14th Aug 2021, 8:40 am | #81 |
Re: Mains plug restoration
It isn't 'vital' that the outer part of the cap is on the neutral; it's just 'preferable'.
One wonders why the Regulations don't specify it, though. Perhaps to avoid future conflict with some foreign wiring systems? |
14th Aug 2021, 9:09 am | #82 |
The loud Klaxon in the distance is the forum drift alarm going off. We're a long way from the restoration of some vintage plugs.
14th Aug 2021, 11:09 am | #83 |
Sort of back on track.....I took delivery of a very battered mains/battery Vidor portable radio last week and it had one of the MK three pin mains plugs attached, with the external indicator to tell what size fuse it contained, never seen one of these before.....(mine is dark brown, not white as in the example shown, and you guessed it, it had the pointer at 7A and a 5A fuse was fitted....)
14th Aug 2021, 6:21 pm | #84 |
I know the plug, and it's a good idea in principle.
I don't think I've ever seen a 7A fuse, although I have no doubt they exist(ed), 3, 5, and 13 Amp were always the most commonly available ones.
-- Graham. G3ZVT |
14th Aug 2021, 6:25 pm | #85 |
Got a 7 amp fuse in an extension lead, it gets rather hot with a vacuum cleaner on it, a coffee percolator recently purchased has one in the plug, 5A would have been better and cheaper for the manufacturers.
That old MK plug with the pointer would go back to at least 1950's, it's an early example, I have a few in a box but they are being kept as collectors pieces, too rare to use.
Rick, the annoying object roaming the forum. |
14th Aug 2021, 6:57 pm | #86 | |
Most of the world lives with reversible 2-pole connectors, and any requirement or consistent implementation of earthing/grounding being seen as distinctly optional. [My house here has no ground-wires to any light-fittings. Pragmatically, given that the ceiling is 10 feet up and the electroliers/light-fittings don't dangle lower than 7-foot-six, you'd need to be some sort of hyperextensible giant to be able to connect yourself from the electrolier's metalwork to the nearest earthed-point] |
14th Aug 2021, 8:07 pm | #87 |
Electrolier!
What a truly lovely word! Haven't heard it for years! Thanks for making me smile
Best Regards, Peter. |
14th Aug 2021, 8:22 pm | #88 |
We managed one whole post before drifting off topic again maybe this one is done?
After discussion its done Cheers Mike T
