11th Feb 2020, 9:10 pm | #1 |
Ekco TC138 TV ( driving me nuts )
Can anyone help with a problem on an Ekco TC138. I have been renovating this set at Snellings Audio and Visual Museum /www.snellingsmuseum.co.uk
The whole picture has started to creep up vertically from bottom to top by about half an inch. I had enough of a problem just filling the screen and just when I thought it was nearly perfect it started to rise leaving a gap at the bottom and missing the top if picture. The scan remains linear. Any suggestions would be helpful. Also I can get sound and no picture or picture and no sound just an off tune hum! Please note last2 images are mirror image! |
11th Feb 2020, 9:57 pm | #2 |
Re: Ekco TC138 TV ( driving me nuts )
Good evening,
Are there some shuffle plates around the neck of the CRT. Probably mounted on the rear end of the scanning coil assembly. My Ekco TMB272 has one and pushing it up and down makes the picture shift left and right and pushing it sideways shifts the picture up and down. If not it could be a leaky capacitor in the frame stage causing a DC offset on the scan coils. Christopher Capener
11th Feb 2020, 10:34 pm | #3 |
The Ekco TC138 is a development of the model TS88 so I assume the frame timebase circuit is the same.
Because the cathode current of the output valve flows through the scanning coils there will be a degree of picture shift. Excess current through the SP61 will a result of leaks in C20 or C21. DFWB. |
12th Feb 2020, 1:20 am | #4 |
No shuffle plates Chris unfortunatley, but I will check the SP61 again, I think I have changed the caps in framestage but I will recheck
Thanks David |
12th Feb 2020, 11:02 am | #5 |
Check the caps again. I have a number of variants of these receivers and have never experienced frame creep providing the frame caps have been replaced. The SP61 is not an ideal FOP valve but appears to work well with the TS88 series. It is very easy to miss one. The best method is to locate each one on the circuit and mark it with a highlighter as you replace them. This way you find them all.
Check also the screened cable to the top cap of the SP61 for leaks. It was a stock fault in its day. Very reliable receivers. An interesting one! John. |
12th Feb 2020, 11:08 am | #6 |
Cheers for that I will check next Tuesday and report back.
David |
12th Feb 2020, 11:35 am | #7 |
I took these pictures a few moments ago.
As you can see you should not be struggling for height with any Ekco model. I turned the height control almost fully to take this picture and amazingly the linearity is not at all bad! This TS88 has not been turned on for around 3 years and it came straight on with no adjustment. It needs a little twiddle but demonstrates Ekco quality 70 years ago. [As David has mentioned the original TS88 chassis was employed with slight variations in many Ekco models.] The later versions such as the TC138 being superhets. The rest of the circuit remained the same. Regards, John. |
12th Feb 2020, 6:40 pm | #8 |
Hi John
Maybe I am being a little too critical with our set. I see that the top of your picture is missing so as to get the bottom just right. I have been trying to centre the whole picture just a bit more, I can get ours to look exactley as your is so maybe I will settle for that if I can cure the scan from rising after a while. I hope this makes sense to you !!! |
13th Feb 2020, 1:25 pm | #9 |
This is purely adjustment. My example would center up correctly if I pulled it from it's sleeping place and did a bit of twiddling. It should be perfectly linear and central on the screen of course. The TS88 is more than capable of producing this.
Yours looks fine and providing it is stable, I would leave it at that. This chassis tends to suffer from slight line drift when warm. If the SP61 is OK I would suggest you replace the two silver mica 100pf capacitors in the line oscillator. They are a common cause of drift and a stopped oscillator. Very unusual for this type of cap to play up but they do in the TS88! They tend to drastically reduce in value. John. |
13th Feb 2020, 1:58 pm | #10 |
Yes I have got a bit of a line sync problem when it first comes on, 1 minute and it remains fine. I did find a 2pf video coupling capacitor ( cannot remember C number ) this cured a poor video fault. I have never (as far as I can remember) ever had a very low pf cap have such a drastic effect on a picture and it's a lot of years now.
25th Feb 2020, 7:13 pm | #11 |
John you were right, SP61 caused line drift, still cannot get picture correctly centred so I have taken everything off the tube neck, going to refit tube in situ and then fit and adjust the neck mountings and focus assembly. Then hope for best.
26th Feb 2020, 2:05 pm | #12 |
Great to know you have calmed down the line drift. You often have to try several SP61s, even new ones until you find one that is completely stable and twitter free.
The picture centering arrangements on the TS88 are a bit crude. They involve loosening the 4BA screws that secure the focus assembly to the chassis, note loosen. The unit can then be tilted/rocked slightly side to side and back to front. Do not slide the whole assembly forwards or backwards as this will upset the central position of the focus lever. Note the packing pieces in this shot of a 88 chassis. Cardboard has been placed at sometime during it's life, probably when the tube was changed, under the magnet assembly to TILT it back slightly once the securing screws have been tightened. This is quite OK but I would suggest a thin strip of polythen or something similar is wound once around the tube neck where it passes through the focus magnet. The last thing you want is metal to glass neck contact! I hope this info helps clear this up. It should run faultlessly for many hours. The LOPT is very reliable and the whole chassis runs very cool. John. |
10th Mar 2020, 9:33 pm | #13 |
At long last I have the picture in the centre of the screen to my satisfaction. I cheated by magnetising two washers and glueing them to the assembly. I think it looks ok but I am now biased !!
I still cannot get sound and vision together, so I think I am going to settle on picture. |
11th Mar 2020, 12:08 pm | #14 |
The IF tuning cores tend to unwind themselves downwards on these chassis. Best left well alone as the picture is great. John.
11th Mar 2020, 2:13 pm | #15 |
Nice result!
I’ve had to demagnetise scan coils on a Philips 385U before, my own fault really, I had to replace the steel wire, and to check the replacement was in fact steel, I stuck a big magnet to it! The picture was shoved up into one corner on that one, but demagnetising it cured it. Regards Lloyd |
11th Mar 2020, 3:22 pm | #16 |
The original wire was referred to by Philips as oxidised Armcowire.
Most likely it was a nickel-iron wire. Jac |
11th Mar 2020, 9:31 pm | #17 |
Mine got replaced with welding wire!
