Old 30th Jan 2023, 7:40 pm   #1
carlos10
carlos10's Avatar
Default Kenwood TS830S no ALC in tune mode.
hallo,
in tune mode i have no alc indication,
first is was intermittent, alc on a few bands,
now the alc indication is completely gone,
in tune mode the meter makes a small movement to the left of the zero mark,
the radio is still performing full output 100watts,
mayby there some quys who experienced the same symptomes....
carlos on6cn
carlos10 is offline
Old 30th Jan 2023, 7:46 pm   #2
Cruisin Marine
Default Re: ts830s no alc in tune mode
There are posts relating to this problem
https://cse.google.com/cse?cx=008872...h+this+website
"Behind every crowd, there's a silver Moonshine"
Cruisin Marine is offline
Old 30th Jan 2023, 9:01 pm   #3
HamishBoxer
HamishBoxer's Avatar
Dirty processor switch a quick look revealed.
HamishBoxer is online now
Old 1st Feb 2023, 9:33 am   #4
carlos10
carlos10's Avatar
Default Re: Kenwood TS830S no ALC in tune mode.
No, it's not the processor this time, is there somewhere a description in pdf how TS830 ALC works?
Carlos ON6CN
carlos10 is offline
Old 1st Feb 2023, 10:16 am   #5
murphyv310
murphyv310's Avatar
Guaranteed it will be dry joints.
My very clean TS-830S had the same issue and other intermittent problems, all gradually sorted with so many dry joints found.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 1st Feb 2023, 10:57 am   #6
carlos10
carlos10's Avatar
ok, thanks reply, what do you mean with dry joints...
no indication of mike sig in alc mode as well
i have full rf output in usb/lsb
so mike is working ok , also full cw rf output
tested on other receiver
what does the relay on the rectifier unit...
carlos on6cn
carlos10 is offline
Old 1st Feb 2023, 4:49 pm   #7
murphyv310
murphyv310's Avatar
The soldering gets what is known as dry joints. Also I've come across soldered joints that have little or no flux and when prodded reveal a clean printed circuit land. This problem is now rearing it's ugly head on the TS-830S
Do you have the service manual? To identify the circuit area and what individual components do without it is impossible. To do the resoldering will require patience and time doing a little at a time and testing so any mistakes can be rectified, not really a job if you are less than confident.
Mine started to show problems after replacing the PA valves as items got disturbed inside.
Cheers,
Trevor.
Old 1st Feb 2023, 5:42 pm   #8
HamishBoxer
I would always recommend a head magnifier when looking for dry joints,
Old 2nd Feb 2023, 7:43 pm   #9
carlos10
carlos10's Avatar
solved, it was rl1 , this one drive me nuts hi
carlos on6cn
carlos10 is offline
Old 3rd Feb 2023, 12:43 pm   #10
G8UWM-MildMartin
Was that the 4-pole one on the AF Unit?
Unfortunately, Kenwood/Trio called all of the three different relays (ANT relay, Rectifier Unit relay and AF Unit relay) RL1.
G8UWM-MildMartin is offline
