16th Feb 2019, 12:51 pm | #1 |
Revox A-700
Good Morning to All,
I am looking for someone that can either repair VU METER for A700 Or have one for sale please... All the best from Alan & Thank you |
16th Feb 2019, 1:01 pm | #2 |
Re: Revox A-700
Try PMing forum member DOFFERY. He does R-R repairs and in located in Blackpool.
16th Feb 2019, 4:19 pm | #3 |
Re: Revox A-700
Thank you for the information, that sounds great
All the best from Alan |
16th Feb 2019, 4:56 pm | #4 |
Re: Revox A-700
They are as rare as hens teeth, the last one I bought several years ago cost around £150
16th Feb 2019, 9:14 pm | #5 |
Re: Revox A-700
The last one sold on ebay was £120, but mine was working OK at that time.
That's life.... All the best and thank you from Alan. |
17th Feb 2019, 3:15 am | #6 |
Re: Revox A-700
Also, sometimes a meter movement can be repaired. I've been successful in some cases. A watchmaker or someone skilled in fine, delicate repair work may be able to do this. Sometimes glues used in original manufacture let go and new glue needs to be carefully applied after realigning the relevant parts. A steady hand as well as lots of patience helps. Probably not for novices!
17th Feb 2019, 11:55 am | #7 |
Re: Revox A-700
Hi
Yes I was looking at a Russian set of photos, where he took one side of the VU meter out, so that gave me an idea, look for a VU meter. The one on the right is working, and on the left the VU meter is not working. So anyone out there have a good right meter they want to sell? All the best from Alan |
17th Feb 2019, 1:24 pm | #8 |
Re: Revox A-700
As posters say - rare as hen's teeth. And v hard to fix. Watch maker country... A700s are not that wide-spread hence the lack of parts - I took 6 months to find the feet for mine.
17th Feb 2019, 5:55 pm | #9 |
Re: Revox A-700
I agree with you, but I might be more lucky getting a meter with one side working, against both working... have to try...
23rd Feb 2019, 8:00 am | #10 |
Re: Revox A-700
Update to this issue, I saw an ad for an LED meter replacement for the A700. Unfortunately I cant recall who the vendor was. Try a Google search.
23rd Feb 2019, 9:15 am | #11 |
Re: Revox A-700
well I do, but I life in the Netherlands
The costs for repair is 50 euro. Jack Marotick |
23rd Feb 2019, 9:23 am | #12 |
Re: Revox A-700
Revox-Online have new replacements for a mere 260 Euro...I'm not sure if the LED jobbie made it into production.
23rd Feb 2019, 12:09 pm | #13 |
Re: Revox A-700
Just seeking a little more detail from Stewartrose. Have you removed the meter unit from the machine? Are you certain it is the meter itself that is at fault rather than the driver circuitry or wiring?
Assuming the problem is the meter, can you measure the resistance of each meter's terminals with a digital multimeter? If they measure the same or close to it, that means the delicate moving coil is intact as well as the connections through the hairsprings right up to the outside terminals. There's more hope of a repair in that case. As already mentioned, if your aim is simply to monitor record levels, a generic stereo LED bar strip and matching driver circuit could be custom installed. An alternative is a similar style of analogue stereo meter, probably needing some mods to adapt but of course not the original look. See photo. |
