Old 22nd Feb 2013, 9:19 pm   #141
audion_1908
Default Re: My Bush TV43 restoration.
I had to look up forumites, lol
Light dimmer as a variac
The light bulb a is a load on the dimmer so it works ok, and light bulb b is current limiter to TV, b can be 1 or more 60w bulbs
lots of electrical noise from the dimmer, but that will not matter, I have one cap the wrong size 2x 2 uf are fitted instead of 3uf its c35 it is to bypass the ht diodes and but ac ripple on the ht line will 4uf be ok, and why is it there in the first place?
thinks have come up and I wont be doing much on the tv for a week or 2, sorry
audion_1908 is offline
Old 22nd Feb 2013, 9:36 pm   #142
Sideband
Sideband's Avatar
You can't use a light dimmer as a variac
Reason? A light dimmer 'chops up' the AC waveform and effectively feeds pulses of AC to a lamp hence the light is dimmer. Just how many pulses (= mark/space ratio) are fed to the lamp depends on where the dimmer control is set. A TV will not like 'chopped up' AC.
Besides with the lamp in circuit, you don't need anything else. Suggest you use a couple of 60 watt lamp in parallel but don't bother with the dimmer.
Rich
Sideband is offline
Old 22nd Feb 2013, 9:44 pm   #143
audion_1908
OK, I will try that, start with 1 and work my way up
Old 22nd Feb 2013, 9:48 pm   #144
Freya
Freya's Avatar
what type of capacitors are you using for this part of the hum cancellation circuit ?
3.3uf is commonly available
Freya is offline
Old 22nd Feb 2013, 9:51 pm   #145
Sean Williams
Sean Williams's Avatar
Cue Johnny Cash......
Fingers crossed Friday evening is here, let's see a piccy of this most auspicious event!
I really hope it works first time - it's a hell of a lot of work otherwise!
Sean Williams is offline
Old 22nd Feb 2013, 11:34 pm   #146
Station X
Station X's Avatar
I'm afraid we'll all have to wait another couple of weeks Sean.
I wonder if this thread will be up to 200 posts by then?
Graham. Forum Moderator
Station X is offline
Old 23rd Feb 2013, 12:03 am   #147
audion_1908
it was an very large can, and was ac electrolytic , 3uf and I think 275v or 375v
I fitted an 2uf 630v Polyester or other plastic film Capacitor and a 18 year old 2uf motor run capacitor! I payed for a 1uf 630v capacitor to go with the 2uf to make up 3uf but I am still waiting for it to arrive!!!
I think the hum cancellation circuit is very strange, but as it wants 3uf I can have 4uf or 2uf? which is better?
Old 23rd Feb 2013, 12:42 am   #148
audion_1908
I have found that most things take a lot more time and work than expected and can still disappoint, I have a radio I built using 1930s parts over 8 years ago, it works ok but over runs one of the rf valves, and I still cant fix it I did follow the plans.
I may end up looking for a new CRT if I am not lucky or saving to have it re-gunned in france, eather will take me a long time.
I will film the power up and post the clip, when I do it
Old 23rd Feb 2013, 1:04 am   #149
audion_1908
I have had nearly 5000 views and I will have more than 200 posts by the time I am done, I have to get the tv working, get it working well, work on the wooden case, setup and fit the raspberry pi and other bits, designing and building the color converter, and filling the tv with good films and doctor who episodes.
Old 23rd Feb 2013, 8:47 am   #150
Heatercathodeshort
Heatercathodeshort's Avatar
Let us know when your going to fire it up and I will drop an email to the Central Electricity Generating Board. They don't like sudden demand surges.
Now come clean, you are going to spend the next two weeks getting first light just to spoil our fun..
Looks like I'll need a new bulb for the light in the window.
As always, good luck with the end result. Regards, John.
Heatercathodeshort is offline
Old 23rd Feb 2013, 9:33 am   #151
Sideband
Sideband's Avatar
There is no such thing as an AC electrolytic.
This tells me all....
I don't think I'll contribute any more to this thread.
Good luck though!
Sideband is offline
Old 23rd Feb 2013, 11:46 am   #152
Tazman1966
Tazman1966's Avatar
It may well have been a typo and should've read "an electrolytic" maybe?
All the very best,
Tas
Tazman1966 is offline
Old 23rd Feb 2013, 12:44 pm   #153
audion_1908
there are AC electrolytic capacitors, rs still sell them? they are just not used much, it looks like its a paper capacitor?
Bush TV43 Hum Cancellation Cap
https://www.vintage-radio.net/forum/...ad.php?t=71267
http://en.wikipedia.org/wiki/Electrolytic_capacitor
Bipolar electrolytics (also called Non-Polarised or NP capacitors) contain two anodized films, behaving like two capacitors connected in series opposition.[12] These are used when one electrode can be either positive or negative relative to the other at different instants, on alternating current circuits. Bad frequency and temperature characteristics make them unsuited for high-frequency applications. Typical ESL values are a few nanohenries.[13]
Old 2nd Oct 2013, 6:08 am   #154
audion_1908
I have not tested the Bush tv43 yet, so do not know if the tube is good, but even if its great I would like to have a spare for when the crt gets worn out, as they will only get harder to find in the future! I have found on ebay a lot of possible crt's, I think from my reading here that a Mullard MW 36-44 would be good.
the tubes are 190 miles from me that is a problem as I dont drive, but maybe another member needs a tube and could relay one? I am in surrey
http://www.ebay.co.uk/itm/Television...-/271287781995
Last edited by Sean Williams; 2nd Oct 2013 at 9:17 pm. Reason: to remove ebay list of tubes.
Old 2nd Oct 2013, 8:13 am   #155
Freya
Freya's Avatar
There will possibly never be a affordable way to change a tube in a vintage set now, the NOS tubes on ebay are likley to make decent money because of that.
As more enthusiats get into vintage television restoration any remaining new vintage stock will dwindle rapidly and we will be faced with making do with what we have.
You are faced with getting the set running to prove the tube good, no point in sourcing replacements or a spare at this stage IMHO
Stephen
Freya is offline
Old 2nd Oct 2013, 10:23 am   #156
Brigham
... designing and building the color converter...
I'm curious to know what you propose to use to display the 'color'. A revolving wheel, presumably. Perhaps driven by a Raspberry PYE?
Brigham is offline
Old 2nd Oct 2013, 1:35 pm   #157
audion_1908
yes, I was thinking of using a synchronized spinning color wheel on some glasses like the Vectrex 3D Imager http://www.youtube.com/watch?v=gCQ-L12g8c4 so it could do 3d or color but it would cut the effective frame rate. and the Raspberry pi should make a good media source.
Old 3rd Oct 2013, 1:48 pm   #158
Brigham
Wow! Now that wasn't what I was expecting! I can't quite see how a rather run-down 405-line set fits in with this project. A modern-ish 625-line B&W portable would be easier, being already compatible with the Raspberry, if you must use cathode-rays.
Have you looked at low-definition? Your kind of imagination seems more in line with Baird, rather than Marconi-EMI.
I've been involved with this club:
www.nbtv.org/
...for a good many years, and ideas like yours create much discussion and many actual working products. There is currently a scheme for a PIC-based colour decoder for sequential scanning, although I can't ever remember anyone suggesting a computer-driven helmet-mounted colour wheel. In fact, that alone would be a good article for the club newsletter!
Brigham is offline
Old 4th Oct 2013, 1:21 am   #159
audion_1908
I know a 625 line tv would be much easier, but I was looking for a "run-down 405-line set" as I wanted to mod it and it would be a shame to change a pristine vintage tv, and I like the look of the worn bush tv43.
computer-driven helmet-mounted colour wheel's have been done before, I will probably have most of the problems with software processing the video, and making the motor and wheel run quietly enough! if I could find some, the glasses from the Vectrex 3D Imager would work great.
Old 4th Oct 2013, 9:48 am   #160
ianm
ianm's Avatar
At the current rate of progress, your existing CRT will last forever!
Regards
Ian McLaughlin, BVWS member
ianm is offline
