Old 25th Nov 2020, 6:58 pm   #1
Scotorvm
Default Bush AC34 restoration - quiet audio, help, please.
Guy's
Have attempted a restore of what is quite a large set, to me anyway.
I acquired this for £20, which seemed like a good deal when you look at all the workmanship on this.
The case was in poor condition, the laminate peeling, scratched and missing in sections.
Spent a few days on the case and replacing all the wax caps, before attempting to power up.
Audio is there, but very quiet, a couple of stations on MW, no external aerial plugged in for the test, hum from the speaker, but all quiet when the external speaker knob un-screwed on the rear, so somethings working.
Any pointers on where to start appreciated, no voltages checked so far.
Thanks again
ID:	221243   Click image for larger version
ID:	221244   Click image for larger version
ID:	221245   Click image for larger version
ID:	221246   Click image for larger version
Scotorvm is offline
Old 25th Nov 2020, 7:04 pm   #2
Scotorvm
Default Re: Bush AC34 restoration - quiet audio, help, please.
Sorry, forgot to mention, resistors all check out OK.
Scotorvm is offline
Old 25th Nov 2020, 9:05 pm   #3
John10b
Just as a starter switch to Gram and touch the PU sockets with metal probe , or your finger, with volume control turns right up you should get a Healthy buzz.
John10b is offline
Old 25th Nov 2020, 9:12 pm   #4
John10b
Sorry I should have asked do you have the service manual or circuit diagram?
John10b is offline
Old 25th Nov 2020, 9:12 pm   #5
Ed_Dinning
Hi Scot, voltage checks I'm afraid it has to be.
If you have the service data from the forum note that if your figures are within 10% of the values given there is no problem.
Also observe if anything is getting hot and resist the temptation to twiddle the coil cores and trimmer caps
Ed
Ed_Dinning is offline
Old 25th Nov 2020, 9:48 pm   #6
Scotorvm
Hi John, thanks for the tip re the probe, will try that, I do have the circuit diagram.
Cheers.
Lee
Scotorvm is offline
Old 25th Nov 2020, 9:50 pm   #7
Scotorvm
Ed
Thanks Ed, yes I have the DVD from the forum, back to work tomorrow, but will check next week
Scotorvm is offline
Old 25th Nov 2020, 10:25 pm   #8
Sideband
Sideband's Avatar
You WILL need an aerial to hear anything meaningful. It will be very quiet without one.
Sideband is offline
Old 25th Nov 2020, 11:43 pm   #9
McMurdo
McMurdo's Avatar
Most of my radios here would be pretty dead without an external aerial...at least ones without their own internal aerial like yours.
Kevin
McMurdo is offline
Old 26th Nov 2020, 2:10 am   #10
electrogram
Looking at the second pic it looks like some of the pF caps in the RF stages have been replaced... Built in frame aerial for MW/LW.
electrogram is offline
Old 26th Nov 2020, 9:40 am   #11
crackle
What are those blue caps on the tag strip.
Mike
crackle is offline
Old 26th Nov 2020, 9:54 am   #12
vinrads
Looks like the mica capacitors have been replaced! That needs checking out.
Mick.
vinrads is offline
Old 26th Nov 2020, 4:28 pm   #13
Scotorvm
Mike
Mike
The blue caps are in on the strip paralleled to double the value to what it should be.
I replaced the small waxy pF caps too, should I have left them?
Scotorvm is offline
Old 26th Nov 2020, 4:29 pm   #14
Scotorvm
Mick.
Mick, yes I replaced those, a mistake? the old ones were waxy and replaced with the correct pF rating.
Lee
Scotorvm is offline
Old 26th Nov 2020, 5:31 pm   #15
HamishBoxer
HamishBoxer's Avatar
Yes!
HamishBoxer is offline
Old 26th Nov 2020, 6:02 pm   #16
John10b
Do I understand correctly that the Radio works, after you changed the components, as you say in post #1, but with low volume?
John10b is offline
Old 26th Nov 2020, 9:55 pm   #17
Scotorvm
Yes John, on MW can hear at least 2 stations, very quiet at almost full volume, without an external aerial. I think I saved the pF wax caps from another Bush set which I can put in this set, if it would help.
Lee
Scotorvm is offline
Old 26th Nov 2020, 10:16 pm   #18
Simon Gittins
The reason the advice is given not to change the pF values is that they are rarely faulty and to change them may affect the alignment. However, now that you have changed them, there is no point putting old wax types back in.
The best thing is to follow the advice in post 5 and carry out voltage checks. Changing the capacitors may not have affected alignment too badly and it's best not adjusted without a signal generator.
Simon Gittins is offline
Old 27th Nov 2020, 11:42 am   #19
Scotorvm
Cheers Simon
Scotorvm is offline
Old 27th Nov 2020, 2:09 pm   #20
Freya
Freya's Avatar
Did you change any pF caps inside the cans ?
Stephen
Freya is offline
