12th Mar 2023, 10:48 am | #1 |
Output from Marconiphone 4406 .
Hi i have a Marconiphone 4406 Unit with a Garrrad SP 25 Mk11 deck that i want to convert so i can use it to hook up to a Denon CD player, I know it has a rear DIN fitting can i just get a lead from the back of this (it has radio/tape connections on rear, see pictures) that will go to the Denon, I also need info about what stylus i might need to replace it with. Do i need a modern replacement? I don't have much knowledge on electronics so nothing too complicated please.
Thanks. |
12th Mar 2023, 11:30 am | #2 |
Re: Output from Marconifone 4406 Player
A couple of things.
1. Stylus. That looks to be a Sonotone 3509 cartridge (rebadged Garrard) KS40A, that stylus is the one you need. Others may well fit, check the ceramic cartridge sticky I made. In the photo it's the box in the centre. The others likely have nothing to do with this player, post a picture of what is in them if need be. 2. You will need to take the signal from your record player from the TAPE socket to a pair of RCA phono plugs for the Denon's line in. If the sound is lacking in bass you should add a 1 megaohm resistor in series with each signal lead, you could do this with 1/4 watt resistors soldered neatly inside the phono plugs. edit: just re- read the OP and I am not sure if you want to play CD's through the Marconiphone record player's amp, or the record player though the Denon system. Could you let us know?
Regards, Ben. |
12th Mar 2023, 3:23 pm | #3 |
Hi Ben
Thanks for the quick reply, The boxes came with Marconiphone but are empty. I want to play this through the Denon CD player if possible please. Also do you have a link where i can get the lead for doing this? |
12th Mar 2023, 6:11 pm | #4 |
The OP admits he does not have much knowledge, so just to say that he can buy a ready made 5 pin DIN to 2 phono plug lead. He does not need to make one. Search "5 pin Din to stereo RCA phono lead". The amp in the Marconiphone is quite good (if a little noisey) but should sound good if playing back CDs through it.
Edward. |
13th Mar 2023, 4:58 pm | #5 |
Re: Output from Marconiphone 4406 .
Thanks for the reply , i want to play through the Denon CD player, so this lead should work on this?
13th Mar 2023, 10:39 pm | #6 | |
Regards, Ben. |
14th Mar 2023, 11:57 am | #7 |
I have just ordered a 5 pin DIN to 2 phono lead from Ebay, Here is a pic of my current cartridge (Garrard KS40A) is this the best type to use and what stylus, I guess it will be suitable to run with the Denon
Thanks |
14th Mar 2023, 6:07 pm | #8 |
So Member's do not get confused, I am sure the OP means "play it through the Denon Receiver".
Edward. |
15th Mar 2023, 4:54 pm | #9 |
I have just got a 5 pin DIN to 2 phono lead from the Tape socket on the back of the Marconifone and put it into the Line 1 in on the Denon but cant seem to get this to work, however when put it from Line 1 output and back into the deck it works, am i doing something wrong as i was going to use the Denon as my amp and use the deck to play through it, Also sorry for all the questions but do i need a whole new cartridge or just the styli as i'm not sure how good this unit is, It was inherited from a family member but has not been used for years and sat around(i have just cleaned it all out and oiled/greased the mechanism which was partly seized), I know the stylus has had it though looking at the state of it
Thanks again |
15th Mar 2023, 10:47 pm | #10 |
Read my post #6 above, you have ordered the wrong cable.
Don't worry about changing the cartridge for now until we've sorted the cabling out. The stylus has two tips, try both, one is probably fine. It looks dirty in the photo, clean it carefully/gently with a q tip dipped in some isopropyl alcohol or similar.
Regards, Ben. |
16th Mar 2023, 11:49 am | #11 |
Hi Ben,Okay i need a 5 pin DIN to 4 phono not 2, I saw Edwards post and he said 2 so that is what i ordered, I have cleaned the stylus but all i am getting is a lot of hum from the deck, I know the amp works as when i put the CD player through it i get get sound so is it just stylus or cartridge possibly at fault? I have found "Garrard KS40A/Sonotone 3509 ST/LP x 2 Tipped Replacement Sapphire Stylus, Good Quality Replacement Sapphire Stylus for the Garrard KS40A Cartridge supplied with 2 x ST/LP Tips for playing 33's' and 45's" on ebay for £4.95 so this is what i need?
Perhaps i should have gone with a modern Deck!!! |
16th Mar 2023, 11:59 am | #12 | |
It is possible the cart has failed but that does not explain the hum, so do not rush to changing it.
Regards, Ben. |
16th Mar 2023, 12:20 pm | #13 |
Beware that there are a lot of 5 Pin DIN to Phono leads available that are not wired for this particular purpose. Often they are wired for use with the MIDI musical instrument interface instead. Unfortunately the vendors don't always mention this - I've ended up with some of the wrong type in the past.
16th Mar 2023, 12:23 pm | #14 |
Information for the OP.
The tape DIN (SK1 on one schematic) on your 4406 has 2 stereo outputs (pins 1 & 4) and 2 stereo inputs (pins 3 & 5). Pin 2 being a common ground/screen connection. So if the 5 pin DIN to 2 phono cable is wired to DIN pins 3 and 5, it will not work if you are trying to play the 4406 output to your Amp/Receiver. David |
16th Mar 2023, 1:55 pm | #15 |
Thanks so what type do i need as i am getting a bit out of my depth with this
16th Mar 2023, 2:08 pm | #16 |
See post #6. there is a picture linked. I don't understand why you are so confused.
Regards, Ben. |
16th Mar 2023, 3:05 pm | #17 |
This is one online example (of many) -
https://www.ebay.co.uk/itm/191524904...3ABFBM0LPEq91h This example is 2 metres long, some similar cables can be very short. The 4 phonos as opposed to 2 will provide ability to output the 4406 tape output as well as inputting a signal into the tape DIN. David |
16th Mar 2023, 4:13 pm | #18 |
Okay i will order a 5 pin DIN to 4 phono as mentioned, I have now cleaned the stylus and connections and seems to be better and working but terrible sound( i will order a new stylus and set up the balance on it and go from there
Thanks again |
16th Mar 2023, 4:47 pm | #19 |
Did you flip the little stylus lever 180º to expose the other tip (which will likely be okay)? Did you clean the tip as suggested in post 10? A buildup of crud will give poor sound
Regards, Ben. |
16th Mar 2023, 5:47 pm | #20 |
Yes i sure did but still awful sound, i think i will just order that one i found on ebay
