6th Dec 2022, 2:50 pm | #1 |
Record cleaning machines
I know this has been discussed a few times so apologies if I am covering old ground.
I have just got out some old Christmas LPs and have been disappointed by the numerous crackles and pops on them. I am very careful with my records and don't think there are many if any actual scratches on them. Quite a few of my older records have similar surface noise to some extent. I have been looking at record cleaning machines and am interested in either an ultrasonic one or the more expensive ProJect VC-E vacuum type. Neither are cheap but I may go for one or the other after Christmas if I can be convinced of their effectiveness. Both get good reviews. Does anyone have any experience of either type of machine and its effectiveness?
Paul |
6th Dec 2022, 4:03 pm | #2 |
Re: Record cleaning machines
I got one of these ultrasonic record cleaners and it is just the best thing since sliced bread and pretty reasonably priced too.
https://www.amazon.co.uk/VEVOR-Ultra...091DQ69RC?th=1 Effectiveness? Very! Steve.
6th Dec 2022, 5:05 pm | #3 |
Looks ideal, I am not sure I would have it at too high a temperature though for records.
Peter |
6th Dec 2022, 5:16 pm | #4 |
I was hoping that the ultrasonic one would be good as I also restore clocks as a hobby and an ultrasonic cleaner would be good for clock parts.
Paul |
6th Dec 2022, 5:18 pm | #5 |
Would this be OK with 78's? Presumably best to keep the temp below about 40 degrees C? I have a smaller one that I have used for clock parts - works well. Have used it on a 200+ year old 7 day movement and also 1920's Smiths car clocks. Obviously best to dismantle them first!
6th Dec 2022, 5:20 pm | #6 |
I will let you know if I get one!
What cleaning fluid should be used for records?
Paul Last edited by PaulR; 6th Dec 2022 at 5:32 pm. |
6th Dec 2022, 6:30 pm | #7 |
I don't use the heater and I keep an eye on the bath temperature as it warms up of its own accord after a while, I guess the transducers loose heat to the tank surface.
Cleaning fluid is a minefield and there's all sorts of esoteric overpriced stuff out there. A little (really a little - a drop or two) of detergent does help to wet the surface and loosen the dirt. Rinse in clean water afterwards, enthusiasts use demin water but I don't... I spin the record to shed the excess drops of water and then air dry in the handy little rack that came with the cleaner. Some folks use photographic wetting agent which is a bit posher than my general purpose detergent and I think I might treat myself to a bottle. Ilfotol is a favourite. Steve.
6th Dec 2022, 6:57 pm | #8 |
Thanks for that, Steve, the tap water here is hard so maybe demineralised water to rinse would be best
Paul |
6th Dec 2022, 8:34 pm | #9 | |
Love your avatar BTW Steve.
6th Dec 2022, 10:10 pm | #10 | |
Alan |
6th Dec 2022, 10:16 pm | #11 |
The VPI is the one I use. Does a superb job. I use Liquinox critical component cleaner as the "soap ".
Highly recommended. https://www.musicdirect.com/equipmen...aning-machine/ Joe |
6th Dec 2022, 11:21 pm | #12 | |
Many proprietary record cleaning fluids contain ipa.
Paul Last edited by locknut; 6th Dec 2022 at 11:47 pm. |
7th Dec 2022, 5:39 pm | #13 |
I use a Moth RCM - scrub and suck!! Just the ticket.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
7th Dec 2022, 7:35 pm | #14 |
The recomended solution for LPs (NOT 78s) is deionised water, IPA and a couple of drops of photographic wetting agent.
There are folks on e-bay who buy a 5l container and split it into 100ml lots. They make quite a bit of money I am sure but 100ml will last forever in this application. Peter |
7th Dec 2022, 7:37 pm | #15 |
Do members here have any experience with the Knosti Disco Antistat Record Cleaning Machine? It is well reviewed on Amazon.
I've been wanting to pull the trigger on one for some time now but I have been put off by two things: Firstly, various reviews suggest that the included cleaning solution leaves a residue that builds up on the stylus. Secondly, some reviewers complain about the record clamp not being too good at keeping labels dry. This seems a shame as I think there is a rubber gasket between the record clamp and the record. I really don't want to risk things getting wet. |
7th Dec 2022, 7:39 pm | #16 |
Me too. I bought mine when they offered it as a kit. Build your own box according to plans they supplied.
The suck is provided by a vacuum cleaner pump. That is why it makes such a racket. Craig
Doomed for a certain term to walk the night |
7th Dec 2022, 8:27 pm | #17 |
Are you sure you mean that Peter? The VEVOR ultrasonic cleaner mentioned earlier has a 6 litre capacity. I make my own solution 1 litre at a time for my vacuum system and have used a good number of litres over the last few years.
Alan |
7th Dec 2022, 10:20 pm | #18 | |
I can also see that any system involving vertical rotation could cause problems with label wetting if the protection provided is inadequate or deteriorates over time. To be fair I've never used a Knosti but to me it doesn't appear to offer much in the way of advantages over cleaning by hand. Alan |
7th Dec 2022, 10:46 pm | #19 |
What about ammonia as a cleaning agent? It shines windows really well!
Paul |
8th Dec 2022, 12:11 am | #20 |
Smells superb too, Paul.
JOe |
