8th Mar 2023, 8:11 pm | #1 |
Valve Base Jammed!
Hi All
I have a valve base - B7 I think, it takes the big old valves (e.g.VR109). Anyway this one is very much buried in the kit and not really removeable without major work! My problem is that two of the sockets won't let the valve pins slide in! I don't think that the sockets are filled with solder or that there is anything stuck down in the sockets. My question is: Is this a common occurance and/or how is it cured? I don't want to jam the valve in, as you might have gathered my experience with valves is very limited! Cheers James |
8th Mar 2023, 8:22 pm | #2 |
Re: Valve Base Jammed!
Hi James - a bit of a dilemma there then! Did you remove a faulty valve from that base yourself, if so how did it feel coming out? Can you visualise the individual sockets, do those two you suspect actually look any different from the other 5 sockets? I would use a suitably sized Philips jeweller's screwdriver or solid wire, perhaps from a bit of Twin & Earth power cable, that just fits the "good" sockets to exercise the tight-pin sockets a few times prior to inserting an expensive, fragile valve.
Good luck Chris |
8th Mar 2023, 8:46 pm | #3 |
Hi Chris
The valves all came out possibly a year ago so I can't remember how tight they were. I'm hoping the valve is OK. I've tried the one that went in the socket in other sockets and it went in fine - so not the valve. I have a set of those tools that are just a cylinder of metal with a handle (God, my memory!) A thin one goes in deep and one that fits the other good pins goes in to what feels like an obstruction. I can't see down the hole really, so it might be an obstruction - or just a very tight socket. I am wondering if it only needs to be forced or drilled! Hence I wonder how others cure the problem before I go at it like a bloke! Cheers James |
8th Mar 2023, 9:16 pm | #4 |
Sometimes valves with thin pins need a sort of jiggle to get all the pins to slip into the socket. Not too much pressure, just enough to get it done. Check the pins are not bent, if so carefully give them a gentle nudge to get them straight.
8th Mar 2023, 9:21 pm | #5 |
Hi James - I wouldn't advocate "forcing" it, since there will probably be a soldered lead at the end rather than it being an empty tube. You could test the other sockets with your thin tool (a punch?) to see if it will go straight through or hits solder beyond the length of the valve pins. Will the "obstruction" come out if you turn the equipment upside down and tweak it with a fine wire?
If not then it sounds like drilling would be the better option, marking the drill to the depth of the valve pins as a guide. Cheers Chris |
8th Mar 2023, 9:44 pm | #6 |
Similar to Chris's suggestion. I am not an expert on such problems, however, if it were mine, I would find a drill bit that just fits inside a known single good tube socket when using it as a probe to full depth. Then use it cutting edge inwards to see if I could clear the blocked one. See what debris comes out.
The bit held in fingers whilst gently rotating it gives a "feel" of the obstruction. Do NOT use in a drill! As suggested, mark the depth with some tape wrapped around the probing part to indicate maximum safe depth to penetrate. Rob
10th Mar 2023, 3:47 pm | #7 |
Hi Chaps
Thanks for the replies. In the end I had to go in with a mixture of hand held drill bits and files. There is a little flap on the end of these sockets which I removed to see inside without much success. I suspect that I had let solder get into the socket....... Moderators you can close this thread now, thanks. James |
