20th Mar 2023, 3:31 pm | #1 |
Ekco A22 donor chassis brought to life.
I saw this chassis in the for sale section , I just could not resist the challenge , thanks David (dekatron) parts missing were the mains tx HT choke and output tx loud speaker, I managed to squeeze in a bigger mains tx ,the rectifier is rubbing shoulders with it in fact there is a few mm gap.
The chassis was totally stripped cleaned ,painted ,next day re assembled replacing all the wax capacitors ,and all the rubber coated wire ,I managed to remove the two wires from the screened lead and threaded two thin wires in the screening , I had to fit a resistor to drop 6,3 to 4 volts for the rectifier I wanted to keep the original vale line up , the HT proved to be to high so I fitted a couple of resistors on the AC to the rect kinder to the valve I set the HT to 250volts the recommended HT for the EBL31.I wonder why Ekco used a tap on the mains tx for the dial lamp needless to say this one is connected to the 6.3 v I had all the valves in stock , I an pleased to say it worked first time . If I had seen the other items sooner ie the knobs and back that would have been a bonus . Err no I don't have a cabinet but you never know .Mick. Last edited by vinrads; 20th Mar 2023 at 3:52 pm. |
20th Mar 2023, 3:58 pm | #2 |
Re: Ekco A22 doner chassis brought to life .
Great job!
20th Mar 2023, 4:37 pm | #3 |
I think the reason for the dial lamp being underrun is that being in a small box and close to the scale, there could be a danger of damage to the scale from excessive heat. A bonus also is that the rather awkward job of replacing the lamp through the small access hatch is far less frequent. Congratulations on an excellent job you have made on the chassis.
A22 mains transformers always seem to fail - mine is non-original. A look at the winding resistances shows that the HT secondary must be wound with impossibly thin wire. I wonder why Ekco did that? Leon. |
21st Mar 2023, 4:19 pm | #4 |
Crikey, that's amazing Mick - you only received the chassis a week ago today!
Top job! It had so many key items missing that I never imagined it would ever live to see another day as a working radio! As a reminder of what state it was in, the chassis pics can be seen in this thread: https://www.vintage-radio.net/forum/...d.php?t=199049 Yes, on the original (rather puny) mains transformer, there was a 5V tapping so that the 6V3 pilot bulb, confined in its little box, would be under-run so as not melt or scorch the plastic dial.
21st Mar 2023, 7:06 pm | #5 |
Re: Ekco A22 donor chassis brought to life.
Thanks for that David ,I was so keen to make a start that I forgot to take a before picture. Mick
21st Mar 2023, 7:11 pm | #6 |
Wow,,well done Mick!
21st Mar 2023, 7:16 pm | #7 |
Yes!!! That really is an impressive 'back from the dead' resurrectional achievement... I'm always fascinated by reworks of long-decayed consumer radios that I would personally have 'gralloched' for parts but others have sought to restore.
It's only a 'short superhet' but I wonder how well it would perform on shortwave? Perhaps try listening around 6.2/6.3MHz on sunday mornings to hear some of the more-interesting free-radio stations?
21st Mar 2023, 7:46 pm | #8 |
Great work on the Ekco chassis! And so quick too! It took me months to do mine…
I made a mould for A22 knobs a few years back, got some nice looking ones from it, but I struggled with getting the brass insert central, and as such the knobs I made don’t rotate nicely. I really must have another go, and make up a proper jig to get them right! Regards Lloyd |
21st Mar 2023, 10:07 pm | #9 |
The remains of an Ekco A22 cabinet. I did think about repairing it someway but gave up on the project. Any use to you?
DFWB. |
22nd Mar 2023, 10:05 am | #10 |
22nd Mar 2023, 12:32 pm | #11 |
Hi Mick,
that's all that remains of the cabinet. Did consider having it 3D printed in mirror form but the cost might be prohibitive. DFWB. |
22nd Mar 2023, 12:54 pm | #12 |
Ok thanks anyway hopefully David may have one that is restorable .I don't suppose you have the spider thing and the chrome ring before I make one Mick.
22nd Mar 2023, 2:14 pm | #13 |
The A22 chassis and the remains of the cabinet were given to me by another radio enthusiast. It was his plan to do a repair to the cabinet but finally gave up on the project.
The rusty radio chassis was an easy fix. DFWB. |
22nd Mar 2023, 2:42 pm | #14 | |
(I think it's called the 'trivet').
