Old 19th Oct 2020, 7:02 am   #441
john_newcombe
Default Re: Gemini 80-Bus System
Yes it was an xbeaver screenshot. It was FORMAT.COM from CP/M (Bios 3.5).
https://glasstty.com/wiki/index.php/....28Bios_3.5.29
Also, once you have returned to the A> prompt every subsequent CR produces an extra linefeed.
john_newcombe is offline
Old 19th Oct 2020, 9:32 am   #442
JohnBHanson
I tried that image and it does not have a format.com file downloaded from
https://glasstty.com/wiki/index.php/...5.QDDS.img.zip
and used the config line
board 0xe0 gm849_floppy -geometry 80.2.10.0.512 ~/beaver/disks/CPM_BIOS_35.QDDS.img
but the directory does not contain a format program. Can you check I have
the correct address and also send me the config. Thanks.
JohnBHanson is offline
Old 19th Oct 2020, 1:25 pm   #443
john_newcombe
Really sorry, I am in the middle of moving house and have mixed up a few things on the website. All the CP/M Versions I have are now in the Software Library archive which is here. https://glasstty.com/wiki/index.php/...ry_Disk_Images
Once the archive is expanded, you will find the Bios 3.5 boot disk with Format.com in the folder called GM555_64K_CPM.
Really sorry about the confusion. I have updated the website to make things clearer.
Old 19th Oct 2020, 4:29 pm   #444
JohnBHanson
Thanks - It got the program and the same effect as yours. Problem is it performs
an unlisted escape sequence ESC 8. Why? I cannot find any documentation
that mentions this code. On a real SVC card with version 4.1 software it appears
to be ignored. The next 1a byte clears the screen - having already output the copyright message, again strange.
On the emulator this takes the next character and uses it as the font height for the
screen mode. That is why you see a taller font which you said was double spacing.
This is an extra escape code added by me.
I need to work on a option switch to sort out this incompatability.
Old 19th Oct 2020, 6:42 pm   #445
JohnBHanson
Good news - I have added more options to the gm832 svc card board line.
By default these are disabled, but extra functions and extra screen resolutions
can be selectivly enabled.
Note that this now seems to run the format program correctly. However
xbeaver.cfg need these extra features for the startup screen hence
xbeaver.cfg has changed.
I still don't know what esc 8 does or why it is sent. Also the initial
message is followed by esc 8 1a. 1a does a clear screen afterwards, very
strange.
What version of SVCMON have you on your MFB system - I have checked
against V4.1 and it appears to work.
Old 19th Oct 2020, 9:38 pm   #446
john_newcombe
I have the MFB version of Simon 4.1 in the GM916 MFB Machine. There is a Simon 4.2 on the glasstty resources page but this is non-MFB.
I am sure you will have looked already but I have the SVC Manual here and I can see that 1a is the clear screen command, however, I cannot see any reference to ESC 8. I presume you mean 1B 08 rather than 1B 38 (esc "8") either way, there seems to be no documented reference.
Old 19th Oct 2020, 9:52 pm   #447
JohnBHanson
No I really do me 1bh 38h or in ascii ESC 8
The SVC Card uses ESC 1 through ESC 4 for the 4 screen modes it supports.
The emulator has extended that for ESC 1 through ESC 9 to give higher
resolutions. Because of the way cursor position is encoded the limit is 222 columns (Offset of 32, and cpm does not like outputing 0xff or 0xfe in some
versions).
Why the format.com program does is I do not know. On a real SVC card
it appears to do nothing. This code is followed by a 1ah which clears the
screen. This is also strange as it has just output a copyright message
before the ESC 8 ^Z sequence. So the program erases its own copyright
message.
On the emulator before the patch the ESC 8 sequence swallowed the next
character for the font height. which is why it looked like double line spaced.
Even worse - the format.com is coded so that the copyright message is not in
plain text, but is generated by subtracting a sequence from each character
in a string and outputing that.
Why a program would go to such lengths to hide its copyright message is
strange - first hide it coded in the binary and then erase it from the screen
as soon as it is output. The only thing I can think of is that this copyright
is in a library and the author of format wanted to hide the use of the library.
Very strange indeed.
If you want to experiment vpm/m supports the vdu command which can take decimal or hex arguments
eg
vdu 1ah
or
vdu 1bh 31h
etc
(There is also lpt which does the same for the printer).
Of course you can always use chr$(27) etc in basic.
can you please run vidreset which will make the SVC card report its software version number. Thanks. (I have 4.1 which is also
what my emulator reports).
Old 19th Oct 2020, 10:14 pm   #448
john_newcombe
Will run vidreset in the morning but I am 99.9% sure it is SVC Version 4.01. (Note, 4.01 not 4.1).
Old 20th Oct 2020, 9:41 am   #449
john_newcombe
The SVC on my machine is reported as V4.01 1984 when using vidreset.com. I hope that helps. It looks like I don't have a dump of this version only V4.1. At the moment the cards are innacessible as the house move leaves me with several machines stacked next to each other. If it was important I could drag it out and unpack my Dataman to get a dump of it.
I am still having difficulties with T-NET on the machine. I have communications i.e. I can send a char using GEMDEBUG to B4 and see it on Minicom on the server machine and I can see chars comming in on B4 from the server machine. However, a DIR returns a frozen cursor i.e. it stops flashing and a hard reset is then required.
I am wondering if I have the correct version of T-NET I vaguely remember that you re-compiled a version for me when I was experimenting with the Rack System, I am not sure why that was though. I may be mistaken, I usually am.
Old 20th Oct 2020, 9:52 am   #450
john_newcombe
I sould have said, on the server side is see the following:
Code:
Trace tty    : Baudrate requested 9600 set 9600
Trace tty    : Modem control RTS:1 DTR:1
bvrnet file server running - use t-net on the clients to connect
Trace tty < 00:00
Trace tty > 00:00
The two final trace messages appear when I issue the T-NET N command on the Gemini.
My Configuration is:
Code:
#XBEAVER network server configuration file
#Define as a server file - eg no main processor activity
cpuclock 0
#                         baud *tracing*      *ttyport*         *********************** Directories to serve ******************************************
board 0x00 serial_extloop 9600 trace tty tty /dev/ttyS0 bvrnet ./NetworkDrive
echo
echo bvrnet file server running - use t-net on the clients to connect
Old 20th Oct 2020, 4:55 pm   #451
JohnBHanson
Sorry for the delay. You should be using gemdebug with port b8 on a gm813. B4 is the
centronics printer port. However your diagnostic from xbeaver looks correct which indicates
that port b4 is the serial port - this is non standard.
Configuration looks correct for the motherboard serial port /dev/ttyS0. However you did report on your website that previously you
had to use a usb port because of a problem with the linux serial port. If you are using your mac with docker /dev/ttyS0 maybe correct
especially as you appear to send characters it
The same program should work as for the rack system.
PS - just checked tnet in your TNET.1.GEMDDDS.IMG and that works on the simulator - so that should be your correct program assumint the serial port is at b8 (The standard).
Thinking about it the serial port could not be at b4 as it
requires a block of 8 io addresses.
Old 20th Oct 2020, 5:32 pm   #452
john_newcombe
I have no idea why I said B4, it was B8 I was testing with. I have now tried all versions of T-Net that you have sent me over the last year or so just in case they were any differences but alas no joy so far.
Now that you have conformed I am going in the right direction I will do some more digging.
I have attached the RO201 disk contents. This is only the files for now, however the system track looks to be the same as the gem925mfb disk that we already have.
I have just spoken with Charles, the original owner of the machine (and disk!) and have removed a few things that were personal to him. I have checked the rest and it all looks good with no personal data on it.
The disk contains files from both the MFB-1 and MFB-2 systems. This adds to my collection of software and I will try and get what I can documented and sorted out. I will pop the key applications on to separate QDDS floppy images for posterity. I also have both the MFB-1 and MFB-2 user manuals, I will try and get these scanned properly once I have moved house.
Old 20th Oct 2020, 5:53 pm   #453
JohnBHanson
Here is a program to read the svc rom. It copies the rom to
address 8000h in processor memory. If you get the time run
this on *real* hardware and then use a debugger to copy the
8k (length 2000h) down to address 0100h and then exit the
debugger and use the save command to generate an 8k file.
The debug command depends on what debugger you use.
The save command to use is
A>save 32 svcrom.rom
No urgency though provided the format program works on you
systems (emulated and real). Thanks.
Old 20th Oct 2020, 6:31 pm   #454
john_newcombe
No problem I will try and do it tomorrow. Yes the format program does work on the real hardware I have used it to create a QDDS boot disk for the rack system.
Old 20th Oct 2020, 8:33 pm   #455
JohnBHanson
And here is the program....
Old 21st Oct 2020, 3:03 pm   #456
john_newcombe
I have copied and uploaded the SVC 4.01 MFB ROM image to the Gemini 80-Bus Resources page.
https://glasstty.com/wiki/index.php/...01_MFB.ROM.zip
I also now have T-NET working and it took some sorting out. Both my Linux box and the Gemini have their serial ports defined as DTEs which is what I expected, however, the Gemini has the TXD and RXD reversed so neither a DTE or DCE but something of both. I have created a custom cable for now but will sort it all out and make it a proper DTE once I have moved house. Anyway the upshot is that I now have my Gemini networked to a Docker container runing on my Arch Linux box. This also works on my Mac, and Windows should work also.
I will create a Docker 'run' command that starts the server automatically and post it to Docker Hub and glasstty.com when I get chance. That way the server can just run under Docker in the background.
Old 21st Oct 2020, 3:16 pm   #457
JohnBHanson
Swapping pins 2 and 3 on an rs232 is a common trick - I almost mentioned it and now sorry
I didn't.
Thanks for capturing the SVC ROM. It will be worth doing an image of the hard disk
over T-NET for use with simulators etc (Including xbeaver ).
Disked can copy an entire disk over into a file on a t-net server I have done it with
floppies.
Best wishes on the move.
Old 21st Oct 2020, 3:16 pm   #458
JohnBHanson
PS Did the format program work on xbeaver.
Old 21st Oct 2020, 4:50 pm   #459
john_newcombe
Looking at DISKED it wasn't clear to me which command I should use to image the disk, any pointers?
Old 21st Oct 2020, 5:04 pm   #460
JohnBHanson
For disked
Type ? for help
All commands are single letter (Case is important - comments in brackets do not type).
Run disked
A>disked A:
Disked>t0 (Select track 0)
Disked>s1 (Select sector 1)
Disked>Fsn:image.dsk (Select file to dump to)
Disked>Fwnnnn (Write out file of length nnnn*128 bytes)
Disked>Q (Quit)
Notes numbers are entered as hex or as %decimal - eg 10 or %16
? normally gives help at any stage.
PS - not sure append mode works through t-net.
Depending on the bios you maybe able to use nnnn as the full size of
the disk. The I command gives infomation and D selects the disk.
Using I on disk B may give you the total size of the disk (If it has
a large OFF in the Disk Parameter block). In that case multiply
Sectors Per Track by number of tracks reported to calculate nnnn.
Then proceed as above USING disk A and the value of nnnn calculated.
Disked is worth getting to know. Note at start up the disk is write
protected. This is toggled by the w command. Note that changes
to a sector can also be undone with the U command. So it is
easy to learn without risking damage.
