Old 20th Jan 2019, 11:12 am   #201
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Help needed restoring a Murphy V310
Completely agree with DC's information. It is tuned very slightly to the HF side.
You will have to ascertain which version of the fine tuning method you have. Early versions have a spring and plunger affair that was very nasty. If you have this version details can be posted but it sounds like you have the polythene tube.
A thin knitting needle with it's point shaped like a screwdriver tip will be fine but you have to take great care not to apply too much pressure and damage the oscillator coil.
If you encounter problems it might be better to remove the tuner side screen, remove the BBC [channel 1?] oscillator coil. locate the core and give it a tiny turn and test. If results are poor, return it to it's original position and again give a tiny turn in the opposite direction. When OK refit the screening can.
Murphy tuners are incredibly stable and do not require a customer adjustable fine tuner. Hope this sorts it out. J.
PS Try the charity shops for knitting needles, plastic of course!
Heatercathodeshort is offline
Old 25th Jan 2019, 11:16 am   #202
Radio_Dave
Radio_Dave's Avatar
Fine tuning has greatly improved the appearance of the vertical white line, it's now only slightly visible on the darkest of screens.
I've never tuned a 405 line set before and I'm a little confused why fine tuning seems to be the same adjusting the brightness. It wasn't until the picture was very dark that it broke up or very bright before it went fuzzy. There was lots of adjustment between between the two, without any deterioration in the picture, so I went for max volume on the speaker.
Regards
Radio_Dave is offline
