Old 16th Nov 2008, 12:14 am   #41
Steve_P
Steve_P's Avatar
Default Re: Ferguson 606T restoration.
The set looks pretty good so far. Just wants the top linearity doing. Tube looks a bit dim, but that could bee the camera. Run it for a bit and it'll soon come up if it is low.
Cheers,
Steve P.
Steve_P is offline
Old 16th Nov 2008, 11:28 am   #42
Heatercathodeshort
Heatercathodeshort's Avatar
Hello Des,
Looks pretty good. The tube should be OK. I have never replaced a Mullard AW43-88, they are a great tube. The actual picture shape will not be as it would on a conventional tube of the period say the AW43-80 90degree. The makers were a bit concerned at the time of the flat construction of the 110 degree tube bulb and made the corners rather rounded to reduce stress. Its only a technical point and the pictures produced were excellent. This was overcome to a large degree when the AW47-90 19" tube was introduced in 1961.
Regarding your sound fault. If the audio amp is working ok [input to PCL82 triode section] it might be an idea to check the condition of the sound detector diode mounted in the final sound i.f. transformer. Its W4 inside L48/49 can. I have found several of these O/C in vintage sets giving no sound, or no vision if used as vision detectors. Must be an age thing as they very rarely failed when in normal service. Just a point but you can do a lot of head scratching with this one. Regards, John.
Heatercathodeshort is offline
Old 16th Nov 2008, 4:39 pm   #43
Line whistle
Line whistle's Avatar
Hi, The problem I had yesterday with the sound was caused by nothing more than the sound output valve being poorly seated in its holder, now ok. I'm pleased with the set and the Aurora. Thanks again to everyone for their help.
Cheers, Des.
ID:	21331   Click image for larger version
ID:	21332   Click image for larger version
www.freewebs.com/405tv
Line whistle is offline
Old 16th Nov 2008, 7:39 pm   #44
Heatercathodeshort
Your very welcome DES. I think we all enjoyed this one by its following. Nice to know it came to a good conclusion. 'BBC television will now be closing for this evening. Good night everyone, Good night, and just a reminder to switch off your sets..' J.
Old 16th Nov 2008, 7:54 pm   #45
Tazman1966
Tazman1966's Avatar
Hi Des.
Glad to see it turned out so well. I guess you can add working pictures to your website now. Smashing pictures although quite sad to see stills of "On the Buses" seeing as Reg Varney (Stan Butler) died today
Good luck on your next restoration.
Best wishes,
All the very best,
Tas
Tazman1966 is offline
Old 16th Nov 2008, 10:58 pm   #46
BGmidsUK
Thanks for this great thread! I've certainly enjoyed following it. Great work
BG
BGmidsUK is offline
Old 16th Nov 2008, 11:14 pm   #47
chipp1968
chipp1968's Avatar
Great Pictures
chipp1968 is offline
Old 20th Nov 2008, 5:20 pm   #48
Line whistle
Thanks, Here's a few more pics. My camera isn't doing the set justice.
Cheers, Des.
ID:	21381   Click image for larger version
ID:	21382   Click image for larger version
Old 20th Nov 2008, 6:29 pm   #49
chipp1968
chipp1968's Avatar
Very period
Old 20th Nov 2008, 7:02 pm   #50
Heatercathodeshort
Very stylish Des, a familiar setting to any 60's television engineer.
Regards, John.
Old 20th Nov 2008, 8:22 pm   #51
Tazman1966
Tazman1966's Avatar
A perfect step back in time (though hide the CD's next time)
Best wishes,
All the very best,
Tas
Old 20th Nov 2008, 10:13 pm   #52
Brian R Pateman
Brian R Pateman's Avatar
Very nice indeed, especially the period setting.
(And Helen says "How much do you want for the cat?")
Regards,
Brian
Brian R Pateman is offline
