Old 26th Nov 2021, 3:27 pm   #1
Sundog-
Sundog-'s Avatar
Default Mullard valve genuine?
I purchased a "Mullard PL36", but I don't think it is a genuine Mullard. Before I complain to the seller, I'd just like to check my reasoning:
Although the box is Mullard, the valve has no Mullard logo (just a worn"PL36"mark", nor any visible etch codes on the glass.
Am I correct in assuming it is not a Mullard?
Last edited by Cobaltblue; 27th Nov 2021 at 12:35 pm. Reason: to comply with rules
Sundog- is offline
Old 27th Nov 2021, 1:06 pm   #2
Amtec123
Default Re: Mullard valve genuine?
Difficult to be absolutely sure, but the font doesn't look correct. Does the box say 'Made in Great Britain' or 'Foreign'. If MiGB then there should be a lot more writing on the valve ie 'BVA Made in Great Britain', (google Mullard PL36 valve museum). If the box says 'Foreign' then it could be genuine, either way it might not be the original box for that valve.
Have you tried the valve? It looks quite clean with no blackening.
Good luck.
Amtec123 is offline
Old 27th Nov 2021, 2:43 pm   #3
kalee20
It doesn't look like Mullard's printing.
But what's 'genuine' anyway? I have a DF1 pentode, Mullard red print, 'pentone' trademark, in a Mullard box, but... the base is screen-printed 'Made in USA.' Since when did Mullard have a factory in America?
The answer of course, is that it's a (probably) Sylvania-produced 1N5, bought-in by Mullard during the early years of the War when their own production was maxed-out; tested by Mullard; labelled by Mullard; and despatched by Mullard in a Mullard box. So if Mullard give it their blessing, is it genuine or not?
kalee20 is offline
Old 27th Nov 2021, 2:46 pm   #4
mark pirate
mark pirate's Avatar
Certainly does not look like a Mullard, the font is not correct.
The fact the writing on the valve is worn away, could indicate a used valve, it was quite common for engineers to put a used valve back in the box after replacing it.
If you have access to a valve tester, I would check it's emission.
Mark
mark pirate is offline
Old 27th Nov 2021, 3:04 pm   #5
dazzlevision
Here are two Mullard PL36 valves. Yellow is circa 1963-4 with old Mullard shield logo. White is early 1970s with new Mullard shield logo.
I’m sceptical that your valve is one originally branded and sold by Mullard, even if they didn’t actually make it themselves.
ID:	246752   Click image for larger version
ID:	246753   Click image for larger version
Last edited by dazzlevision; 27th Nov 2021 at 3:06 pm. Reason: I’m sceptical that your valve is one originally sold by Mullard.
dazzlevision is online now
Old 27th Nov 2021, 3:53 pm   #6
I ask why are you bothered? If it works that will do in my book.
Old 27th Nov 2021, 4:23 pm   #7
Norman Raeburn
To be fair, the seller probably knows little or nothing about the valve. They may have inherited a collection and believe it to be Mullard because of the box. I wouldn’t think the intention was to deceive. Mullard aren’t the be all and end all in valves and as merlinmaxwell says, as long as it works.
Norman Raeburn is offline
Old 27th Nov 2021, 4:33 pm   #8
AC/HL
AC/HL's Avatar
The 'etch' codes are painted and can also suffer from age and cleaning, but the remaining PL36 doesn't look genuine at a glance. Valves were often multi sourced and rebranded, even by the major manufacturers, the logo and type just added at the point of sale. Whether or not it works is the important fact, but if it was specifically bought on brand it does seem dodgy.
AC/HL is offline
Old 27th Nov 2021, 5:24 pm   #9
Cobaltblue
Cobaltblue's Avatar
I think there is a consensus about this valve it is of course up to the OP what he does next.
This is a good time to wind this one up
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
