Old 22nd Mar 2023, 11:02 am   #1
sparkymike
Default Bally fruit machine question
Hi I am repairing a 70's Bally fruit machine. There are numerous bulbs behind the front panel.
Parts list (USA) lists bulbs as following types, but no voltages give.
55/44/47/63.
How do these match up with UK bulbs ?
Mike.
sparkymike is offline
Old 22nd Mar 2023, 11:10 am   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: Bally fruit machine question
Please see the table attached if its too small you can find it here :
https://www.kevinchant.com/uploads/7...sdiallamps.pdf
The 63 isn't listed on here but can be bought here:
https://www.amazon.com/CEC-Industrie.../dp/B00JNFAE2W
Mike T
Name:	Dial Bulbs.jpg
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 22nd Mar 2023, 8:10 pm   #3
broadgage
It is worth noting that in fruit machines that the supply voltage often has little connection with the lamp voltage.
A 55 volt supply and 12 volt lamps was one common arrangement, the lamps being driven in a multiplexed array such that each one was only "on" at a very low duty cycle.
I have seen UK fruit machines with a mains transformer suitable for either UK or USA mains.
broadgage is offline
Old 22nd Mar 2023, 9:10 pm   #4
bionicmerlin
bionicmerlin's Avatar
Being it’s from the 70s I think you will find
Number 55 would be 6.5/7 volt
The number 44 and 47 are the same apart from the 47 running cooler . They are both 6.3 volt Some people change 44s to 47s to cut down on heat being less wattage.
I’m not sure about the 63 so can’t help on that.
Should be easy to find . Do a search for pinball lamps . Andy
I bet that car doesn't have a suppressor.
bionicmerlin is offline
