8th Dec 2020, 12:21 pm | #1361 |
Re: The Thanks Thread
Thank to Graham (Station X) for very promptly sorting out an issue on Monday.
12th Dec 2020, 11:50 pm | #1362 |
A big thank you to Anthony for one of the pair of HP 540B transfer oscillators that were offered & for print outs of the relevant manuals, they should be a great help for getting it going again.
Also thank you to Rileyman for a pair of E1T valves & sockets, probably the closest I'll get to owning an original counter that uses them. David |
19th Dec 2020, 1:31 pm | #1363 |
Thankyou to chriswood1900 for supplying the Grinder/Buffer that safely arrived yesterday, will be put to good use.
David |
20th Dec 2020, 3:36 am | #1364 |
I second DMcMahon - chriswood1900's objects arrived impeccably packaged and perfectly safely, despite the delivery man's grumbling about their weight. I know how long packaging like that takes, and am suitably grateful! I hope the MCR21 project continues apace in the new year.
21st Dec 2020, 1:56 pm | #1365 |
A big thank you to Neutrino for sending me some suitable rubber grommets so I can finally start to finish off my Ultra Model 50.
30th Dec 2020, 1:13 pm | #1366 |
Many thanks to David G4EBT for supplying the 0.1uF Mustard capacitors, they will be put to good use.
David |
30th Dec 2020, 1:26 pm | #1367 |
30th Dec 2020, 5:45 pm | #1368 |
Many thanks to AdrianH for the restoration work on the Solartron CD814-2 oscilloscope and offering it here, now nestling amongst several friends.
Paul Bottrill
Bear2Biker |
31st Dec 2020, 1:35 pm | #1369 |
David G4EBT, many thanks for the Mustard's, expertly packaged, all arrived safely and will be under the iron very soon.
Best, Sean. |
1st Jan 2021, 9:21 pm | #1370 |
I would like to thank all for you help during 2020 and a very difficult year, what a great site, unrivalled I reckon.
4th Jan 2021, 4:12 pm | #1371 |
Thanks to Alan snowman_al for the 22 pots, should enable variable controls for width and height on my simple home made TV.
Adrian |
6th Jan 2021, 4:42 pm | #1372 |
Thank you (David Factory) for taking time out to find and sending me a line switch for my HP8601a
many thanks gezza123 |
9th Jan 2021, 1:04 pm | #1373 |
Thank you to whiskas (Rob) for the numerous Reel to Reel manuals that arrived today.
David |
10th Jan 2021, 5:26 pm | #1374 |
A big thank you to David (davidh1041) for the B7G valve holders.
A very generous offer. I have some upcoming projects using B7G battery valves so absolutely ideal. Cheers Mike T
13th Jan 2021, 4:16 pm | #1375 |
My thanks to Ian, Northyorks1 who saw I’d missed out on an offered post recently and kindly sent me a Grundig with the best packing I’ve ever know. Extremely kind. Sincere thanks.
17th Jan 2021, 2:49 pm | #1376 |
Many thanks to Steve (stevehertz) for the Technics RS-BX601 Cassette Deck which arrived safely yesterday (very well packed), will give it a test later today.
David |
18th Jan 2021, 1:08 pm | #1377 |
Big thanks for Tractorfan (Pete) for sending me the Polavision equipment .
Thanks you again.
Oh I've had that for years dear!! |
19th Jan 2021, 6:47 pm | #1378 |
A real big thank you to Roy for supplying me PDF copy of the Truvox Series 90 tape recorder Servicing Instructions manual, the large bound hardcopy manual must have taken some series scanning to produce the good quality PDF, it is much appreciated.
David |
21st Jan 2021, 3:56 pm | #1379 |
Many thanks to "yestertech" aka Andy for the excellent packed box of DK/DL/etc. valves he's sent me. Regards, David
21st Jan 2021, 9:00 pm | #1380 |
Thanks to Julian (Julesomega) for the Picoscope.
Regards Mike C |
