20th Mar 2023, 6:46 pm | #21 |
Re: Metamec electric clocks. Unsafe?
Maybe people will clear them out... time to look out at car boots and charity shops and save them!
20th Mar 2023, 7:06 pm | #22 |
21st Mar 2023, 1:15 am | #23 |
Here's a movement 'in storage'.
The bobbin is on a plastic former mounted on the laminations, which are connected with the rest of the clock; however the hands are all mounted on nylon sleeves and the only mounting of the mech to the case is to the perspex or acrylic body via deeply-set countersunk screws, themselves covered by the clock face. That's all then sealed behind the glass which is bolted to the same perspex body. Impossible to touch anything that might potentially become live in the event of a primary insulation breakdown (eg coil to laminations). It's almost double-insulated. The clock dates from the late 60's.
Kevin |
21st Mar 2023, 10:07 am | #24 | |
Mike. |
21st Mar 2023, 10:44 am | #25 |
I see, that makes perfect sense now
22nd May 2023, 10:03 pm | #26 |
Thanks to all of you that have replied.
My two clocks are running well on the replacement mains cables fitted, they have 1 amp fuses in the plug and the coils look pretty good. I don't think I'll fit an earth system even though the clock wind & adjust mech's are metal. Lovely clocks that keep perfect time. Regards ..... Gary |
23rd May 2023, 3:20 pm | #27 | |
23rd May 2023, 3:22 pm | #28 |
...and curse it on the odd occasion when it all goes wrong!
https://www.vintage-radio.net/forum/...d.php?t=137419 |
23rd May 2023, 4:46 pm | #29 | |
24th May 2023, 3:19 pm | #30 |
They are perfectly adequate & have been used successfully for many decades.
25th May 2023, 1:38 am | #31 | |
If the clock is a wall mounted device, they would mostly be approached "in service" using a ladder or "standing on a chair". A "zap" in such circumstances may well cause injury, including, if you fall just the wrong way, death. |
25th May 2023, 2:41 am | #32 | |
Other metal cased electrical equipment had Earth connections as standard, but used direct Mains connections. If was not uncommon in Australia for houses to be supplied with 3 phases. In the (maybe unlikely) event that two different phases were present in the same room feeding different GPOs, & devices operating from them had Active to case shorts, you would have full phase to phase voltage between them. If the metal case is earthed, both devices will blow the fuses feeding them, & there will be no danger. If, in the case of both GPOs being on the same phase & one has an earthed metal case & the other not, if the latter has an Active to case short, touching both simultaneously is dangerous. As far as radios, in particular are concerned, at the end of WW2, Australia did not have the plethora of different power supply systems the UK & Europe had, so did not have the requirement for the radios to be usable on both AC & DC Mains. We also didn't have 110v Mains, which in the USA made "series string" heaters a lot easier to implement than in 240v countries. What we did have was valve manufacturers who had vastly ramped up their manufacturing capabilities of 6.3 volt valves during WW2, so instead of setting up new production lines for "series string heaters", it made solid economic sense to use power transformers & produce "ac only" radios for the mass market, with the few DC Mains areas, being regarded as "niche" markets, where special radios using imported "series string" valves could be used. Interestingly, most such radios used "figure 8" cable, as with the Mains confined to the on/off switch & transformer primary, there was little danger of a Mains to chassis short. Power transformer design was a mature technology, & fires caused by burnt out transformers were pretty much unheard of. Transformers stink when they burn out, so in a domestic environment will soon be detected, whilst in commercial service, electronics with power transformers have run continuously for decades. Yes, transformers did fail, but not catastrophically, & were just replaced & the equipment put back into service. |
26th May 2023, 2:12 pm | #33 |
Semi-offtopic: Isn't there more than just tradition to the tendency of Australian equipment to use mains transformers? Philips did a specific redesign of their non-mains-isolated buck converter topology power supply in the K9 TV chassis to make it mains isolated for the Australian and NZ market.
26th May 2023, 2:48 pm | #34 |
Time to close this thread. It's drifted way off the safety of electric clocks.
