1st Dec 2021, 2:54 pm | #1 |
Philips 1700 VCR
Hi, I am new to this site and have joined although I know nothing about electronics. I have a Philips 1700 which I brought in 1978 I had it just over a year and it suddenly stopped working. When I pressed the on bar it would turn on then immediately turn off again this happened both when the tape was in the machine and when it wasn't. because I couldn't afford to have it repaired I put it in the loft now 43 years later I have brought it back down but of cause it still does the same thing. Can any one tell me if there is an easy fix to this problem as I would like to see what I have on the dozen tapes that I have.
2nd Dec 2021, 11:22 am | #2 |
Re: Philips 1700 VCR
First thing to check on these vcrs are the belts. They're accessable through the bottom of the vcr. There is a square plastic cover which has two screws and a locating lug. Take that off, flip down the power board and the belts will be visible. The head motor belt, if melted/broken/stretched will cause the machine to shut off as without the head spinning properly it goes into a kind of safe mode. Hope this helps. When ordering a new belt kit DO NOT buy them from a company called MFBfreaks, their stock is old and the rubber is already perished, plus the belts from them are far too thin (I've had some bad experiences with them!!) Good luck Last edited by Snarf81; 2nd Dec 2021 at 11:29 am. Reason: Info added. |
3rd Dec 2021, 6:41 am | #3 |
Thank you for your suggestion I will have a go at it this weekend
3rd Dec 2021, 11:05 am | #4 |
Hi, thanks for the great reply I have had a look at the belts and the Head belt and the Capsten belt were both broken so I will order some and hopefully it will do the job.
Regards Vince |
3rd Dec 2021, 11:31 am | #5 |
Obviously the belts need replacement but it seems unlikely the belts would have failed only a year after you bought the machine. It was probably something else at fault all those year ago but as Snarf says, the belts need replacement now.
3rd Dec 2021, 11:33 am | #6 |
Please see this thread explaining how to attach images to posts: https://www.vintage-radio.net/forum/...ad.php?t=77650
3rd Dec 2021, 1:30 pm | #7 |
Thank you for that information. Here are the photos of the belts.
8th Dec 2021, 2:59 pm | #8 |
Hi. Well I have fitted the new belts and the machine comes on and stays on which is a big plus as it hasn't done that in 43 years. However when I put the tape in it doesn't play, I can hear the head spinning but the tape doesn't move. After around 30 seconds the unit turns itself off and just before it stops the tape moves a very little bit. Also, and I don't know if this is important but the fast forward and rewind buttons don't depress. Any thoughts as to what I'm doing wrong?
8th Dec 2021, 6:44 pm | #9 |
How many belts did you replace? All 4?
The loading system might need to be cleaned and the worm gear on the loading motor might need new molykote grease. Also there are some metal sliding arms under the flip up servo board (to the right of the video head and transport) which might need cleaning and lubricating. You can trick the vcr into thinking a cassette is in by removing the cassette basket and moving a flat lever on the bottom right (iirc), then you'll see if the loading process is being completed or not. |
9th Dec 2021, 9:29 am | #10 |
I replaced the Capsten and head belts the other two seamed good the belts came from the German company on eBay 25 euro and the seem to fit well.i have some 3 in 1 professional lubricant will that be ok for the sliding arms?
9th Dec 2021, 3:01 pm | #11 |
3 in 1 is fine, but use it very sparingly and wipe off all excess as you don't want to get it on any part of the tape path and pinch roller.
