11th Apr 2021, 9:36 am | #1 |
Marconi T24DAB
I've recently repaired one of these 50's portable radios. Following the usual wax capacitor replacement I found the HT to be low at 75V. I replaced the original rectifier with a silicon replacement and added a further 100 ohms to the mains droppers and the HT is now 90V. The sound quality was very poor due to the speaker. I purchased a replacement and mounted the output transformer in the space vacated by the original rectifier. Only other thing it needed was a DK91 valve. For what it is it works amazingly well but as you can see, could now do with some cosmetic restoration. Regards Graham |
22nd Apr 2021, 8:42 am | #2 |
Re: Marconi T24DAB
Hi Graham well done repairing the chassis do you fancy re covering the case , and painting the top ,it would transform it , Mick.
