31st Jul 2020, 1:56 pm | #61 | ||
Re: A phone too far ...?
Hello folks,
I'll try to deal with as many of the previous observations/suggestions as I can. In reverse order: Re the CD1000: whilst I can't claim to have any clue as to what's inside the little oblong box, I can only report as previously that it seems to make no difference whether the phone in question goes through the CD1000 adaptor or it doesn't - i.e. nothing changes when the CD1000 is removed. As regards checking out the sockets, as mentioned previously, for all practical intents and purposes this is impossible in at least one, arguably two, of the cases in question. Of the remaining two sockets, even one of those is only just about accessible; in real terms, of the four sockets in use, there's only one that's relatively easy to access. I'm not sure by any means, but I feel I might be right in saying that if you can't check all of the sockets, there's not a lot to be gained by checking any of them. If the suggestion is that I should disconnect the capacitor in the master socket, even if my residual electronic knowledge is adequate to identify the capacitor on sight, the master socket is only just about accessible enough to touch with your fingertips, never mind conduct internal surgery. A BT engineer might risk it, but I'm not at all sure I should. As regards Dave's question concerning where the resistor is in phone A in the picture I posted, I believe what's happened is that I posted that particular picture before installing the second resistor between T16 & T17, which is where it is now. Quote:
To the best of my knowledge, the only 'hitherto undisclosed variable' was the CD1000, which was indeed my bad, but which at the same time does not appear to influence the situation one way or the other. I do see that it would be nice for experimental purposes to be able to do as you suggest, but unfortunately I don't have the facility to achieve it. All of that being said, one experiment did occur to me which was rather easier to carry out. I had, stored away, a 746 of similar vintage to the 782 ( phone A ) which started all this. So, I unplugged phone A and plugged in the 746, which again was working perfectly well when last used. The net result as regards the effect on the ringing of all four phones was identical to when phone A is plugged in. I may not understand in-depth electronics, but I have a fair grasp of basic logic, and this tells me that one of two things must surely be true: either both phones ( i.e. the 746 and the 782 - phone A ) have precisely identical faults ( which seems to me to be relatively unlikely ), or else the fault doesn't lie within the phone at all. If that is the case - I do say 'if'!!! - then I'm slowly coming to the conclusion that I may simply have no choice but to accept the situation and live with it, this having already become a far more complicated problem than I ever dreamed it would be! At any rate, for whatever it's worth, that's the story so far. Any thoughts, observations, suggestions - bearing in mind my fairly rudimentary level of knowledge - are very welcome indeed, and by the way, let me also take this opportunity to thank all those who have contributed so far. When the film of this saga comes out, I'll be happy to credit you all accordingly. |
31st Jul 2020, 2:12 pm | #62 |
I think you're right in that it's something you'll have to put up. It's sounding very much like a wiring problem and as you can't get at the sockets to see what's what, never mind correct any problems, you're stuck.
31st Jul 2020, 2:32 pm | #63 |
I agree that the problem appears to lie with socket A, so you're stuck with it if you're not in a position to open it up.
31st Jul 2020, 2:46 pm | #64 |
The conversion of telephones with low impedance ringers in can be frought with problems, especially, as you alluded to in post 1, your distance from the exchange. Maybe you should've headed this post 'a line too far'!
The length of your line, the 'unknowns' of it on your premises and the resistance or other socket issues thereof could have significant impact on you being able to squeeze a quart of ringing from a pint network pot. Once you can drive a certain current though the bells, as low as about 13mA, you'll be fine. But you need some means of getting that sort of supply, and that might mean either a small exchange, stand-alone or computer-based, or a ringer extender box (REN Booster).
Regds, Russell W. B. G4YLI. |
31st Jul 2020, 2:55 pm | #65 |
I would suggest a simple thing to try. Get a master socket and three secondary sockets, all screwed to a piece of MDF/plywood etc. Then wire then all up 2-2 , 3-3 and 5-5 in each one. Then connect 2 and 5 to 2 and 5 somewhere along the existing set of sockets or preferably to the rear of the front cover of the NTE5 'Master socket' and ideally with your own wiring disconnected . Then plug your phones into the new set of sockets and see how they work. That should at least at least prove if the phones work OK when all plugged in to a known correctly wired set of sockets. And if the fault is in your internal wiring.
4th Aug 2020, 1:05 pm | #66 | |||
I may have misunderstood. I had thought it to be the case that unless it was possible to provide photographs of all the sockets, any individual ones on their own were of no use. Socket A is the one into which phone A - the new addition - is plugged; that, as it happens, is the only one of the sockets to which access is relatively straightforward. Hence, I've attached photographs of the inside of that socket, in the hope that they might at least help those of you with the knowledge to understand what you're looking at. Quote:
I feel like this is easier than I'm making it, but I just can't quite see how. I'm hoping that the attached pictures may indeed be of some help. As you all know by now, my knowledge of electronics is rudimentary to say the least, but further to numerous earlier references to a capacitor being part ( or all ...? ) of the problem, to my untrained eye, it looks as though the large yellow object is a capacitor. [ Can't quite remember what capacitors do ... store current ...?... although I never did quite get the hang of how that works! ] It worries me that if this is a capacitor - and if it's apparently the offending capacitor that's causing the problems - the only apparent way of disconnecting it is to cut it out of the circuit altogether ( it's obviously not designed to be unplugged or disconnected in any other reversible way ). In light of my experiences with the resistors, it concerns me that I might end up doing this only to find I then need to reconnect it somehow, which I'm ill-equipped to do. In case anyone thinks it makes a difference, I know the cable to socket A and the socket itself were installed 'after the event', as it were, i.e. not along with all the original cabling in the property, it being the case that the studio is a recent addition. In fairness, I have no reason to think that the guy who installed it was anything less than competent. As I say, it feels like I'm making this harder than it is, but I've no idea how; all I've done is plug phones into sockets. Still, if there's no other alternative, as mentioned before, we may just have to learn to live with it. As a Virgo ( not that I believe in that stuff! ), I just find it hard to let these things go ...!! |
4th Aug 2020, 1:54 pm | #67 |
That is a master socket. The yellow thing is the capacitor we've been talking about (in this circuit, it basically lets the AC current through to ring the telephone bell, but blocks the DC current that is used to indicate that the telephone is off-hook).
What bothers me is that the external wiring (to the white connector blocks at the bottom of the PCB) is just 2 wires to terminals 2 and 5. That suggests that the 'bell shunt wire' (terminal 3) is possibly not wired on any of the sockets and that they're all master sockets. |
4th Aug 2020, 2:25 pm | #68 |
The other thing that strikes me is that it's connected using four-pair cable. While that doesn't matter per se it's unusual enough to make it look like it was done by somebody who had their own ideas or used what they had to hand. As Tony says, there could very well be more than one Master socket.
The Master is usually near to where the cable comes into the house. If it's been installed or changed since the late-'80s it'll also be bigger (about the size of a single mains socket) with a line just above halfway down the front and the hole for the 'phone plug in the middle of the bottom half. |
4th Aug 2020, 2:34 pm | #69 |
Given that all the 'phones ring somewhat, they must all end up with a ringing capacitor in their bell circuit. And the capacitor in the socket shown in post #66 can only be connected to the telephone plugged into that socket (since there is no wire going to terminal 3 on the connector blocks).
Therefore there must be at least one other master socket in the installation to provide a ringing capacitor for the other telephones. My _guess_ is that all sockets are masters here, all have the capacitor, and that capactor is in the bell circuit of the telephone plugged into that socket only. |
4th Aug 2020, 2:51 pm | #70 |
They're all master sockets, if each pic is a different socket. It looks to me like the wiring is all spurred off from a central point to terms. 2 and 5 in each socket, but can't say for certain about sockets 3 and 4 as only one wire is shown in each!
But, if this is the case, and each capacitor is connected to each bell, even with a 3k3 resistor, you're going to be attempting to draw something like 56mA from the exchange! A bell with a REN of 4 - and NO 3k3 resistor - will only draw around 33mA, if the one capacitor in the master LJU is used. So your REN is way too high! Perhaps this is sinking your ringing signal to a level where it is innefectual?
4th Aug 2020, 3:44 pm | #71 |
Ah... I've just read post 66 properly and the pics are all the same socket! But, just in case the other sockets are masters too, then...
4th Aug 2020, 4:31 pm | #72 |
Putting together all that has gone before, I suspect that the situation is simply that socket A is a second master where it should be a slave (i.e. no additional components within it).
There appear to be two possible ways forward: 1: live with the situation you have currently 2: replace the current socket with the correct one. If you feel able to tackle option 2, I can supply you with a suitable socket* free-of-charge if you send me your postal address by personal message. You would then connect the blue and white-with-blue-stripe to the slave socket on terminals 2 and 5 respectively as they are currently in the spurious master. You would also need to connect the orange wire to terminal 3. Depending on whether the orange wire has been connected to terminal 3 on the other sockets, this should either solve the problem or mean that 'phone A no longer rings at all. *Looking at your images, it appears that your current socket fits a standard sinngle pattress rather the smaller ones only used with telephone sockets.
4th Aug 2020, 4:51 pm | #73 |
Or just snip the components off the spurious master jack and make it a slave.
When I used to sort out phone wiring faults for friends and family the most common problem was more than one master jack.
4th Aug 2020, 6:38 pm | #74 |
As the current situation is clearly incorrect, that would certainly be an alternative, though I was thinking of making the change reversible.
N.B. You still wouldn't get ringing on that socket without the orange wire being connected (at both ends!)
5th Aug 2020, 1:55 pm | #75 |
As far as the question of which of the four in-use sockets are or are not master sockets: we've established, I gather, that socket A is. Socket B ( living-room ) is completely inaccessible. Socket C ( office ) is what I've always understood to be the 'master socket'; certainly none of the BT or EE engineers who've been here have ever questioned that. As far as I can recall, it used to look like the one in The Pillenwerfer's picture, but was replaced a while ago ( a year or so, maybe? ) with a socket that's curved at the top and has the words 'Openreach Master Socket SC ( could be 5C ) on it. That was installed by a BT engineer. It's at the back of a cupboard and only just visible, never mind accessible with a screwdriver etc. The BT engineer was not impressed. Socket D ( bedroom ) is half-and-half; unlike the living-room, the cupboards in front of it are not fixed, but would be very difficult to move unless absolutely essential. It's a decorative brass socket ( as, by the way, is socket B, from what I remember of it before the TV units were fitted in front of it ). I wouldn't have thought either B or D would be configured as master sockets inasmuch as they look like they were probably just bought from B & Q or the like. I could, of course, be wrong.
All of this being said: the external phone cable comes into our loft and goes to some sort of junction box up there. I myself have never seen the junction box in question. You can laugh and point all you like, but I'm profoundly arachnophobic, and the chances of me going up in the loft are slimmer than a page 3 model. I therefore cannot provide any information about the aforesaid junction box except that I presume all the sockets stem from it; even that is pure assumption, however. Therefore: at a best-guess, it seems we can be fairly sure that sockets A and C are masters, and the balance of probabilities would suggest that B and D are most likely slaves, though this is not certain. As stated, the nature of the loft junction-box and / or it's involvement in any of this is, and will likely remain, unknown. If I've understood correctly, even the fact of there being one additional master socket is enough to cause problems, and potentially to cause this particular problem. I do say 'if'. Moving to the possible solutions suggested so far: Obviously, simply living with the situation is a possibility I may ultimately have no choice but to embrace. I feel there might still be a little way to go yet, though. Snipping the components off the spurious master to make it a slave may work; if ( again, I do say 'if' ) I've understood the observations about the ( orange? ) bell-shunt wire correctly, that may also cause phone A to not ring at all. As far as I can tell, the only way to reverse that situation, having snipped out all the unnecessary components, would be to replace the socket with a slave; which seems to bring us to Dave's suggestion. I'll be happy to take you up on your very kind offer, Dave, and will certainly PM you with my address. On the face of it, swapping one socket for another doesn't look like it would be too difficult; I'm not entirely sure how the internal connectors within the socket work, but hopefully it isn't rocket science. Presumably if I swap the sockets over and connect the orange wire as you suggest and the phone still doesn't ring, it's a case of going back to the status quo with the spurious master socket? As I say, I have no sure way of knowing whether the orange wire is connected on any or all of the other sockets in the circuit. Unless anyone has any other thoughts on the matter ( I'm open to any other suggestions that don't involve me getting a doctorate in engineering ), I'll PM my address to Dave and we'll see what happens next. Thank you all once again. |
5th Aug 2020, 2:50 pm | #76 | |||||
Mending is better than Ending (cf Brave New World by Aldous Huxley) Last edited by Dave Moll; 5th Aug 2020 at 2:54 pm. Reason: it helps if I include the promised attachment |
5th Aug 2020, 6:00 pm | #77 |
Sorry ... just me starting to lose the plot ... I knew what I meant.
Which was: if I don't snip any of the components out of the existing socket, but simply replace it with the slave you're very kindly supplying, then if the slave doesn't work, I can just replace the master socket 'as was', with all components still intact, and be no worse ( or better ) off than when I started. |
5th Aug 2020, 6:41 pm | #78 |
Correct.
11th Aug 2020, 4:16 pm | #79 |
<Sigh>
Well, there's good news and there's bad news. The good news is, with the slave socket connected, all three of the other phones ring just fine. In case you haven't seen it coming, the bad news is that phone A doesn't ring at all. I've connected the blue / blue & white wires as they were in the original socket, to terminals 2 & 5. I don't know whether it makes a difference which way round they go, but yes, I've made sure it's the same way round. I've connected the orange wire to terminal 5; results as above. Just in case, I've followed the directions on the packet and connected the orange & white wire to terminal 4; I don't know if you'd expect this to make any difference, but it doesn't. As regards the 'orange' and 'orange / white' wires: referring back to my original pictures, I've taken this as near face value as I can. As you can just about tell from the pictures, one wire is orange and the other is orange with a white stripe running along it. The packet describes these as, quote, 'orange with white ring / blue' ( to terminal 3 ); 'white with orange ring / green' ( to terminal 4 ). As per previous posts herein, I've taken their 'orange with white ring' to mean 'orange' and their 'white with orange ring' to mean 'orange with white stripe'. The blue wire is obviously already connected to T2 and the green wire isn't connected to anything, so I've assumed these are red herrings. So there it is. Unless I've missed something, short of carrying out experiments way beyond my capabilities / resources, it rather looks like we've reached the end of the road. Pending further advice, I haven't yet reconnected the previous ( spurious master ) socket as socket A, but I'm assuming that's the only way I'm going to get all four phones ringing, albeit barely in some cases. Thank you again, Dave, for the socket, and thanks to everyone for their contributions. In light of all of the above, if anyone has any other ideas that seem like they'd be within both my capabilities and my resources, by all means send 'em my way ...!! |
11th Aug 2020, 7:47 pm | #80 |
My guess is that the orange/white wires are not connected at the other end of that cable. I know it's next-to-impossible to get to, but I think the only way forward is to work out which socket that cable goes to and unscrew that from the wall to see how it's wired.
