26th Mar 2019, 2:33 pm | #81 |
Re: FM to AM Converter?
I intend fitting one of these FM to AM converter boards inside a car radio (Radiomobile 4220) c1950. Should I include circuit protection against voltage spikes? The converter board needs 3v at 22ma sourced from the radio 12v pos earth.
John. |
25th Jul 2020, 3:29 pm | #82 |
FM to AM Radio Converter
Not everyone likes to construct on veroboard as it can be rather fiddly. So finally I’ve got around to creating a new PCB for the FM to AM Radio Converter (hopefully living up to David’s earlier popular design).
If anyone is interested more details can be found at … http://www.i4cy.com/m0oox/fm2am/ Last edited by __i4cy__; 25th Jul 2020 at 3:49 pm. |
29th Jul 2020, 6:46 pm | #83 |
Excellent Guy - great to see this thread woken from it's slumbers - well done on your efforts!
The converter has been a deservedly popular project (81 posts and 14,000 views of this thread). The PCB will make it easier to construct and lessening the chance of errors. The RDA5807M module is a little challenging to solder, but is surprisingly robust, and at £3.50 for five post free from UK suppliers on eBay, it's not going to break the bank if any mishaps occur. Especially useful to provide FM on live-chassis radios such as the ubiquitous Bush DAC90A, to which the direct connection of other external devices to provide FM cannot be safely achieved. Every success with it.
1st Aug 2020, 9:39 am | #84 |
The project had gone a little quiet of late, and with all this spare time I decided to design a PCB. Originally, the plan was to follow up with a PCB depending on the project’s interest. Thankfully David kindly solved this with his popular board design, while adding to the success of the project.
The RDA5807M FM receiver module is the only tricky part to solder to veroboard, especially because of its metric pitch, but is somewhat simplified when using a PCB. The new red PCB is double sided, and has all the frills you get with a professionally manufactured board, including a silkscreen, solder resist, and tinned pads. The only change I’ve made to the circuit is Q1 which was originally a BC184L. As you know this transistor has pin-out variations depending on the part number suffix (BC184, BC184C have different pin-outs). As this caused problems, Q1 has now been replaced with a 2N3904 which is more widely available, cheaper and does not suffer from pin-out variations. (In fact any general purpose low power NPN transistor with Ft > 100MHz and Hfe > 100 should suffice for Q1.) All else remains the same, including the PIC firmware. Guy |
1st Aug 2020, 1:10 pm | #85 |
Inspired by the recent renaissance of this thread I decided to have a go, I had ordered the PIC from Guy ages ago. I have just finished populating a PCB I knocked up yesterday.
Current drawn is 23mA @ 3,1V, I can scope the data pins (2 and 3) from the PIC and have pulses when the button is pressed. The oscillator is around 860kHz, adjustable by about +- 10kHz, but I have no AM audio output. I have removed the RDA module and will try another one as it is a bit fiddly to fit and I may well have damaged it in the process. What level of audio should I expect from the output (Pin 7) of the RDA module?
Eddie BVWS Member. Friend of the BVWTM |
1st Aug 2020, 1:31 pm | #86 |
Hi Eddie, a bit late now but you could have used pin 8 instead of pin 7, I dare say a blob of solder to short the two pads should have worked especially if connection to 7 was damaged.
John.
My favourite text message "I'll be there in five minutes, if not read again" |
1st Aug 2020, 2:15 pm | #87 | |
As the firmware sets the RDA5807M module to mono, you could indeed try using pin-8 instead of pin-7 as John has suggested. But I wouldn’t advise shorting these two pins together. |
24th Oct 2020, 9:05 pm | #88 |
Lately i am messing with old radios, i like em a lot and try to preserve them so i can listen from them but also to pass them to my kids. Problem is that there is almost nothing to hear at AM band so today i said ''what if there is an FM to AM converter available?'' So i google it and minutes later i found this page. I will certainly build that converter to see how it will go. So Hello to everybody and i will keep you updated as soon as i have it ready.
Thomas |
6th Nov 2020, 2:43 pm | #89 |
So few days later I received the PCB and programmed IC from i4cy. I have to say that I am impressed from the high quality of the PCB board. Put everything together (small fm radio unit push my eyes to the limit) and now I can enjoy my favourite music in my old radio.
I would like it to have a stronger output since at list in my radio needs the am cable to plugged into the radio antenna in so I can have reception but I understand this has to do with EMC regulations. All in all I am very happy with it and might build a second unit. |
7th Nov 2020, 3:41 pm | #90 | |
Good to hear the pre-programmed PIC and PCB arrived with you safely in Greece. Also that you have successfully constructed the converter, and are very happy with its results. Thanks for the feedback. Guy |
4th Jan 2021, 12:41 pm | #91 |
I have a few FM to AM Radio Converter construction kits available if anyone is interested. Please note, requires a fine tipped soldering iron and a steady hand.
http://www.i4cy.com/m0oox/fm2am/ Happy New Year to everyone. Guy |
