Old 11th May 2020, 9:45 pm   #101
deepspacedaz
deepspacedaz's Avatar
Default Re: Fixing a GEC BT 302 Television
Thank you for the advice
deepspacedaz is offline
Old 15th May 2020, 12:11 am   #102
deepspacedaz
Hello again. I fired the telly up and all valves glow. Cathode a back glows. But I can hear a really high pitched sound, any ideas
Old 15th May 2020, 12:52 am   #103
deepspacedaz
when I play with horizontal hold frequency changes. can see small dot when I switch off.
Old 15th May 2020, 8:09 am   #104
Heatercathodeshort
Heatercathodeshort's Avatar
So what was causing the lack of valve heaters?
Heatercathodeshort is offline
Old 15th May 2020, 10:38 am   #105
deepspacedaz
Is thats whats happening?
Old 15th May 2020, 10:43 am   #106
deepspacedaz
What is the whining noise its really loud? frequency.
Old 15th May 2020, 10:51 am   #107
Cobaltblue
Cobaltblue's Avatar
The whinning is probably the line output stage and if your getting a dot when you switch off chances are your getting EHT.
You should be able to vary the frequency of the whinning with the line hold control.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 15th May 2020, 11:09 am   #108
deepspacedaz
Ok so its a good start then there's something happening
Old 15th May 2020, 11:12 am   #109
deepspacedaz
Should I able to use some static or will I need a signal for that
Old 15th May 2020, 11:32 am   #110
dazzlevision
If you click on the "Quote" button in an individual post, you can then add your reply/comment to it. That way, we will all know to what you are referring. Otherwise, it is often far from clear.
dazzlevision is offline
Old 15th May 2020, 11:54 am   #111
deepspacedaz
Thanks for the advice
Old 15th May 2020, 12:17 pm   #112
dazzlevision
As Heatercathodeshort asked earlier, can you tell us what was causing none of the heaters to light up, please?
Old 15th May 2020, 12:22 pm   #113
ms660
ms660's Avatar
All I could figure out was possibly the fuse, I couldn't find anything in the posts relating to a defective heater chain per se unless I missed it.
Lawrence.
ms660 is offline
Old 15th May 2020, 12:24 pm   #114
Station X
Station X's Avatar
Post #36 onwards. It's unclear what the situation actually was though.
Graham. Forum Moderator
Station X is online now
Old 15th May 2020, 12:26 pm   #115
deepspacedaz
Ok, the situation is I switch on tv. It makes a high pitched whine sound. No picture but when I switch off I see the classic white dot
Old 15th May 2020, 12:28 pm   #116
deepspacedaz
I had the valves checked yesterday some are a little weak but ok. I can list them if you like. I colour coordinated them but they may have got mixed up. Trouble is Ihe some valves labels have worn off ?
Old 15th May 2020, 12:46 pm   #117
Freya
Freya's Avatar
So it sounds like you ready to put a signal in to it next. It will not display any static, just a blank screen that may be brighter if the brightness is right up
Stephen
Freya is offline
Old 15th May 2020, 12:53 pm   #118
deepspacedaz
If the valves are wrong will i t screw it up ?
Old 15th May 2020, 12:59 pm   #119
Freya
Freya's Avatar
If you got the result with the white dot with switch off earlier then its unlikely to be disastrous. If a signal is applied and everything is in correctly you would likely see something on screen which would then let you know what's needed next.
Stephen
Freya is offline
Old 15th May 2020, 1:27 pm   #120
deepspacedaz
So i need to put a signal through
