Old 27th Aug 2013, 12:28 pm   #1
dazzlevision
Default Capacitors "Black Museum"
Hello,
Following on from recent discussions here about the short lives of 1950s and 1960s paper dielectric capacitors, I have assembled some pictures of such components, grouped by brand.
These were taken from my box of faulty components that I have removed from equipment over the years (my "black museum").
They show the evolution of capacitor technology. Unfortunately, the British based consumer product capacitor manufacturers (Dubilier, TCC-Plessey and Hunts-Erie) all seemed to disappear by the late 70s/early 80s. The only exception I know of is "LCR", which make the yellow axial Polypropylebne dielectric types I use in TV boost circuits. However, I've not been able to track their location down.
The only reasonably long lived Plessey (originally TCC) paper cap that seems to survive in long term storage is the grey plastic cased ones that started to appear around 1970, displacing the previous yellow cased "Supamolds" and "Duomolds". Does anyone have a spec for these, to confirm the dielectric used and the encapsulation material?
I have also attached a Word document with the same pictures but with labelling.
I've come across, but don't have examples of, other types such as the "Plesseal" by Plessey. Does anyone have a picture of this type?
Apart from the 1970s grey Plessey and the Mullard C296 "mustards" (and their Lemco or SRC clones), I would advise that all the other types are replaced on sight.
Regards,
Dazzlevision
Name:	Capacitors - black museum 001.jpg
ID:	83388   Click image for larger version
Name:	Capacitors - black museum 002.jpg
ID:	83389   Click image for larger version
Name:	Capacitors - black museum 004.jpg
ID:	83390   Click image for larger version
Name:	Capacitors - black museum 003.jpg
File Type: doc Paper dielectric capacitors - black museum - Dubilier.doc (456.0 KB, 481 views)
Last edited by dazzlevision; 27th Aug 2013 at 12:40 pm. Reason: Added text and Word file
dazzlevision is offline
Old 27th Aug 2013, 12:39 pm   #2
dazzlevision
Default Re: Paper capacitors "black museum"
More Word documents
Old 27th Aug 2013, 12:45 pm   #3
G6Tanuki
G6Tanuki's Avatar
An extremely interesting list...!
Wondering if anyone can refresh my memory about who made a particular type of capacitor I came across a lot in 1970s-era telephone exchanges. Usually low-value (up to 0.5uF) 250VDC working. Axial leads, hard green plastic encapsulation. Something very similar in appearance was used in the first generation of domestic plug-and-socket BT NTE boxes. They looked very much like a darker green version of the green Supamold so I'm thinking TCC.
The only time they ever failed (and we had hundreds of thousands of them in service) was when the overheads took a lightning-strike - and then you usually had other issues [I remember an entire house - six extension outlets - with the entire CW1306 wiring completely vapourised] to worry about rather than an exploded capacitor.
Also, the red-and-black-plastic early-1960s Plessey electrolytics used in transistor circuits - I'm rebuilding a piece of test-gear that has more than a smattering of these. Are they "Replace-on-sight" or do they survive well?
G6Tanuki is offline
Old 27th Aug 2013, 12:47 pm   #4
Station X
Station X's Avatar
All the Red/Yellow/Black Plessey Electrolytics I've come across have been bad. Perhaps I've been unlucky though.
I'm surprised to see a Mullard Mustard featured. I've never found a bad one.
Graham. Forum Moderator
Station X is online now
Old 27th Aug 2013, 12:57 pm   #5
turretslug
turretslug's Avatar
Ashcroft?
turretslug is offline
Old 27th Aug 2013, 1:30 pm   #6
Andrewausfa
Andrewausfa's Avatar
Rassau in Wales
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 27th Aug 2013, 1:33 pm   #7
G6Tanuki
G6Tanuki's Avatar
Originally Posted by turretslug View Post
Ashcroft?
They could very well have been Ashcroft. What I do know is that four 0.5uF 250V ones wired in series/parallel without benefit of any voltage-equalising resistors worked just fine for several years as the main energy-storage capacitor in a capacitor-discharge-ignition system I built for my Mk.1 Ford Escort.
[I think the design was published in "ETI" sometime around 1975]
G6Tanuki is offline
Old 27th Aug 2013, 1:41 pm   #8
G6Tanuki
G6Tanuki's Avatar
Given that you've sown the seeds of doubt, I'll replace the lot, probably with some nice translucent-blue-sleeved Mullard/Phillips ones (which never seem to fail).
Only time I've ever had one fail was when the speaker voice-coil failed open-circuit and the 'mustard' tone-correction capacitor across the output transformer primary lost the will to live. An ECL86 also lost its life in that particular incident.
I've got a nice collection of 400V rated NOS mustards that I use to replace waxies in general decoupling, bypassing and "that capacitor" service.
G6Tanuki is offline
Old 27th Aug 2013, 2:13 pm   #9
dazzlevision
Hello,
Glad you like the thread!
I have some axial capacitors of a dark green colour made by TMC (Telephone Manufacturing Company - later Pye TMC). Otherwise, Filmcap - Advance Filmcap - Gould maybe?
As for those red/black case with yellow adhesive label Plessey electrolytics; if they are in low temperature transistor equipment, they may well be OK but if in a valve radio or TV, I would replace them all.
Regards,
Dazzlevision
Old 27th Aug 2013, 2:17 pm   #10
dazzlevision
Hello,
Yes, failure of the Mullard C296 series is verty rare and I have only ever replaced a couple over 40+ years of repairing/restoring vintage equipment.
I included them, to show the change/evolution of the Philips black wax dipped paper capacitors into the very reliable C296 Polyester dielectric types that replaced them, including the green cased ones that first appeared and the "clones" made by SRC and Lemco (which also seem to be reliable).
I may well add another post with pictures of electrolytics in my "black museum".
Regards,
Dazzlevision
Old 27th Aug 2013, 2:19 pm   #11
dazzlevision
I forgot to mention that Dubilier (DCC) = Dubilier Condenser Company. Their very small capacitors (shown at the bottom of my "Dubilier" photo) were only marked with "DCC".
Old 27th Aug 2013, 2:46 pm   #12
af024
Thank you for this posting Dazzlevision. Putting everything in one place, together with a detailed description is just the job.
I don't know whether my contribution below is of any use (maybe not as some capacitors are seemingly not identified regrettably), but there are a couple of Aerovox amongst them.
Regards,
Andy
Now where on earth did I remove that from?
af024 is offline
Old 27th Aug 2013, 2:53 pm   #13
AC/HL
AC/HL's Avatar
I don't think the encapsulation makes a lot of difference, it's the dielectric that counts. The moisture gets into them all, even high grade ones, eventually. If it's paper, survival is just a combination of lucky factors.
Perhaps in the case of the Plessey electrolytics, the encapsulation did make a difference however. Had they been better sealed they might have fared better.
AC/HL is offline
Old 27th Aug 2013, 4:27 pm   #14
Alan Stepney
The red/black Plessey caps with the yellow labels were considered rubbish at the time they were new.
We would never use them, if we could possibly avoid it.
And, that was when I worked for Plessey!
Alan Stepney is offline
Old 30th Aug 2013, 7:25 am   #15
dazzlevision
Hello again,
I attach some more pictures and Word documents. These cover a). plastic cased electrolytics that have proved less long lived/unreliable than others of their era. I also cover some additional paper dielectric types and a few "overseas" electrolytics.
I think the "CRL" (inside a diamond) branded black cased radial electroytic is Centralab (USA); perhaps someone can confirm this. I'm not sure about the "Impec" and "Elcap" branded ones though; any ideas?
Perhaps the mods might change the thread title to Capacitors "black museum"?
Regards,
Dazzlevision
Name:	Capacitors - black museum - miscellaneous (1).jpg
ID:	83489   Click image for larger version
Name:	Capacitors - black museum - miscellaneous.jpg
File Type: doc Electrolytics - plastic cased & misc paper.doc (470.0 KB, 266 views)
Old 30th Aug 2013, 9:53 am   #16
threeseven
threeseven's Avatar
Mention is made of LCR capacitors in the opening post, I use their motor capacitors.
They are based in Wales,
http://www.lcrcapacitors.co.uk/default.htm
threeseven is offline
Old 30th Aug 2013, 8:01 pm   #17
AC/HL
AC/HL's Avatar
Default Re: Capacitors "Black Museum"
Title changed as requested
AC/HL is offline
Old 15th Oct 2014, 12:13 am   #18
AC/HL
AC/HL's Avatar
We have regular posts querying capacitor types/makes and related reliability issues. This comprehensive thread is well worth bumping for newer members' information
AC/HL is offline
Old 15th Oct 2014, 12:51 am   #19
kalee20
Wot! No transparent-epoxy encapsulated Rifas?
kalee20 is offline
Old 15th Oct 2014, 1:03 am   #20
Lucien Nunes
We had a discussion here: Tropyfol experience in which the Wima Tropyfol M was agreed to be a highly reliable cap. I have since tested many more of these and found them all to be excellent, and would be happy to retain them even in relatively critical positions for the time being.
I suspect that my next restoration candidate has a few hundred of assorted values, which will provide a useful sample size to corroborate.
Lucien Nunes is offline
