15th Jun 2021, 4:09 pm | #41 |
Re: Help with some old TV tubes.
Update.
I ordered a couple of cans of Graphit 33 yesterday and they arrived today, the graphite i had previously tried to apply would simply brush off the CRT, so I cleaned it up and wiped down with some Acetone again letting it dry off for a few hours. The spray stuff is brilliant, it goes on well and does not run off the glass and it does have a good solvent smell with it, this evaporates quickly as the colour changes from a wet black to dull grey. I have applied two coats and after a 10 minute wait , using the DVM probes gently resting on the coating approx 1 inch apart, I am getting 1K8 Ohm. I will let the CRT sit for a day in the garage to see if it gets any lower. I was considering putting the CRT in the sun, but decided against it unless i could find a way of rotating it automatically, I would not want one side of the tube in the sun to expand against the cooler side in the shade. I wonder if anyone with a colour printer has ever made up new Mullard CRT labels and warning papers to apply to a re-coated tube? Adrian |
16th Jun 2021, 3:46 pm | #42 |
The coating went under 1K Ohms per inch after a 'polish' of the coating so very happy with the result. I have swapped the tube for the one in my TV, details in my Ferguson thread.
Adrian |
16th Jun 2021, 4:16 pm | #43 |
Excellent result!
Jac |
