10th Mar 2015, 8:17 pm | #241 |
Re: 405-Line VHF Aerials 2013 to the present day.
A nice idea but when not using one of my old MW/LW radios, I listen to stations being streamed over the internet using an old surplus smartphone.
Chris |
10th Mar 2015, 10:26 pm | #242 | |
In the meantime we may see 405 line tv transmitted from Alexandra Palace when this aerial of yours will come into its own.
Simon BVWS member |
10th Mar 2015, 10:38 pm | #243 | |
Classic TV Show Theme Tunes |
10th Mar 2015, 11:02 pm | #244 |
13th Apr 2015, 1:22 am | #245 |
I spotted these surviving 405 line aerials recently, apologies for the poor quality. They were taken in difficult conditions using my phone's camera.
The first picture is at Ilkeston (Derbys), with the aerial probably pointing at Belmont. The UHF aerials will be aimed at Waltham. The second picture is taken at Matlock (Derbys). I've been walking past this spot for years and never noticed the aerials. They look to be a bit of a DIY installation and are pointing south, so towards Lichfield/Sutton Coldfield. Matlock has several surviving 405 aerials, mostly along the same stretch of road. I'll have to photograph these as well. The last picture is at Sutton in Ashfield (Notts) This aerial would be pointing at Belmont as are two of the three UHF aerials. Michael. |
15th Apr 2015, 11:09 pm | #246 |
Aidan's photo in post 222 of Peter Pennington's TV shop shows a good range of receiving aerials and charts the history of TV from 405 lines up to current digital satellite. There's even a BSB Squarial bolted to the side of the building.
The shop will have seen many changes. Presumably the upstairs space would have been the repair workshop. Michael. |
27th Apr 2015, 5:31 pm | #247 |
Great photos there Michael. Many thanks for uploading them.
Caught this once common combined Ch5/8 aerial in Winlaton, Gateshead earlier today. The vertically polarised UHF aerial is for the Fenham relay. On first seeing the aerial it looks as if one of the BI dipoles had broken off through age. When I saw it later it appears to have been removed on originally mounting it as it would've got in the way of the roof! On second thoughts perhaps it was removed when moved down from the top of the pole to make way for the UHF aerial. There's also a lower UHF aerial directed for Pontop Pike. Cheers, Brian |
11th Jul 2015, 5:09 pm | #248 |
Thought I'd revive this thread, as I saw several such aerials on a recent visit to Maidenhead. These are just a few of the many I saw.
Most, if not all, were pointing towards Crystal Palace. |
11th Jul 2015, 5:09 pm | #249 |
And a couple more.
24th Jul 2015, 4:29 pm | #250 |
I've been taking these photos for a while and saving them, so its about time I up loaded them to this thread!
They are all in Worcester city centre which his quite low lying. Getting a signal from Sutton over the high ground to the NE of the city clearly needed a good antenna. There seems to be examples of antennas for just about every broadcast band on these two buildings. The UHF arrays are aimed at Malvern. Does anyone know what the wooden board was for? Could it have been the support for an early wire radio antenna? Steve. |
24th Jul 2015, 4:53 pm | #251 |
Here are a few more antenna picture from around my area.
The first photo was taken in Upton-upon-Severn. This is another low lying location and clearly need a good antenna for Sutton. There does'nt seem to be any band 1 antenna. The second picture was taken in Tenbury Wells. This array is pointing at Sutton. The last two are on top of buildings in the centre of Ledbury, not far from the old market building. They are both pointing to the SW. I guess with the Malverns and the Ledbury Hills in the way Sutton was no go from here. The UHF array seems to be pointing to the south, not towards Ridge Hill which is only a few miles away. It may just be a bit off the correct heading, but could it have been aimed at the Mendip transmitter? Steve |
24th Jul 2015, 5:40 pm | #252 |
This last group of pictures are of antennas in places out of my local area.
The first antenna is in George Street, Oxford. Assuming that the small UHF array is facing the local Oxford transmiter, the VHF array is facing NW towards the Birmingham transmiters. The second antenna is in Mumbles, near Swansea. The simple band 1 diople would have received a good signal from the Wenvoe transmitter across Swansea Bay. The UHF array, presumably also for Wenvoe, is pointing skywards and the feeder doesn't seem to be doing very much! The third picture is of an antenna on a building in Helmsley market square. The UHF array is pointing at the Bilsdale Moor transmitter, not far NW of here. The VHF array is therefore pointing towards the SW. Would this have been Emley Moor? The "take off" from here is very good to the south. The last two pictures were taken in Pickering. Again the UHF arrays are looking at Bilsdale Moor with the VHF systems probably facing Emley moor with the same good take off as in Helmsley. Steve. |
24th Jul 2015, 9:16 pm | #253 |
The George Street (Oxford) one is apparently on what used to be the Welsh Pony pub. A candidate for an elaborate aerial array, I suppose.
Thanks for posting it. |
25th Jul 2015, 11:37 am | #254 |
Re post no. 252
Can I suggest that if the impressive Belling & Lee double 9 is pointing to Lichfield, then the remnants of the Band I aerial is in the opposite direction (note where the junction box is and the Band II 'twigs')? They're all interesting pics ! |
25th Jul 2015, 12:06 pm | #255 |
Re post no. 251,
The Ledbury aerials: I recognise them ! As for the (J. Beam MBM) aerial, well both Wenvoe (an early TX) and, slightly later, Mendip aerials are to be seen in the locality. Also a few Sutton Coldfield in spite of the terrain. However as you (rightly) imply, the opening of Ridge Hill on UHF swept the board. There were only a few Channel B6 aerials for Ridge Hill 405 line ITA in this part of the world, most were either B8 (Lichfield) or B10 (St Hilary) 'turnarounds'. Last edited by SteveCG; 25th Jul 2015 at 12:08 pm. Reason: clarification |
27th Jul 2015, 10:00 pm | #256 |
Thanks for the comments on the antenna pictures.
I don't know Oxford well, so I had no idea what the building was, thanks Nick. Ok on the VHF array Steve. I noticed that the booms aren't exectly parrallel, but didn't spot that it was facing the other way! I supose that would mean that it was directed at the London transmitters. I wonder why they didn't use London for the ITV signals? Maybe they prefered the Midlands programming. I spotted a few more antennas in Hereford while driving through the city the other day. I'll try to get some pictures next time I'm over that way. Best wishes, Steve |
27th Jul 2015, 10:37 pm | #257 |
27th Jul 2015, 10:46 pm | #258 |
Oxford still has quite a few VHF installations surviving. ITV reception was always very difficult with signals coming all the way from Croydon or Lichfield (not CP or SC, they were BBC transmitters) so there were some impressive rigs in use. Even where the aerials have been removed the very substantial poles remain in place with a tiny UHF aerial perched on top.
The remnant of the band I aerial on the Welsh Pony (now the Eurobar) is probably for AP or CP. Despite the 'posh southern' image, Oxford is culturally a Midlands town. When the Beckley UHF transmitter was opened it was allocated to ATV and later Central. |
28th Jul 2015, 8:44 am | #259 |
I know Oxford fairly well, but didn't know that the 405 line aerial array was still atop the old 'Welsh Pony' pub, which has a different name these days, I believe.
28th Jul 2015, 9:17 am | #260 |
Here's a rather poor "Google Street View" grab showing a combined BI/III antenna at the southern end of Mansfield Road (where it joins Holywell Street). I suspect it's pointing at London, though I'd have thought it should be vertically polarised?
The 'swept back' B1 element is particularly attractive though I doubt it does anything to improve directivity. Last edited by G6Tanuki; 28th Jul 2015 at 9:41 am. |
