21st Apr 2021, 2:33 pm | #1 |
Replacement for a Sanyo A1221 4-pin. Transistor?
Hello!
As a relative novice, I am attempting to overhaul an early 70s Shibaden S610 VTR. I have a working machine as a reference (good), but no service manual (bad) After re-capping the Demodulator board (which had several way out of spec elcos), my next challenge is to fix the lack of flow from Tape RF in -> CVBS out. There are no traditional ICs on the board but looks like a component labelled "IC1" has failed. It is a Sanyo A1221 4-pin semiconductor component which I have never come across before. Can anyone advise what this thing is and - hopefully - a modern replacement? Last edited by collisr; 21st Apr 2021 at 2:38 pm. |
21st Apr 2021, 2:46 pm | #2 |
Re: Replacement for a Sanyo A1221 4-pin. Transistor?
21st Apr 2021, 2:46 pm | #3 |
It appears to be an FM detector chip.
https://www.ebay.co.uk/itm/LA1221-A1...-/282053719406 It looks to be quite simple, so you may be able to lash something up using discrete components. |
21st Apr 2021, 3:14 pm | #4 |
Thanks guys. I did see the US-based ebay listing for NOS, but was hoping someone with more knowledge than me would be know of a modern equivalent to replace it with. An FM detector makes sense, this is the first component after the Tape RF input, but the next component down has no signal detected on a scope.
21st Apr 2021, 4:16 pm | #5 |
According to my 1999 Jaeger Elektronik book that A1221 is actually an LA1221 and is classed as a linear IC for FM intermediate frequency use. Unfortunately the book does not list an alternative.
Dave
21st Apr 2021, 5:30 pm | #6 |
Fairly obvious maybe but make sure that the DC supply (VCC) is getting to pin 2 wrt (with respect to) the ground pin 4 as per the data sheet in Mike's Post.
Some ICs can have low pin count and physically look like typical transistor body shape wise. David |
