Old 17th May 2022, 5:07 pm   #1
Ralphs House
Default Mystery radio
Had this a while but what is it? Three valves and seemingly no power supply so assuming battery powered.
ID:	257376Click image for larger version
ID:	257377Click image for larger version
ID:	257378Click image for larger version
ID:	257379Click image for larger version
Ralphs House is offline
Old 17th May 2022, 5:31 pm   #2
Ralphs House
Default Re: Mystery radio
Three valves, three large coils. Have no interest in restoring it, or keeping it really. Would be better in the hands of someone who likes really vintage stuff but its a curio all the same. I rescued it from a box of junk. It appears to have a printed diagram and component list so doubt its home brew.
Old 17th May 2022, 5:53 pm   #3
barrymagrec
Was probably a kit for home build, I would have thought.
barrymagrec is offline
Old 17th May 2022, 6:02 pm   #4
Any info at bottom right of the circuit digram?
Station X is offline
Old 17th May 2022, 7:09 pm   #5
HamishBoxer
HamishBoxer's Avatar
I would have said homebrew but for that circuit diagram, looks military. Looks well modded though , I must say. Not battery with 6.3 AC and HT written on it.
HamishBoxer is offline
Old 17th May 2022, 7:34 pm   #6
Silicon
Some of the parts have Air Ministry marks or numbers on them.
It could be either totally homebrew or alternatively made from modules taken from surplus military equipment.
Silicon is offline
Old 17th May 2022, 7:50 pm   #7
John M0GLN
John M0GLN's Avatar
With the number of controls on the panel, type of coil and tuning capacitors, could it be a transmitter?
John M0GLN is offline
Old 17th May 2022, 8:10 pm   #8
Cobaltblue
Cobaltblue's Avatar
The drawing seems to be attached to a lid or panel that has been repurposed. into a home brew.
You can see where part of the drawing and paint has been crudely scraped away to make an electrical connection with a bracket.
The component on the lid seems to be marked 10/1523
All in all a bit of fun for someone to play with
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 17th May 2022, 10:26 pm   #9
Ralphs House
Will post some more pics asap.
Old 18th May 2022, 10:02 am   #10
Gridiron
The parts list shows parts with RAF store numbers. Something home made using some RAF metalwork.
Mike.
Gridiron is offline
Old 18th May 2022, 10:09 am   #11
Ralphs House
Can't get to bottom of diagram but heres some more photos.
ID:	257416Click image for larger version
ID:	257417Click image for larger version
ID:	257418Click image for larger version
ID:	257419Click image for larger version
Old 18th May 2022, 10:12 am   #12
Ralphs House
I might have a go at restoring it if I actually knew what it was. If transmitter I won't bother. May just strip it for its parts and make some steampunk thing out of it.
Old 20th May 2022, 8:18 am   #13
AlanC
AlanC's Avatar
Looks more like a homebrew 1V1 TRF receiver to me, heavily screened RF stage and with what looks like perhaps preset and bandspread tuning for each tuned circuit In the post war era there was tons of ex military gear advertised in magazines that you could buy for very little and strip for the chassis and components. Bardwells here in Sheffield still had odd bits of it 'when I were a lad' in the late 60's/early 70's. There's a big hole in the chassis partly covered by other components which says it's not a professional build. As for the circuit, it's possibly a 'blueprint' that radio mags in the 50's were fond of publishing. I agree it looks kind of military except that I'd expect to see component designations like R1A, C2A etc. Very interesting!
Always expect the unexpected...
AlanC is offline
Old 20th May 2022, 9:12 am   #14
FrankB
What is the tube lineup?
I saw a VR65, IIRC that is a voltage regulator, without looking it up.
Quite uncommon in a HB receiver.
That, the number of variable caps, and the big coil tend to make me think it is a HB transmitter.
FrankB is offline
Old 20th May 2022, 11:50 am   #15
G3PIJpeter
Originally Posted by FrankB View Post
... the number of variable caps, and the big coil tend to make me think it is a HB transmitter.
The two variable capacitors in Post 1 photo 2 above appear about the same value and are in parallel. They are brought out to separate knobs on the front panel? Rather a strange arrangement.
Can you trace out the circuit? The VR65 is equivalent to the SP61 (see http://www.r-type.org/exhib/aaf0004.htm). A sketch of the circuit, even if incomplete, would offer some clues.
Peter
G3PIJpeter is offline
Old 20th May 2022, 10:17 pm   #16
Ralphs House
Other two valves
The VR65 ia a WWII military receiving pentode valve made for the RAF. I think it would be very difficult to trace out the circuit.
Old 21st May 2022, 1:12 am   #17
G3PIJpeter
VR65 (receiving pentode) - http://www.r-type.org/exhib/aaf0004.htm
1 2 3 4 5 6 7 8 TC
h k a g2 g3 m nc g1
What connects to the anode (pin 3) - g1 (top cap) g2 (pin 4) etc. ?
EL33 (audio output valve) - http://www.r-type.org/exhib/aad0112.htm
1 2 3 4 5 6 7 8
m h a g2 g1 - h k
Likewise, what is connected to the anode pin (3)? The control grid g1 pin (5) etc.
Where are other components connected that are not directly connected to a valve base? TRF receivers, oscillators and transmitters have distinctive circuitry that can help to identify what you are dealing with here.
Peter G3PIJ
Old 21st May 2022, 11:05 am   #18
HamishBoxer
Heavily got at, looking at the mixture of knobs. Still think that circuit is military though.
Old 21st May 2022, 1:01 pm   #19
G3PIJpeter
The pictorial circuit that can be seen in photos 2 and 3 of Post 11 includes components mounted on tagstrips; also a coil with tapping lugs (L2, L3, L9) down the side. This does not coincide with the actual layout of the components in the other photos, so I suspect that this pictorial circuit is simply whatever happened to be glued to the piece of metal that was used as the front panel. It's looking to me like a straight receiver built from whatever came to hand by someone who was not a radio technician. It might even not have worked!
Peter
Old 21st May 2022, 4:20 pm   #20
HamishBoxer
Certainly short wave anyway.
