Old 15th Mar 2023, 12:49 am   #1
ThomasAdam
Default GPO 746 On/Off switch and ringing light
Hey all,
I'm wondering if I can makeshift something which approximates to:
  • Having an on/off switch
  • An external light which flashes on/off when the switch is in the 'off' position
For the on/off switch, I've read the following:
https://www.vintage-radio.net/forum/...d.php?t=141777
I am not certain though what type of switch I'd need, in conjunction with the plastic switch I seemingly can puchase here:
https://www.britphone.net/gpo-transp...tton-218-p.asp
Is there a complete "kit" I can buy which has the switch assembly as well as the switch itself? If not, is there some other kind of DIY assembly I can try instead?
As for the "external light" -- I'm aware of Handset No. 7:
https://www.britishtelephones.com/hands7.htm
I'm curious if, without that specific handset, but an on/off switch, whether it would be possible to create some external housing, containing a light bulb which would achieve the same thing.
Thanks all for your help -- and if there's anything I've not been clear on, please le me know.
Otherwise I look forward to your replies and help.
Thanks again!
Thomas
ThomasAdam is offline
Old 15th Mar 2023, 9:48 am   #2
Dave Moll
Dave Moll's Avatar
Default Re: GPO 746 On/Off switch and ringing light
If I understand correctly, you wish to be able to switch ringing between the bell and a light, in which case you will require a switch, locking, change-over. See https://www.britishtelephones.com/switch1.htm for a list of available switches (with some images).
For your external flasher, your best option is probably a small neon with a suitable series resistor connected in place of the ringer when the switch is in the appropriate state.
Dave Moll is online now
Old 15th Mar 2023, 10:00 pm   #3
Tim
Tim's Avatar
I have some of those switch 2a if needed.
Tim is offline
Old 16th Mar 2023, 3:11 pm   #4
ThomasAdam
Hey Tim. Thank you for the offer, I’d be very interested, please.
Kindly,
Thomas
