Reply
Old 22nd Jul 2019, 1:38 pm   #661
Jonster
Default Re: 405-Line VHF Aerials 2013 to the present day.
Here's on local to me in Pevensey Bay, East Sussex, B1, 3 and 5 together, all seen better days! B3 VHF pointing to Dover, UHF to Heathfield.
Jonster is offline   Reply With Quote
Old 22nd Jul 2019, 2:18 pm   #662
Mr Hoover
Mr Hoover's Avatar
The remains of the band 1 elements
look a bit short for Crystal Palace Ch1,
probably for the Eastbourne relay on Ch 5.
Mr Hoover is offline   Reply With Quote
Old 1st Aug 2019, 9:43 am   #663
Heatercathodeshort
Heatercathodeshort's Avatar
Travelling back from Dulwich yesterday I spotted this interesting channel 1/9 aerial in Aberdeen Road Croydon.
It's surprising how many 405 aerials remain in this area literally within touching distance of CP and BH. I guess that being so close to the transmitter, the co-ax screening not being very efficient back then, would probably lead to ghosting and other odd effects. Being too close was probably as bad as being too far away! Regards, John.
Name:	Aberdeen Road Croydon. 1-8-19..jpg
Heatercathodeshort is offline   Reply With Quote
Old 1st Aug 2019, 12:57 pm   #664
Jonster
The high gain and narrow vertical beamwidth of the transmission antennas meant that areas in the immediate shadow of the mast often received poor pictures. See here for an explanation of the 'Penge Effect'
https://www.bbceng.info/Install/Tran...pub-effect.PDF
Old 1st Aug 2019, 1:03 pm   #665
Nuvistor
Nuvistor's Avatar
Initial very local coverage of UHF from Winter Hill was a problem, it was resolved in the area I worked but not sure how Horwich, which is under the mast, faired.
Frank
Nuvistor is offline   Reply With Quote
Old 1st Aug 2019, 1:42 pm   #666
Richard_FM
Richard_FM's Avatar
I have some relatives in the Melton Mowbray area & their picture from Waltham was never brilliant, especially my Aunt & Uncle's in Great Dalby.
Hello IT: Have you Tried Turning It Off & On Again?
Richard_FM is offline   Reply With Quote
Old 1st Aug 2019, 5:18 pm   #667
G6Tanuki
G6Tanuki's Avatar
Originally Posted by Heatercathodeshort View Post
Travelling back from Dulwich yesterday I spotted this interesting channel 1/9 aerial in Aberdeen Road Croydon..
Lovely!
A friend used to refer to those as "Fishbone" antennas, for obvious reasons.
Old 1st Aug 2019, 5:25 pm   #668
G6Tanuki
G6Tanuki's Avatar
Spotted today in Newbury, just off what everyone locally calls the "Halfords roundabout".
Pointing down the valley to London, the BI antenna has lost its dipole but the director remains.
The side-by-side BIII antenna is a nice example of a "Slot-fed" double-Yagi with 'delta' matching back to the feedpoint.
The coax from the BIII feedpoint has come away from the boom/mast and now trails sadly over the lower part of the 'slot' element.
It's a rather well-constructed setup, with a big beefy clamp from the BI boom to the mast and paired paralleled arms supporting the two booms of the BIII array from the BI boom. I wonder if perhaps this design was originally BI-only and the BIII elements were retrofitted when ITV came available?
Old 2nd Aug 2019, 10:54 am   #669
Peter.N.
I had a customer that lived almost directly under the Stockland Hill mast and had a dreadful signal.
Peter
Peter.N. is offline   Reply With Quote
Old 2nd Aug 2019, 11:31 am   #670
SteveCG
Re post no. 668:
The Band III looks like a J-Beam design - except that I've never seen that mounting method used for J-Beam. No sure about the Band I maker, except that the substantial mounting clamp could also be a J-Beam design.
SteveCG is offline   Reply With Quote
Old 12th Sep 2019, 9:31 pm   #671
shortwaverx
shortwaverx's Avatar
Photographed in Lynton, Devon today.
Cheers,
Ian
shortwaverx is offline   Reply With Quote
Old 13th Sep 2019, 9:32 am   #672
Hybrid tellies
Hybrid tellies's Avatar
Glad to see it is still there. I took a picture of this some years back. I think the problem in the Lynmouth/Lynton area was not to little but to much and to many signals. There is a clear 30 mile path across the Bristol Channel to both the high powered 405 line transmitters at Wenvoe on ch5 and St Hilary on ch10.
Because of these strong signals and the surrounding hills and cliffs multi path or ghosting was a severe problem on both channels. It was a nightmare for local aerial riggers who tried different types of aerials to try and overcome or reduce the ghost problem.
Simon
BVWS member
Hybrid tellies is offline   Reply With Quote
Old 13th Sep 2019, 9:19 pm   #673
akuram1
That really is a beauty. Never seen one like that before. J-Beam obviously.
akuram1 is online now   Reply With Quote
Old 13th Sep 2019, 9:37 pm   #674
G6Tanuki
G6Tanuki's Avatar
What a fascinating design.... I really can't figure it out properly! Is it just a BI design or is the 'skeleton slot' also supposed to provide some form of directionally-confused BIII coverage ??
It still seems to be a case of dipole-and-director [the director appears to have adjustably-extensible ends] which is a less-than-optimal design as far as gain and directivity/anti-ghosting is concerned.
Old 13th Sep 2019, 10:02 pm   #675
Nuvistor
Nuvistor's Avatar
J-Beam HornBeam, see pages 418/419
https://americanradiohistory.com/Arc...ld-1956-09.pdf
Frank
Old 13th Sep 2019, 10:17 pm   #676
1955APREN
1955APREN's Avatar
Guest who fitted a few of them , called Hornbeam made by Jay beam
The band 1 rods are adjustable held in place by a set screw . The lasting kit had
a bolt and sort of gear armament that was operated with a alan key . Did not fit
many as this type of lashing kit was time consuming
Derrick
1955APREN is offline   Reply With Quote
Old 13th Sep 2019, 10:25 pm   #677
Nuvistor
Nuvistor's Avatar
How well did they work?
Frank
Old 26th Dec 2019, 8:40 pm   #678
dragonser
dragonser's Avatar
spotted a while ago, but photographed today in Wallington Surrey.
there is also another one on KIngston road in New Malden. I will take a photo when I can..
Regards Peter B
dragonser is offline   Reply With Quote
Old 31st Jan 2020, 4:49 pm   #679
Tazman1966
Tazman1966's Avatar
Here's one I didn't spot until today. It's round the corner from my house in the next street along here in St Albans. One of many ch1/ch9 combined arrays that were installed around here.
Sorry about the not too clever picture. I think the lens on my camera phone needs a clean
All the very best,
Tas
Tazman1966 is offline   Reply With Quote
Old 1st Feb 2020, 11:17 am   #680
Peter.N.
Same antennas as we installed in Petts Wood in the '50s. We were looking directly at Crystal Palace but Croydon was off in the distance.
Peter
Reply
