella Transistor NOT an ST405. (Identified as an ST405T)
Hello,
I don’t usually do transistors but I bought this because my grandfather had one and I was allowed to use it when I stayed. Externally it looks exactly like the ST405 on Rmorg but the IF board and Transistor line up are different. OC44,45,45,75,74,74 There’s nothing with the same line up on the site. I should probably be grateful it doesn’t have the AF117s but does anyone know the model number or if it’s likely to be earlier or later then the AF117 version dated 1964? Thanks for reading. John |
18th Sep 2022, 6:25 pm | #2 |
Re: Stella Transistor NOT a ST405
It will be earlier than the AF11x version. Philips used a very similar chassis in many of their early 60s transistor sets.
18th Sep 2022, 6:31 pm | #3 |
18th Sep 2022, 6:32 pm | #4 |
18th Sep 2022, 6:37 pm | #5 | |
18th Sep 2022, 7:45 pm | #6 | ||
John |
18th Sep 2022, 8:19 pm | #8 |
Re: Stella Transistor NOT an ST405
Yes. The transistor line up in the manufacturer's sheet matches that given by the OP in post #1.
18th Sep 2022, 8:47 pm | #9 | |
Just need to get it working now. John |
19th Sep 2022, 4:42 am | #10 |
Re: Stella Transistor NOT an ST405. (Identified as an ST405T)
i Hope the restoration goes well. It obviously means a lot to you.
All best wishes, Tony
G8KBG - BVWS Member - BATC Member |
27th Nov 2022, 6:48 pm | #11 |
Just an update;
Finally found time to finish this radio. Transistor sets are not my usual thing but this model has special memories for me. There were some faults but just down to connector errors and dirty switches. It’s cleaned up well and perhaps not surprisingly works really well too. John |
10th Dec 2022, 7:24 pm | #12 |
As you say John not surprisingly that it works well ,I have repaired many Philips radios and amplifiers ,they all seem to work better than they should , Mick.
