22nd Jan 2021, 2:24 am | #81 |
Re: My newly found Marconi 707
Hi Ed,
I've found this dual pot from the scrap set. It is not actually a Morganite part, unlike the one in my HMV 905, but still an original EMI fitted part. It is a little rust at the back, is a bit squeaky and the brass shaft is encrusted with rust from the knob and shaft adapter that were fitted to it. However, both sections work OK electrically. I would rather you don't ask for it until you have had a go at fixing the one in your set first. In any case if can get the original working it will probably be more reliable as your set has not seen the damp that my spare pot has seen. Cheers Andy
www.youtube.com/user/andyvalve100 |
22nd Jan 2021, 3:22 am | #82 | |
Spent this eve looking at this pot. As you can see the outer shaft has snapped along where the C clip would attach to. (As mentioned it was bent!) The surface area looks quite small to attempt to epoxy it - I won’t be able to re attach the C clip! Both Read good though. I could attempt gluing the shaft but concerned it will have a weak point with the C clip tight around it. What are your thoughts? Would you have a shaft from a dud pot which could be sacrificed to repair this one!
With regards, Ed |
22nd Jan 2021, 8:30 am | #83 |
Hi Ed, I've been following your restoration with great interest.
what I would do is drill both parts out on a lathe and fit a pin up the centre and use a little loctite. it will be far better than trying to glue it. there seems to be a hole in the shaft already - does that go all the way through? cheers Tony |
22nd Jan 2021, 9:52 am | #84 |
Hi Tony,
This is a dual concentric control, so the central hole is for the inner shaft. As such it can't be pinned . This is the sort of job that could be done with a lathe, but it would be tricky to make a new shaft, look how thin the metal is at the point where the break occurred. Hi Ed, It looks like that pot is the same type as my spare. Some of the pots EMI used were from the US and this might be one of those. I don't have many of this type and I certainly don't have any other dual pots of this type, except the one I mentioned earlier. I think you definitely qualify for my spare! I'll send you PM. Cheers Andy
22nd Jan 2021, 9:56 am | #85 |
Hi again Ed,
As I've never taken this make of dual pot apart before, I'm curious to know how you got the inner shaft out, or is that broken too? Cheers Andy
22nd Jan 2021, 11:16 am | #86 |
Hi Tony,
As Andy has mentioned this is a dual pot, with the inner shaft hole being for one of the dual variable controls - so unfortunately I doubt I could drill this one out. A restorer friend suggested soldering it, but I don’t know. Hi Andy, Thank you very much! I will respond now. I’ve uploaded some photos here of the inner shaft and it’s fixings. Appears to have another C clip with two brass(?) moulded points to hold the back cover on. I would dismantle further but don’t want to destroy it more, as I think squashing those two little brass points is a one time thing, it won’t hold together afterwards! Such a shame as it’s actually perfectly good working order. Must have been bent up in its early life.
With regards, Ed |
22nd Jan 2021, 11:17 am | #87 |
Here’s a closer photo with light
With regards, Ed |
22nd Jan 2021, 2:23 pm | #88 |
To add to the collection, some photos I took (HMV 904).
In this case I had to make a new broader wiper, since the little washer had long come off the wiper V-lug and the track was badly scored. Steve
https://www.radiocraft.co.uk |
25th Jan 2021, 11:28 am | #89 |
Silver solder would make a solid join but it would fill the groove - is this the outer circlip? If it is you could make up a ring with fixing screws or even just glue a washer in place.
25th Jan 2021, 1:30 pm | #90 |
I could have a go at turning one, but it will be a pain in the bum so only PM me the sizes if you can work out how to get the old one off the paxolin disk- is it riveted on, and could a replacement just glue on if a turned-down shoulder was provided on the shaft?
I don’t want to fit it for you - I have messed up someone’s stuff on here once, which was once too often. M
"The best dBs, come in 3s" - Woody Brown |
27th Jan 2021, 7:08 pm | #91 |
Thanks all for the comments about the pots. Andy has now sent me the spares one to fit so spent the afternoon doing this.
The radio portion of the set is now alive and kicking and receiving well, I thought I would move my attention onto the vision side of things. I replaced the 2 domino capacitors feeding the grids of the timebase and proceeded to apply power. I was gifted with strong line whistle, and could hear the frame timebase purring away, but wasn’t getting any raster on the tube. R41 started burning up and eventually went open circuit. A quick power off, and a search for the shorted cap started. I had already replaced C23, but I think I’ve found the culprit. The shorted cap was behind the brightness/contrast pots, both C3 and 4 were both under 500 ohms, but the location on the schematic had nothing to do with R41 anyway. There’s very few original caps left now, so even though the short is cleared I’ll be cautious. I’ll come back to this. R41 is now replaced so now it’s time to work on the TV side of things. I’ll post some updates when I get something on the tube!
With regards, Ed |
27th Jan 2021, 7:23 pm | #92 |
To add about R41 going up in smoke, C64 and 65 were changed a while ago... who knows!
With regards, Ed |
27th Jan 2021, 8:39 pm | #93 |
I would be inclined to get the damaged one repaired as well, silver soldering will work but the circlip area would need to be turned off as would the other rough end. An aluminium rod can be inserted to prevent solder blocking the centre hole and keeping alignment,. then the circlip groove can be turned back. It would loose a couple of mm in length.
28th Jan 2021, 4:34 am | #94 | |
Hi Stephen, once I’m back in my London workshop, I might be able to rebuild the shaft, or defo give a good attempt at repairing it.
With regards, Ed |
30th Jan 2021, 11:59 am | #95 |
Hi Ed,
Now you should know that to be indoctrinated into the world of prewar tellies you have to be able to complete the following verse:- "A mighty maze of mystic magic rays..." This video of my set should help you answer that one and hopefully give you some encouragement. I know that these restorations can get a bit daunting once the scale of the work sets in. I was halfway through the restoration of my set when I learnt that we had a baby on the way! I'm sure you will get there in the end. The fact that you have already had first light from the tube that proves it is a good one means that you have a good basis for a lovely set. Enjoy:- https://youtu.be/b1vT0IVBQTg Cheers Andy
www.youtube.com/user/andyvalve100 Last edited by beery; 30th Jan 2021 at 12:02 pm. Reason: extra detail |
30th Jan 2021, 2:04 pm | #96 |
Ecellent!
A mighty maze of mystic, magic rays Is all about us in the blue, And in sight and sound they trace Living pictures out of space To bring a new wonder to you The busy world before you is unfurled - Its songs, its tears and laughter, too. One by one they play their parts In this latest of the Arts To bring new enchantment to you. As by your fireside you sit, The news will flit, As on the silver screen. And just for entertaining you With something new The stars will then be seen. So... There's joy in store The world is at your door - It's here for everyone to view Conjured up in sound and sight By the magic rays of light That bring Television to you. But not the only television song to learn. There's also "Here's Looking at You" although the recordings of it are a bit fragmented. “Here's looking at you From out of the blue Don't make a fuss Just settle down and look at us...” |
31st Jan 2021, 12:49 am | #97 |
These songs drive home the special 'magic', 'thrill', and 'wonder' aspects of television in the 1930s - which I think still motivate restorers today!
Steve
31st Jan 2021, 9:51 am | #98 |
Spot-on Steve.
Peter |
31st Jan 2021, 4:35 pm | #99 |
31st Jan 2021, 7:59 pm | #100 | |
-- Graham. G3ZVT |
