27th Nov 2021, 11:49 am | #1 |
Ferguson 51K5.
I'm giving the set's PCB a lookover before it is dispatched to it's new owner.
The set was last used in 1994. The board looks to be in excellent condition. DFWB. |
27th Nov 2021, 1:23 pm | #2 |
Re: Ferguson 51K5.
It actually does look great, especially seeing as it was all the way back in 1994 that it was last used.
Cheers, Luke |
30th Nov 2021, 1:09 am | #3 |
Re: Ferguson 51K5.
Found quite few dry soldering joints which have been dealt with.
Hopefully, I haven't missed any. So the time came to take a chance and for the first time after twenty-seven years out of use the set was switched on. The channel indicator showed the figure 1, but no activity on the screen. Mea culpa, forgot to reconnect the scan coil plug. Switch on again, voila! A snowstorm on the screen. DFWB. |
30th Nov 2021, 1:16 am | #4 |
Re: Ferguson 51K5.
This looks like the era when they used Rifa caps (white) as suppressors on the mains i/p. I recently changed them on three Thomson -based sets I brought out of storage after about 12 years.
The first one let go and filled the workshop with acrid smoke!
Regards, Ben. |
30th Nov 2021, 1:46 am | #5 | |
Re: Ferguson 51K5.
I'll replace the RIFA cap once its over, I bought a bunch of them for £1 on eBay. Not risking filling the room with smoke, the stench is even worse than the smoke. When the WIMA in my IKC2 let go the smell took a full week to get rid of.
Cheers, Luke |
30th Nov 2021, 11:00 am | #6 |
Re: Ferguson 51K5.
Should have been Ferguson - Stranger Ideas!
Hope the 59P7 is as good - however I always found the 21" versions to be far more reliable. As far as I remember mine was working around ten years ago when I changed it for the customer. It had a slight E/W fault which was either a dry joint or junky pot as it jumped out when you touched the chassis. |
30th Nov 2021, 11:53 am | #7 |
Re: Ferguson 51K5.
The 51K5 employs the 21" 45AX CRT which has 110degree scanning so the timebase circuits are almost the same as the 59P7.
The set was allowed to run over an extended period and then went into standby. Panic stations! Pressing the channel up and down buttons didn't return the set into operation. Then it was realised the channel up button has to be depressed for three seconds or so. Although disliked by many technicians there is a lot of clever circuits in the ICC5 chassis. Noteworthy is the frame timebase which creates the sawtooth waveform by integrating line pulses from the transformer. DFWB. |
30th Nov 2021, 12:32 pm | #8 |
Re: Ferguson 51K5.
I agree. Those designers were a clever bunch!
I hope I misread that, and you didn't buy "new" RIFA caps to replace the old to avoid the risk of filling the room with smoke. |
30th Nov 2021, 12:44 pm | #9 |
Re: Ferguson 51K5.
I recently repaired a Ferguson Music centre which had suffered from a Rifa burn up, it was on top of the mains transformer and had really burned out violently .
The owner had kept if for sentimental reasons but had assumed it was "burnt out beyond repair" due to the amount of smoke. I wonder how many appliances have been taken to the tip for the sake of a flambecap? In the case of the ICCxx range some engineers would say the best thing for it would be to set fire to it !
The rotation of the earth really makes my day... |
30th Nov 2021, 1:10 pm | #10 |
Re: Ferguson 51K5.
I believe that TV receivers equipped with the !CC5 chassis were introduced into the continental marketplace in 1986 so by the time it was introduced to the UK it was a well understood design for the Ferguson team to customise for UK requirements.
Picture quality was always excellent. The 51K5 we're discussing here comes with the correct remote control handset which has the function change switch on the side of the case. DFWB. |
30th Nov 2021, 2:14 pm | #11 | |
Re: Ferguson 51K5.
Cheers, Luke |
30th Nov 2021, 2:15 pm | #12 | |
Re: Ferguson 51K5.
Cheers, Luke |
30th Nov 2021, 2:18 pm | #13 |
Re: Ferguson 51K5.
I imagine alot of the ICC stuff along with the IKC2 would have been disposed of once the room filled with smoke, people would naturally assume its toast.
Cheers, Luke Last edited by IKC2E51R8; 30th Nov 2021 at 2:23 pm. |
30th Nov 2021, 2:23 pm | #14 | |
Re: Ferguson 51K5.
My other IKC2 has a problem where if its left in standby for more than half an hour, the red LED will go dim and the set will refuse to come out of standby, the temporary cure is to leave it unplugged for about an hour and then try again and immediatly bring it out of standby. I Havn't actually gone looking for the fault, i'll have to at some stage.
Cheers, Luke |
1st Dec 2021, 12:01 pm | #15 |
Re: Ferguson 51K5.
Sssh - we made a few pounds from holding the P+ button in, not just on these but on aand some Toshibas too! Then it was time for some acting, removing and refitting plugs and re-tuning so the customer didn't feel stupid for not knowing what to do (and to justify the call-out charge).
1st Dec 2021, 1:10 pm | #16 | |
Re: Ferguson 51K5.
Cheers, Luke |
1st Dec 2021, 4:05 pm | #17 |
Re: Ferguson 51K5.
Off-screen picture taken earlier today. The 51K5 is connected to a DVD player via the SCART socket.
DFWB. |
1st Dec 2021, 4:53 pm | #18 |
Re: Ferguson 51K5.
Amazing, I cant wait to see it in person, Picture on it looks great.
The 59P7 That Glyn gave me arrived today and arrived in one piece, Havnt powered it on yet, have just finished tending to some dry joints in it
Cheers, Luke |
