12th Mar 2023, 2:31 pm | #1 |
"Tinned" resistor leads
Does anyone know if the resistors typically used in the 80's & 90's had leads which were literally tinned, or were they a 60:40 or a similar alloy?
John |
12th Mar 2023, 6:02 pm | #2 |
Re: "Tinned" resistor leads
It varies with the maker. For high volume automotive applications, I specified strict solderability requirements, together with stock rotation and use-by dates. Military standards as usual were useless - so I devised my own.
As an example, vitreous enamelled wire wound resistors were not acceptable, as the leads would oxidise after enamel firing. The maker would sand blast the leads, and then dip them into a solder pot prior to dispatch. After they failed my solderability test, I visited the factory. The sand blasting process was crude and incomplete. Philips power metal oxide resistors with tin/lead coated leads were therefore specified for my high volume application. Leon. |
