8th Mar 2023, 5:54 pm | #21 |
Re: Capacitors "Black Museum"
Thread reopened by request.
8th Mar 2023, 6:09 pm | #22 |
I have just removed two Dubilier Type 700.
Tried some DC on them and was up to 12mA by 250V (and it started to climb), so bottled out. Thought 3W dissipation was enough...! Given they are toast, applying a rather unfair 500V insulation tester yielded a few tens of kΩ resistance. Straight resistance measurement was about 1MΩ. Both very similar and one cased showed signs of splitting open.
Richard | BVWS & RSGB member | |
8th Mar 2023, 6:09 pm | #23 |
8th Mar 2023, 6:23 pm | #24 |
BEC electrolytic 1964 vintage.
8th Mar 2023, 6:25 pm | #25 |
A gaggle of bubblers.
TCC Type 343 and 543. DCC "WM" although suspect latter is a date code. Not this is ELV rated. Hunts A306.
8th Mar 2023, 9:06 pm | #26 |
Is the BEC electrolytic shown really duff?- they're generally one of the better survivors, though of course the odd exception can be excused after all this time.
8th Mar 2023, 9:19 pm | #27 | |
The other section was quite exciting: 15mA by 200V and starting to run away. In each case I did bring them up from 0V progressively - I didn't just bang them on at 200V.
8th Mar 2023, 10:00 pm | #28 |
Location: Ellesmere, Shropshire, UK & Co. Cork, Ireland.
Black 1Kv labelled 'Plesseal' 0.1mfd caps from 1962. All spurting molten wax but not gone dead short. Appear to be dip coated in a black shiny coating. Found in a Irish built Pilot 23/625 TV from around 1962. Oval in section and approximately 3 inches long.
Dom Less snakes...more ladders! |
9th Mar 2023, 8:56 am | #29 |
Your Plesseal caps look very similar to the Wima and ROE types used in German radios of the '50s - Grundig etc. Those types tend all to be leaky too.
John |
9th Mar 2023, 10:49 am | #30 |
Another bad kind are the "micamold" capacitors from the USA - they look like dominoes.
I am surprised by one or two shown above. Perhaps what we really need is the list of the ones that are known to usually be OK? |
9th Mar 2023, 11:02 am | #31 | |
I'll open one to kick it off.
9th Mar 2023, 3:41 pm | #32 | |
And they go leaky. There are two of them in parallel serving as "that capacitoir" in the RCA AR88 receiver, so doubling your chances of something bad happening to the output valve!
9th Mar 2023, 6:13 pm | #33 |
To me, that "Plesseal" looks like a re-badged Wima, and it certainly seems to have behave like one!
Les. |
9th Mar 2023, 7:47 pm | #34 | |
Two rather than one won't halve the lifetime (luckily!) |
9th Mar 2023, 8:05 pm | #35 |
9th Mar 2023, 8:44 pm | #36 |
It would be interesting to check this out. I would agree that paper capacitors from the same batch are likely to have the same life as it looks like the quality of the paper is what leads to the leakage.
There is strong evidence that environment is not the cause because hermetically sealed paper capacitors have been found to go as leaky as any other package. The water that ends up causing the leakage is created chemically by the decomposition of the paper. |
10th Mar 2023, 3:18 pm | #37 | ||
12th Mar 2023, 9:14 pm | #38 |
This HT via a few tens of kilohms has long been my favoured method of bringing HT electrolytics back into service- it can be left for hours quite safely current-limited like this, even if things go awry internally and leakage shoots up or a short develops, little power will be developed either internally or by the resistor. With modern LEDs giving noticeable light output at less than 1mA, one in series gives a useful indication of how things are going without tying up a meter in the meantime. Even at 400V HT, a shorted capacitor will only draw 8mA through the LED, a nice bright "Achtung".
