Old 21st May 2022, 4:06 pm   #1
ljdavek
ljdavek's Avatar
Default Defiant transistor radio
Hi All Dave here!!
I just picked up this vintage radio for a auto jumble today! What you people think??
So I want to power it up but is got to 2 sets of wires for what would be the old 4.5v battery’s how do I convert it to run with a 9v battery?
And any Curcit diagrams would be amazing!
Thanks
Dave .
ljdavek is offline
Old 21st May 2022, 4:23 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: Defiant transistor radio
Do you have a model number of the set or have you information that the set uses 4.5v batteries?
Rather than try to use a 9 volt battery, if they are 4.5V, you could use 2 sets of 3x AA batteries. Holders are available for AA batteries, it would keep the radio original.
https://cpc.farnell.com/pro-power/pp...wer%20Supplies
Frank
Nuvistor is online now
Old 21st May 2022, 4:56 pm   #3
Paul_RK
Paul_RK's Avatar
I can't think of a Defiant model that used separate 4.5V batteries - Perdio did in various of their models, and flat hand-lamp 4.5V batteries were popular on the Continent - but several Defiants were designed for the 4.5+4.5V PP11, essentially a PP9 in two sections. Standard colour code for the battery wiring was red positive, black negative, green for the mid point.
Paul
Paul_RK is online now
Old 21st May 2022, 6:11 pm   #4
Trifocaltrev
Trifocaltrev's Avatar
I just wondered if it could be a Defiant A%Dhttps://www.radiomuseum.org/r/co_op_defiant_a5a.htmlefiant A5.
Trevor.
Trifocaltrev is offline
Old 21st May 2022, 6:37 pm   #5
Sideband
Sideband's Avatar
Yes, we need a model number and some pictures (a picture speaks 1000 words)! You can't always just 'modify' something to work on a different supply. If it uses a centre-tapped supply (4.5 + 4.5) it might not be easy. Certainly you cant just wire in a 9V battery if that is the case.
Sideband is offline
Old 21st May 2022, 6:42 pm   #6
Bob_Moss
Bob_Moss's Avatar
There is a thread here which shows you the modification. I haven't done it to my A55 yet, still running on 2 x 4.5V batteries.
https://www.vintage-radio.net/forum/...&highlight=a55
I was so upset that I cried all the way to the chip shop.
Bob_Moss is offline
