23rd Jan 2022, 4:08 pm | #1 |
1930 Servant Bell Box Relocation
Hi, For some reason our semi has a servant bell box. It is fully working but it is on a wall we want to knock down. We have had a few electricians around but just lots of puzzled and horrified faces!
We would really like to keep it so checking on here if anyone has any advice on how to go about moving it? The wires into it would need extending about a meter. I've seen some other threads on here about the internals but they are all ok. Thanks in advance for any help. |
23rd Jan 2022, 4:35 pm | #2 |
Re: 1930 Servant Bell Box Relocation
If this annunciator's existing wiring around the house is sound, my approach would be to terminate it in a junction box at some point prior to it reaching the wall destined for removal, then to use multi-core cable (such as ethernet cable) between the junction box and the new location of the annunciator panel.
N.B. The junction box need be nothing more elaborate than a piece of terminal strip (known as chocolate block) in a wall-mounted back box behind a blanking plate.
23rd Jan 2022, 5:03 pm | #3 |
Thanks Dave that's great. I had thought that initially but the type of wire being used threw me.
23rd Jan 2022, 7:01 pm | #4 |
Interesting to see one still in use. How is it powered?
23rd Jan 2022, 7:39 pm | #5 |
It's on a transformer off the mains.
Thought it would be nice to keep it as a feature since it is working and the box is in great condition. |
23rd Jan 2022, 8:50 pm | #6 |
Small neat screw-terminal junction boxes may be found in the "burglar alarm accessories" section of various suppliers' catalogues. 10-, 20- and 50-pair telephone cable is available in short lengths from Ebay sellers.
There's probably a call wire from each push, a common wire from all pushes, 2 x transformer wires, and 2 x bell wires if the bell is remote. |
24th Jan 2022, 11:25 pm | #7 |
that's a nice feature and I'm glad you're saving it.
Kevin |
3rd Feb 2022, 2:05 pm | #8 |
Some friends had a semi with a very similar box and bell pushes throughout the house. It was a reasonably sized house built in the 1920s (4 bedrooms) but nothing very special. I was surprised they had a servant even in those days. I imagine it was an over worked maid of all work.
Unfortunately they stripped it all out . It was the 1970s, after the worst of the Barry Bucknell era, but something like that was just not valued at all.
Paul |
3rd Feb 2022, 2:18 pm | #9 |
As others have said, low-voltage wiring then - chocolate-block terminal strips, will be fine!
Exactly. Having to open the door and shout for servants is so uncivilised... |
3rd Feb 2022, 9:10 pm | #10 |
Hi, this should not be a complex issue. There appear to be 8 indicators most likely activated by 8 pairs of wires. Any "old school", sparks worth their salt ought to be able to "buzz' out each applicable pair, extend & reconnect onto each indicator in turn. Just compare it to reconnecting 8 separate doorbells.
To buzz out each call button - get someone to permanently press a call button then connect a continuity tester lead to one wire then touch the other lead to each remaining one until bleep heard. Mark up that pair then repeat. In the short term you could just extend the wires to the new position just to allow for making good the building works. It's a shame you do not live closer... I would have been happy to sort just for the love of rescusitating a lovely piece of vintage equipment |
4th Feb 2022, 12:40 am | #11 |
My paternal grandparents had three bells on springs in the kitchen in their Victorian flat in Edinburgh, operated through wires pulleys and cranks. Only the street door bell worked, one of six large brass pulls which seemed to be quite common on Edinburgh tenements when I was a kid.
There was a Bakelite handle in the lounge, you could hear the broken wire rubbing against the laths inside the wall, I can't remember what the third bell was for My aunt, who lived in a more suburban area of Edinburgh had an electric board like the OPs, I don't remember it ever working (but I do vaguely remember a lady who helped with the ironing). More recently some friends moved into house in Manchester with a similar board and I was looking forward to reverbing it along with stripping the paint off and varnishing it. As it happened, that privilege went to one of the dads, but he did a grand job.
-- Graham. G3ZVT |
4th Feb 2022, 9:03 am | #12 | |
From the other side of the indicator a single wire goes to each bell push. The other side of each bell push goes to the other side of the battery or transformer. Generally there is a length of twin conductor bell wire running from each bell push to the bell board. One wire is connected to a common terminal in the bell board and the other to an individual indicator. I'll try to post a circuit later if no one beats me to it.
4th Feb 2022, 11:43 am | #13 |
Circuit attached. The positions of the bell and battery may be transposed.
4th Feb 2022, 12:42 pm | #14 |
We have a similar one that I had working in our last house. It required a fair number of repairs to the silk covered solid wires that had been broken by previous workmen. I stuck it up on the kitchen wall in our current Edwardian house and have since discovered it is exactly where all the wires run to but the wife is not to keen on me hacking the newly decorated plaster off the wall to wire it in.
4th Feb 2022, 1:08 pm | #15 |
Some people have no idea of fun - or priorities!!
Paul |
4th Feb 2022, 6:03 pm | #16 |
Thanks for all the help and the offer Roger
Bits have all arrived now so going to give it a go next weekend We're doing a lot of renovations so plastering isn't an issue. I always think it is a shame not to try and save things like this. It's going to be above the new kitchen door once they finish building one! |
4th Feb 2022, 6:46 pm | #17 |
Telephone, Ethernet or alarm cable would be ideal for this.
4th Feb 2022, 8:41 pm | #18 |
Good luck & well done for having a go at the weekend. Another option for extending the wires would be to use a similar size pvc wire to the existing ones & join them using an automobile crimp connector (the yellow ones would be right size). The joints should be staggered so you do not end up with a large clump that would be difficult to conceal.
My apologies for info on how to buzz out the bell push pairs because the method I describe would be hit & miss unless all bell pushes were pressed or shorted out first. No ideal to mess too much with the old wiring though because the insulation may have become brittle with the passage of time. Thanks Graham for providing a circuit diagram, I was puzzled as to how the bell rang but can see it is a series circuit. Simple & effective. |
4th Feb 2022, 9:08 pm | #19 |
Annunciators like this were surprisingly common in 1920s and 30s houses, even in quite modest suburban semis. We tend to forget how common domestic servants were at that time - even lower middle class households like teachers and clerks would often employ a 'daily woman' who would spend most of her time in the kitchen, cooking and waiting for the annunciator to ring. Most of the annunciators were ripped out in successive refurbishments, but my aunt's 4 bedroom Streatham semi still had one 20 years ago.
4th Feb 2022, 9:11 pm | #20 |
